Orange Oil is General Finishes most popular and natural furniture care product. It can be used on any cured finish and does a superb job of removing everyday dirt and dust. Orange Oil is all-natural, non-combustible with a fresh orange scent. Designed for use on interior wood finishes.
Satin Finishing Wax is a special blend of waxes designed to give finished woods a rich luster. It can be used as a polish for rubbing out new finishes or as a scratch-remover for worn surfaces. It works well over oil and water-based finishes, including Danish Oil.
After your finish has cured, the best way to clean is with a water-damp rag. If your surface requires deep cleaning due to grease or grime build-up, add a speck of a strong dish detergent, such as Dawn or a bit of vinegar to your damp rag.
If need deeper cleaning, use General Finishes Orange Oil Polish.
This is General Finishes' easiest finish ever and the best oil and wax finish on the market. Hard Wax Oil is a high-quality urethane-solids polymer in a blend of oil & wax that enhances the natural look of wood.
You can lightly buff with 0000 steel wool and General Finishes Orange Oil Furniture Polish - nothing too aggressive.
Even though there is internet chatter about removing wax with 3rd party products, mineral spirits or vinegar, none guarantee success.
There is an old saying in the industry. "Once you wax, you cannot go back". Nothing adheres well to wax and even after cleaning, the wood grain can become contaminated. Wax can penetrate the wood, making future paint or stain finishes or touch-ups difficult or impossible.
This response is true of prepping and existing finish on furniture, but kitchen cabinets are more problematic because they are work areas where grease, steam, food splatters and oil from hands are common. Prep is basically degreasing and abrading the surface for better adhesion. Oil or substances on hands really show up on a failed re-finish around doorknobs and hands if the surface is not cleaned thoroughly.
Although some companies promote their products as "no prep," that is nonsense. If you skip this step the finish can fail. General Finishes's standard for a good finish is it must adhere well and stand the test of time.
There are no guarantees with silicone - it is almost impossible to remove. If the silicone has migrated into the wood through cracks in the old finish, you may not be able to get it all removed.
Unfortunately, silicone contaminants, often from dusting sprays, do not become apparent until a new finish is applied and generally cannot be removed from the surface, only moved around and possibly sealed - a bane of the refinishing industry.
You need to power clean the existing finish and put on some type of barrier coat:
Although some companies promote their products as "no prep", that is nonsense. If you skip this step the finish can fail.
General Finishes standard for a good finish is it must adhere well and stand the test of time.
1. PREP CLEANING:
Cleaning an existing finish removes dirt, grime and many common contaminants such as oil from hands. Dirt, grime, and oil prevent good adhesion causing the possibility of chipping, peeling and flaking - all signs of a failed finish.
