Water-Based Wood Stains from General Finishes
MARK YOUR CALENDARS FOR GROUNDHOG DAY. The General Finishes 2015 Contest Starts February 2nd and runs for 40 days. There are two categories to enter. Enter one or both as often as you wish here
1) WILD NIGHTS DESIGN CHALLENGE
In this new video, Chris Adams and Tom Monahan of GF share 5 decorative techniques using General Finishes Pearl Effects.
For today's professional, industrial and OEM users, water-based Tintable 2K Clear Polyurethane is formulated to stop your biggest frustrations and provide ultimate durability for interior/exterior use.
To prep an existing fiberglass door that has a coat of paint on it:
Water-based Tintable 2K White Polyurethane is engineered to prevent the biggest frustrations for today's professional, industrial and OEM users providing ultimate durability for interior/exterior use.
Both products are exactly the same - the only difference is size. Professional paints are sold in gallons for use in spray applications, whereas Retail Milk Paints are sold in pints and quarts.
General Finishes are particularly durable because they were originally created for commercial use.
Photo of Tintable-2K-dark-color-Under IR
A high-performance 2K coating has a base specifically formulated to be catalyzed with Isocyanates to crosslink the polymer fully. This catalyst provides superior performance over 1 K coatings that have been hardened with PolyAzuradine or Carbodiiamide. To create Enduro Tintable 2K; General Finishes tested over 30 polymers, resins, and other ingredients sourced from around the world.
