Enduro-Var II is a reformulation of our original oil-modified, ambering, water-based topcoat. It replaces original Endurovar and is made with more than 70% RENEWABLE RESOURCES formulated from sustainable materials that decrease the carbon footprint and is compatible with ALL GF products.
Water-based Conversion Varnish is a clear drying, two-component, post-catalyzed urethane topcoat for professional, industrial and OEM use when high durability is needed.
John Mosconi of Sting King Lutherie in Akron, Ohio takes us on his journey of refinishing this mandola.
Step 1: Prep and Sealing
Compare all GF Topcoats Here
Make your wood finishing project's grain really "POP" by layering oil & water-based products together, resulting in enhanced natural wood grain and character.
ANSWER:
It depends! Read on, or watch this GF video demonstration: http://youtu.be/torOAQy91q4
*Here are the main questions to ask yourself:
