fbpx Pearl Effects | General Finishes
Pearl Effects
Pearl Effects are water-based, acrylic, pearlescent paints used to create specialty finishes. They may be applied to General Finishes water-based stains, paints, and topcoats to produce shimmering, metallic effects.
Need some Pearl Effects inspiration? Visit the General Finishes Design Center or Pinterest Board for great furniture painting ideas.
Find A Store Compare Similar Products
General Finishes Argentine Water Based Pearl Effects Paint, Quart
Step 1: Preparation for Pearl Effects
General Finishes Pearl Effects must be applied over a sealed surface, such as General Finishes Milk Paint or General Finishes High Performance Topcoat.
Over a Newly Sealed Surface
If Pearl Effects are applied over a newly sealed surface, it is not necessary to sand the sealed surface before application.
Over a Previous Existing Finish
If Pearl Effects are applied over an older, existing finish, prep cleaning and sanding is required to remove dirt, grime and potential contaminants.
Sand glossy existing finishes with a fine-grade (220-320) foam sanding pad before applying Pearl Effects.
Step 2: How To Apply General Finishes Pearl Effects
General Finishes Pearl Effects Application Steps
ALWAYS apply Pearl Effects over a sealed surface, such as General Finishes High Performance Topcoat or General Finishes Milk Paint; we recommend 1-2 coats of sealant before application. Sand glossy existing finishes with a fine-grade (220-320) foam sanding pad before applying Pearl Effects.
  1. Pearl Effects will separate in the can. Stir paint to reincorporate solids that have settled to the bottom before and throughout the application process. TIP: turn can upside down before stirring to make it easier to mix.
  2. Thin as desired with distilled water; start with 5%, increase up to 10% by volume.
  3. Increase open time, if needed, with up to 5% General Finishes Extender if allowed by local regulations. GF Extender will improve flow and leveling and increase open time, which is helpful in dry climates. California Residents: Adding more than 2% of GF Extender will make the products non-compliant per SCAQMD Regulations. GF assumes no liability for the improper use of these products.
  4. Apply 1+ coat of Pearl Effects:
    • Hand application: Apply using a synthetic bristle brush, foam brush, pad applicator, staining pad or microfiber roller.
    • Spray application: Before spraying, strain paint through a medium-mesh filter. Spray wet films at 3-5-mil thickness. HVLP: 1.8mm-2.0mm spray tip, medium air cap. Verify tip sizes with your equipment supplier. See our general guide for spray tip sizes. Keep your gun at a 90° angle, 6-8" from the surface. On large, flat areas, use wet, even patterns 6-8" wide. For narrow surfaces, reduce the fan pattern to 2-3" wide to reduce overspray. Overlap each pass 25% to conceal lines. Wear a full filter (NIOSH/MSHA approved) respiratory & eye protection and work in a ventilated space. Visit this FAQ for more information on spraying techniques.
  5. Dry 3+ hours between coats and 12 hours before GF water-based topcoat in ideal conditions: 70°F/20°C; 50-70% humidity. Allow to dry completely. If in doubt, wait longer. Rushing dry time can cause clouding/blush in topcoat due to moisture trapped between coats. Increase dry time if
    • A thick coat is applied
  6. If a smoother texture is desired, finish sand between coats with a fine-grade (220-320) foam sanding pad to improve smoothness and adhesion.
  7. Remove dust with a vacuum, compressed air, an oil-free tack cloth or a water-dampened rag.
  8. Always seal Pearl Effects with 2-3 coats of clear topcoat.
Step 3: Topcoat over Pearl Effects
ALWAYS seal General Finishes Pearl Effects with 2-3 coats of clear topcoat, e.g. General Finishes High Performance Topcoat
Topcoat Recommendations
Creative Techniques Using Pearl Effects
Glaze
MATERIALS NEEDED:
Create a glaze by thinning Pearl Effects with 10% Extender or High Performance Topcoat.
Dry Brush
MATERIALS NEEDED:
  • General Finishes Pearl Effects
  • General Finishes Extender
  • Assorted Bristle Brushes
STEPS:
  1. Reduce Pearl Effects by 5% with Extender.
  2. Lightly dust the mixture onto the surface with a bristle brush.
  3. For extra protection after applying Pearl Effects, seal with 1-2 coats of High Performance Topcoat. Lightly sand between coats using a fine-grade (220-320) foam sanding pad or 400-grit sandpaper.
Shimmer
MATERIALS NEEDED:
  • General Finishes High Performance Topcoat
Thin Pearl Effects with 50-80% High Performance Topcoat.
Scandinavian Mixed Media Technique with Efex
MATERIALS NEEDED:
STEPS:
  1. Apply Efex with Dap Rapid Fuse Glue.
  2. Paint 1 to 2 coats of Summertime Blue Chalk Style Paint.
  3. Lightly wet-brush French Vanilla Chalk Style Paint over the piece.
  4. Wet-brush Charleton Blue Chalk Style Paint in corners and edges, dampen with water to lessen the effect. Blot with a paper towel. Let dry.
  5. Apply Van Dyke Glaze Effects to the entire piece. Use a wet brush or water bottle to lessen effect where needed. Wipe back.
  6. Apply Burnished Pearl Effects to corners and over Efex molding.
  7. Seal with 2-3 coats of flat water-based topcoat.
Aged Metallic Finish
MATERIALS NEEDED:
  • General Finishes Chalk Style Paint: Slate Gray
  • General Finishes Glaze Effects: Pitch Black
  • General Finishes Pearl Effects: Argentine Pearl
  • General Finishes Pearl Effects: Bronze Pearl
  • General Finishes Pearl Effects: Tawny Pearl
  • Water-Based Topcoat
  • Assorted Foam & Chip Brushes
  • Spray Water Bottle
  • Paper Towels
STEPS:
  1. Paint 1 to 2 coats of Slate Gray Chalk Style Paint.
  2. Paint Argentine Pearl Effects thickly in a crisscross pattern, leaving strokes visible.
  3. Paint on Bronze & Tawny Pearl Effects in a crisscross pattern randomly in a few spots. Let dry.
  4. Apply Pitch Black Glaze Effects, wipe off immediately.
  5. Spray water on to remove more glaze if desired.
  6. Seal with 3 coats of water-based topcoat.
Burnt Copper Look
MATERIALS NEEDED:
  • General Finishes Pearl Effects: Copper Pearl
  • General Finishes Water Based Wood Stain: Espresso
  • Paper Towels
  • Assorted Chip Brushes
STEPS:
  1. Combine a 50:50 mix of Bronze and Tawny Pearl Effects with a few drops of Copper Pearl Effects added.
  2. Pounce and crisscross mix randomly all over the piece.
  3. Pounce pure Copper Pearl Effects in a few random spots.
  4. Let dry.
  5. Brush on Espresso Water Based Wood Stain and sponge off with a paper towel.
  6. Use a spray bottle of water to apply runs and lessen effect where desired.
  7. Seal with 3 coats of water-based topcoat.
Application tools and materials containing water-based products can be cleaned with soap and water immediately after use.
Please be mindful of the manner in which water-based products are stored and how long they have been in storage. They not a forever product.
Water-based products do not last forever, even when unopened. General Finishes products are best used within 1 year. However, the life of the product may be extended several more years with proper care and storage (see Storage Tips below).
Pearl Effects Warnings and Warranties
  • Argentine Pearl:
    This product can expose you to chemicals including Formaldehyde, 1,4-Dioxane, Ethyl acrylate, Acetaldehyde, which are known to the State of California to cause cancer. For more information go to www.P65Warnings.ca.gov.
  • Bronze Pearl:
    This product can expose you to chemicals including Formaldehyde, 1,4-Dioxane, Ethyl acrylate, Acetaldehyde, Copper, which are known to the State of California to cause cancer. For more information go to www.P65Warnings.ca.gov.
  • Burnished Pearl, Champagne Pearl, Copper Pearl, Tawny Pearl:
    This product can expose you to chemicals including Formaldehyde, 1,4-Dioxane, Ethyl acrylate, Acetaldehyde, Titanium dioxide, which are known to the State of California to cause cancer. For more information go to www.P65Warnings.ca.gov.
WARNING: HARMFUL IF SWALLOWED.
Keep out of reach of children. Do not swallow. Keep container tightly closed when not in use. Wash thoroughly after handling.
Product Colors Argentine Pearl, Bronze Pearl, Burnished Pearl, Champagne Pearl, Copper Pearl, Tawny Pearl
Interior or Exterior Interior
Type Metallic Paint
Application Method Brush, Spray
Dry Time - Touch 1+ hr
Dry Time - Recoat 3+ hr
Can Sizes Pints
Coverage 40-50 sq.ft./pint
Weight Solids 45%
Argentine: <130 g/L
Bronze: <130 g/L
Burnished: <121 g/L
Champagne: <123 g/L
Copper: <123 g/L
Tawny: <123 g/L
Pearl Effects FAQs
*How Can I Create a Custom Glaze, Wash, Varnish or Stain?
You can design your own custom glazes, stains, washes, and varnishes with General Finishes intermixable water-based products. See tips and recipes below.
  1. Applying a base layer of High Performance Top Coat before applying your custom glaze.
  2. Protect all of these finishes with 2-3 coats of top coat when you are finished.
PASTEL GLAZE/WHITEWASH:
Milk Paint + Winter White Glaze Effects OR Milk Paint + Water Based Whitewash Wood Stain
NOTE: Do not add more than 50% paint. If you add more than 50% you will have so much pigment that it will be difficult to wipe away the finish.
CUSTOM GLAZE:
For example, Pitch Black Glaze Effects + Winter White Glaze Effects
Experiment with proportions and colors.
WOOD STAIN AS A GLAZE:
Water Based Wood Stain + 10% High Performance Top Coat
OR
Oil Based Wood Stain + 10% Mineral Spirits
Note: Make sure that you wait 72 hours before applying a water-based topcoat on top of an oil-based stain.
AGED/VARNISH GLAZE:
Water Based Wood Stain  + High Performance Top Coat 50:50 ratio
OR
Dye Stain + High Performance Top Coat 50:50 ratio
CUSTOM STAIN COLORS:
1 part Milk Paint + 1 part Pre-Stain Natural [50:50 mix]
OR
1 part Milk Paint + 1 part Glaze Effects - Clear Base [50:50 mix]
OR
1 part Milk Paint +  2 parts Water Based Stain Natural [1:2 parts]
Note: Proportions are relative to the color you are reducing. Some colors may require 2 parts clear base to reduce strength, others may require 1. Begin with a 50:50 mix, and add more clear base if necessary.
You can further increase the color palette by mixing 2 or 3 Milk Paint colors together before adding the clear base.
Relevant Videos
