Accelerator is an additive that decreases dry time of General Finishes water-based products, which is helpful in humid conditions where dry time is normally extended. Available in gallons and 16 ounce sizes.
ANSWER:
Refinishing furniture in a space that is below or above the 65*-75* F range can lead to problems, and a space below 55* F is definitely too cold. One issue caused by cold temperatures is the development of dimples in the finish called "Orange Peel".
Ideal Conditions are 70 degrees F and 50% humidity. Refinishing furniture in a space that is below or above the 65-75 degrees F range can lead to problems, and a space below 55 degrees F is definitely too cold.
One issue caused by cold temperatures with water-based topcoats is the development of dimples in the finish called Orange Peel.
Dry time is the recommended length of time between coats of product, often called recoat time, and cure time is the length of time recommended before subjecting your finished project to daily use. The following factors can influence your dry time:
Extender is a wetting additive used to improve flow and leveling and slow the drying time of any water-based stain, topcoat or glaze, which is helpful in hot, dry conditions.
Wood Turner's Finish is a water-oil urethane hybrid for use on wood turnings, bowls and other lathe-turned projects, now made with more than 50% RENEWABLE RESOURCES formulated from sustainable materials that decrease the carbon footprint.
Water-based products do not last forever, even when unopened. General Finishes products are best used within 1 year of the manufacture date listed on the bottom of the can. The life of the product may be extended to 2-3 years with proper care and storage.
Thin GF water based stains with distilled water if desired. Start with 5%, adding up to 10% by volume.
Increase open time, if needed with up to 5% General Finishes Extender if allowed by local regulations. GF Extender will improve flow and leveling and increase open time, which is helpful in dry climates.
As seen in Green Building and Design Magazine.
Water-based coatings are the future of finishing. You may not be using them today, but you will be in the next five years.
