Pre-Stain Wood Conditioner with an oil-based stain is designed for use before staining new, soft, and porous wood surfaces, such as aspen, cherry, birch, poplar, or pine.
Maple is one of the most difficult woods to achieve a dark, uniform stain color on because it is a dense, closed grain wood and often absorbs stain very unevenly. General Finishes Gel Stains or Water Based Stains usually will perform very well because they are more topical than traditional liquid oil stains, and contain more colorants.
General Finishes offers a complete line of oil based, water based and wax products. Application techniques differ between oil based products and water based products.
You can apply Gel Stain to MDF, stained surfaces
An unusual combination of oils, urethanes, and wax, Seal-A-Cell Clear has served craftsman for decades as the best wipe-on clear coat to get that "natural" look on beautiful woods. The oils penetrate deep into the wood to highlight the figure of the wood, and the urethane ensures durability.
