Enduro-Var II is a reformulation of our original oil-modified, ambering, water-based topcoat. It replaces original Endurovar and is made with more than 70% RENEWABLE RESOURCES formulated from sustainable materials that decrease the carbon footprint and is compatible with ALL GF products.
General Finishes Professional Enduro White Undercoat is similar to General Finishes Sanding Sealer with the addition of white colorant to provide a primer undercoat for white/off-white wood finishes.
General Finishes Enduro Sanding Sealer
There are four benefits to using sanding sealer as the first seal coat prior to topcoat
Water-based Conversion Varnish is a clear drying, two-component, post-catalyzed urethane topcoat for professional, industrial and OEM use when high durability is needed.
A favorite of professional/industrial finishers and OEM manufacturing facilities, Enduro Clear 1K Poly is a premium non-yellowing water-based self-crosslinking polyurethane-fortified topcoat that delivers a clear, tough, durable, and abrasion-resistant finish.
General Finishes water-based Enduro Pre-Cat Lacquer clear-drying wood finish uses new technology in the polymer manufacturing process. This unique formula produces a smaller and smoother particle, translating into a big increase in film clarity.
Compare all GF Topcoats Here
