Brushable White Enamel Water Based Paint
Brushable White Enamel is a premium, pigmented water-based wood enamel ideal for cabinets, furniture and millwork and is tintable to light colors using zero VOC colorants. Acting as a 2-in-1 paint and topcoat, this enamel can be brushed, rolled or sprayed on the job. See our spray tip size recommendations here.
4 Reasons to Switch to Water-Based Finishes
General Finishes Water Based Brushable White Enamel Satin, Quart
Step 1. Preparation
RAW WOOD:
1. Sand with 120-grit sandpaper followed by 150-grit.
SEALED SURFACE:
Watch our video "How to Prep an Existing Finish"
1. Scuff clean with a Scotch-Brite™ pad & 50:50 mix of denatured alcohol & water.
2. Dry 1-2 hours.
3. Sand lightly with 220-320-grit foam sanding sponge.
4. Remove dust.
Step 2: Priming
When applying Brushable White Enamel over raw wood, apply 2 coats of Stain Blocker FIRST. Watch product overview video here.
Causes of bleed-through:
  1. ​​​​​​Raw Wood Tannin Bleed-Through is unpredictable; yellowing can appear immediately or months later with seasonal temperature changes. Oak, pine, mahogany, and Douglas fir are particularly prone to bleed-through.
  2. Knots in Wood tend to bleed and are dense, making paint adhesion a challenge. Stain Blocker may improve adhesion and prevent bleed-through.
  3. Existing Finishes Bleed-Through may be caused by wood tannins, previous stains or aniline dyes, surface contamination, and incompatibility between brands.
  4. ALWAYS apply 2 coats General Finishes Stain Blocker before applying Brushable White Enamel over an existing finish for adhesion and to prevent bleed-through.
Non-Wood Surfaces may be able to accept paint if primed first. Primer may improve adhesion over laminate and prevent bleed-through from MDF. Metal requires a primer made specifically for metal.
NOTE: Do not tint or use General Finishes Stain Blocker on projects that will be stored outdoors.
Priming Non-Wood Surfaces
Always test for adhesion on a hidden area of your project before getting started.
Metal: Brushable White Enamel is engineered for wood surfaces, but may adhere to metal, such as aluminum or steel, if a metal primer is applied first.
  1. Clean surface well.
  2. Apply primer.
  3. Dry 48-72 hours before painting.
Laminate: Brushable White Enamel MAY adhere to laminate with a bonding primer; however, we cannot guarantee it. You may increase your chances of success by abrading the surface.
  1. Prep: Deep clean, dry thoroughly, sand with 150- then 180-grit sandpaper, and wipe off dust.
  2. Prime: Apply bonding primer, dry 12+ hours before painting.
MDF: Brushable White Enamel can be applied directly to MDF, but the MDF may cast a brown color if not primed first. Two base coats of white-pigmented shellac-based stain-blocking primer, or Stain Blocker, may prevent bleed-through. Alternatively, one base coat of General Finishes Seagull Gray Milk Paint may block brown tone caused by MDF.
MDF is not as absorbent as natural wood. Let each coat of primer and paint dry at least 48 hours before recoating.
Disclaimer
Although Stain Blocker is engineered to prevent the most persistent bleed-through when 2 coats are applied, General Finishes cannot guarantee prevention of bleed-through or yellowing on every project. Unknown factors and assiduous bleed-through can impact results. Stain Blocker is the strongest option we are aware of at this time and has performed extremely well in our tests.
Step 3: How To Apply General Finishes Brushable White Enamel
CAUTION: Do NOT use any type of clear topcoat over GF Brushable White Enamel, as it may cause yellowing when used over raw or finished wood substrates regardless of priming. GF Brushable White Enamel is a premium self-sealing finish and does not require a topcoat.
General Finishes Brushable White Enamel Application Steps for Raw Wood and Sealed Surfaces
  1. Watch a product overview video here or comparison of GF paints and pigmented topcoats here
  3. Stir thoroughly to reincorporate solids that have settled to the bottom of the can before and throughout the application process.
  4. Thin as desired with distilled water; start with 5%, adding up to 10% by volume.
  5. Increase open time, if needed, 10-15% General Finishes Extender if allowed by local regulations. GF Extender will improve flow and leveling and increase open time, which is helpful in dry climates. California Residents: Adding more than 2% of GF Extender will make the products non-compliant per SCAQMD Regulations. GF assumes no liability for the improper use of these products.
  6. 2-3 coats are recommended, dependent on substrate & primer used.  Additional coats may be required for full coverage over dark colors. Test for adhesion over existing finishes before completing the project.
    • Hand application: Use a synthetic bristle or foam brush, pad applicator, or cabinet grade roller with smooth, even strokes.
    • Spray application: Before spraying, strain through a medium-mesh filter. Spray wet films at 3-5-mil thickness. HVLP: 1.8mm-2.0mm spray tip, medium air cap. Verify tip sizes with your equipment supplier. See our spray tip size recommendations here. Keep your gun at a 90° angle, 6-8" from the surface. On large, flat areas, use wet, even patterns 6-8" wide. For narrow surfaces, reduce the fan pattern to 2-3" wide to reduce overspray. Overlap each pass 25% to conceal lines. Wear NIOSH-approved respiratory & eye protection.  Read here for more information on spraying techniques.
  7. Dry 2+ hours between coats in ideal conditions: 70°F/21°C; 50% humidity. Be sure to allow adequate dry time. You can tell if a water-based finish is dry if it forms a powder when lightly sanded with a fine-grade (220-320) foam sanding pad. If in doubt, wait longer. Rushing the dry time can cause "blush," which is clouding in the finish due to moisture trapped between the layers. Increase dry time if:
  8. Finish sand between coats with a fine-grade (220-320) foam sanding pad to improve smoothness and adhesion. Do not use conventional steel wool.
  9. Remove dust with a vacuum, compressed air, an oil-free tack cloth or a water-dampened rag.
  10. A topcoat is not required or recommended. The use of clear topcoat, even when the surface is primed, may cause yellowing. If you choose to topcoat, apply no more than 2 coats and apply Brushable White Enamel over 2 coats General Finishes Stain Blocker.
Tinting
BWE can be tinted, but only to a light neutral or pastel shade with a Colorfal Zero VOC UTC colorant.
Please be mindful of the manner in which water-based products are stored and how long they have been in storage. They not a forever product.
Water-based products do not last forever, even when unopened. General Finishes products are best used within 1 year. However, the life of the product may be extended several more years with proper care and storage (see Storage Tips below).
Brushable White Enamel Warnings and Warranties
  • Satin
    WARNING: This product can expose you to chemicals including Ethylene oxide, which is known to the State of California to cause cancer and birth defects or other reproductive harm. This product can expose you to chemicals including Titanium dioxide, Crystalline silica, respirable powder, Ethylbenzene, 1,4-Dioxane, Dibromoacetonitrile, which are known to the State of Californiato cause cancer, and Ethanediol, which is known to the State of California to cause birth defects or other reproductive harm. For more information, go to www.P65Warnings.ca.gov.
  • Semi-Gloss
    WARNING: This product can expose you to chemicals including Ethylene oxide, which is known to the State of California to cause cancer and birth defects or other reproductive harm. This product can expose you to chemicals including Titanium dioxide, Crystalline silica, respirable powder, Ethylbenzene, 1,4-Dioxane, Dibromoacetonitrile, which are known to the State of California to cause cancer, and Ethanediol, which is known to the State of California to cause birth defects or other reproductive harm. For more information, go to www.P65Warnings.ca.gov.
WARNING: CAUSES EYE IRRITATION.
  • Satin
    WARNING: Keep out of reach of children. Avoid contact with eyes. Keep container tightly closed when not in use. Wash thoroughly after handling.
  • Semi-Gloss
Product Colors White
Sheen Flat (5-10), Satin (25-35), Semi-Gloss (50-60)
Tintable White & light colors only
Type Pigmented Enamel
Coats 2 - 3 coats
Application Method Brush, Roll, Spray, Pad
Usable over existing finishes Yes - see product page application instructions.
Dry Time - Light Use 12-18 hr
Can Sizes Quarts, Gallons
Coverage 100-125 sq.ft./quart, 400-500 sq.ft./gallon
Viscosity Thick
Viscosity (cPs) 1500-2000
Flat: 44%
Satin: 43%
Semi-Gloss: 44%
Solids by Volume
Flat: 33%
Satin: 32%
Semi-Gloss: 34%
Flat: <80 g/L
Satin: <80 g/L
Semi-Gloss: <80 g/L
Hardness (Koenig #) 60
Chemical (105 max) 77
Brushable White Enamel Frequently Asked Questions
*Can Brushable White Enamel Be Tinted?
Yes, Brushable White Enamel can be tinted to a light neutral or pastel shade with a zero VOC UTC colorant.
*Can Brushable White Enamel Be Used Over an Existing Finish?
Brushable White Enamel can be applied to raw wood or existing finishes. When applying over an existing finish, be sure to prep your surface properly.
Learn how to properly prep existing finishes by watching this video.
The use of General Finishes Stain Blocker wood primer is recommended on both raw wood and existing finishes to prevent dye or stain bleed-through.
*How Does Brushable White Enamel Compare to Enduro White Poly?
General Finishes Enduro Pigmented White Poly and General Finishes Brushable White Enamel have similar durability, but different polymer systems.
The ingredients in Brushable White Enamel cause it to dry slower than Enduro White Poly. Enduro White Poly is a spray finish, and Brushable White Enamel is brush, roll, or spray.  Professionals often pair the two by rolling the face frames with Brushable White Enamel and spraying Enduro White Poly. Brushable White Enamel is the perfect choice for homeowners and DIYers who want a professional finish, similar to White Poly, but don't have spray equipment.
*What Shade of White is Brushable White Enamel?
General Finishes Brushable White Enamel is a bright white. It's similar in color to General Finishes Snow White Milk Paint and General Finishes Enduro Pigmented White Poly.
