Enduro Professional Water-Based White Undercoat
General Finishes Professional Enduro White Undercoat is similar to General Finishes Sanding Sealer with the addition of white colorant to provide a primer undercoat for white/off-white wood finishes. This sturdy primer is EXTERIOR rated, and the high solids, heavy-bodied formula facilitates a fast film build and easy sanding. Use as a basecoat for pigmented acrylic finishes. It dries tack-free in 10-20 minutes. Particularly effective on MDF. Learn more about General Finishes' entire finishing system of clear and pigmented primers, acrylic and polyurethane clears, pigmented topcoats, and water-based stains here: 4 Reasons to Switch to Water-Based Finishes. See our spray tip size recommendations here. Made in the U.S.A. by General Finishes.
General Finishes Water Based White Primer Enduro White Undercoat, Gallon
All wood projects require preparation sanding, and all existing finishes require prep cleaning and sanding. If you skip this critical step, your finish may fail.
Preparation for Raw Wood
  1. Sand with 120-grit sandpaper followed by 150- or 220-grit sandpaper.
  2. Remove dust with a water-dampened rag or oil-free tack cloth.
  3. Let dry completely before applying GF product.
  4. Do not over-sand with fine-grit sandpapers; this will close and seal the wood grain, preventing ideal color absorption.
  5. Do NOT use steel wool with water-based finishes; the particles will get trapped in the finish and rust.
Preparation for Sealed Surface
See our video: How to Prep Existing Finishes
  1. Scuff clean with a Scotch-Brite™ pad or maroon synthetic steel wool & 50:50 mix of denatured alcohol & water.
  2. Dry 1-2 hours.
  3. Sand lightly with 220-320-grit foam sanding sponge.
  4. Remove dust.
Step 2: How To Apply General Finishes Enduro White Undercoat
General Finishes White Undercoat is a spray only product that can be applied over raw wood, MDF, existing finishes. Perfect for using as an undercoat for White Poly and light-colored paints. It acts as a physical barrier rather than a chemical barrier. For woods that exhibit tannin bleed-through, we recommend General Finishes Stain Blocker
Download 2023 Professional Water Based Product Catalog here.
Enduro White Undercoat Application Steps
  1. Watch product overview video here.
  3. Stir General Finishes Enduro White Undercoat thoroughly to reincorporate solids that have settled to the bottom of the can before and throughout the application process.
  4. Test for adhesion over existing sealed surfaces.
  5. Thin as desired with distilled water; start with 5%, adding up to 10% by volume.
  6. Increase open time, if needed, with 10-15% by volume of General Finishes Extender, if allowed by local regulations. GF Extender will improve flow and leveling and increase open time, which is helpful in dry climates.
  7. Ready to spray from the container. Apply 1-2 coats, depending on the substrate, the amount applied, and the application method. If you apply 1 light coat you can sand through, add another coat. If you apply 1 solid first coat and sand lightly, then you only need one.
    • Spray application: Before spraying, strain through a medium-mesh filter. Spray wet films at 3-5-mil thickness. Medium air cap. Fluid tip sizes: Compressed air: .040, HVLP: .072 or Airless: .011-.013. medium air cap. Verify tip sizes with your equipment supplier. See our spray tip size recommendations here. Keep your gun at a 90° angle, 6-8" from the surface. On large, flat areas, use wet, even patterns 6-8" wide. For narrow surfaces, reduce the fan pattern to 2-3" wide to reduce overspray. Overlap each pass 25% to conceal lines. Wear a full filter (NIOSH/MSHA approved) respiratory & eye protection and work in a ventilated space. Read here for more information on spraying techniques.
    • Face frames on cabinets: Enduro professional products are engineered to be spray-only but can be applied successfully to cabinet face frames, edges or drawer fronts with a brush, staining pad or small cabinet specific 3/8" nap microfiber roller such as Whizz or AllPro brand. Larger areas may not level with hand application.
  8. If a faster build is desired over raw wood, use General Finishes Sanding Sealer for the first coat.
  9. Dry time based on ideal conditions: 70°F/20°C; 50% humidity. To touch: 30 minutes. Ready to sand: 30 minutes. Re-coat: 30 minutes. Inadequate dry time is one of the top reasons for product failure. You can tell if a water-based finish is dry if it forms a powder when lightly sanded with a fine-grade (220-320) foam sanding pad. If in doubt, wait longer. Increase dry time if:
  10. Finish sand between coats with a fine-grade (220-320) foam sanding pad to improve smoothness and adhesion.
  11. Remove dust with a vacuum, compressed air, an oil-free tack cloth or a water-dampened rag.
Not applicable
Product Colors White
Tintable White & light colors only
Type Acrylic Primer
Coats 1 - 2 coats
Application Method Spray
Brushable No
Spray Tip Sizes HVLP 1.5mm-1.8mm
Dry Time - Recoat 30-45+ min.
Dry Time - Cure N/A
Can Sizes Gallons, 5 Gallon pails, 55 Gallon drums
Viscosity Thick
Viscosity (cPs) 1000-2000
Weight Solids 53%
< 95 g/L
