Pre-Stain Wood Conditioner with an oil-based stain is designed for use before staining new, soft, and porous wood surfaces, such as aspen, cherry, birch, poplar, or pine.
Maple is one of the most difficult woods to achieve a dark, uniform stain color on because it is a dense, closed grain wood and often absorbs stain very unevenly. General Finishes Gel Stains or Water Based Stains usually will perform very well because they are more topical than traditional liquid oil stains, and contain more colorants.
General Finishes offers a complete line of oil based, water based and wax products. Application techniques differ between oil based products and water based products.
You can apply Gel Stain to MDF, stained surfaces
General Finishes water-based Enduro Pre-Cat Lacquer clear-drying wood finish uses new technology in the polymer manufacturing process. This unique formula produces a smaller and smoother particle, translating into a big increase in film clarity.
