General Finishes Enduro Sanding Sealer
There are four benefits to using sanding sealer as the first seal coat prior to topcoat
General Finishes Professional Enduro White Undercoat is similar to General Finishes Sanding Sealer with the addition of white colorant to provide a primer undercoat for white/off-white wood finishes.
Enduro Pro Series Clear and White Polyurethane by General Finishes
ENDURO PRO SERIES SELF CROSS-LINKING CLEAR & WHITE POLY  by General Finishes
Get professional performance for a competitive price. This new pair of ENDURO topcoats are tintable, fast-hide coatings for professional and industrial use. The high solids content provides strong build and 2-coat hide when primed with Enduro White Undercoat or General Finishes Stain Blocker.
Traditionally, flat topcoats were created by adding matting agents to gloss topcoat. These agents decreased the durability of the topcoat and produced a slight haze that reduced the vibrancy of an underlying stain or paint.
Using newly patented polymer resin technology, matting agents are no longer required.  Our new Dead Flat topcoats produce a brilliant clear finish while providing significant improvements to chemical, water and mar resistance.
The term for white or cloudy marks is blush, caused by some type of moisture in the finish. Alcohol damage is more severe than water rings.
General Finishes tests all our topcoats against both isopropyl and denatured alcohol with results showing recovery within an hour.
In most cases, the white mark will fade if the spill is cleaned up in a timely manner. If the alcohol had been sitting on the surface for an extended period then it might not be able to bounce back.
General Finishes Enduro line of water-based coatings is formulated for professional, industrial and OEM for operations. Comprehensive videos for each product are available on YouTube, and comparison charts at www.GeneralFinishes.com.
This response is true of prepping and existing finish on furniture, but kitchen cabinets are more problematic because they are work areas where grease, steam, food splatters and oil from hands are common. Prep is basically degreasing and abrading the surface for better adhesion. Oil or substances on hands really show up on a failed re-finish around doorknobs and hands if the surface is not cleaned thoroughly.
