Exterior 450 Water-Based White Topcoat
General Finishes NEW Exterior 450 White is a water-based exterior-rated pigmented coating for use on vertical surfaces such as outdoor kitchens, entry doors, garage doors, and windows. Features you can expect are mildewcides to inhibit mold and mildew growth, UV absorbers to protect the film integrity, and improved vertical sag resistance when spraying. Exterior 450 White is a self-sealing flexible finish that moves with exterior conditions with superior adhesion over multiple substrates, such as PVC, exterior MDF, composite material and fiberglass. It’s tintable to light or pastel colors with zero VOC colorants. General Finishes recommends ColourFal Zero colorants.
General Finishes Exterior 450 White Water Based Topcoat Topcoat
Step 1: Primer
ALWAYS USE 2 coats of exterior-rated primer for all substrates, such as Enduro White Undercoat or a commercial exterior primer.
Tinting Exterior 450 White (optional)
We recommend tinting with ColourFal Zero VOC colorants. Other colorant systems are used, they should be zero VOC and tested thoroughly.
Step 2: Preparation
Raw Wood
  1. Sand with 120-grit sandpaper, followed by 150 or 220-grit.
Sealed Surface
  2. Dry 1-2 hours.
  3. Sand lightly with 220-320-grit sanding sponge.
  4. Remove dust.
Step 3: How To Apply Exterior 450 White
CAUTION: Do NOT use topcoat over Exterior 450 White or any other white or light paints such as GF Milk Paint, or GF White Poly as it may cause yellowing. Any clear coat can become reactive over wood substrates or existing finishes, causing tannin or dye bleed-though regardless of priming. All of GF's white paints are self-sealing and do NOT require a topcoat.
Download 2023 Professional Water-Based Product Catalog here.
General Finishes Enduro Professional Topcoat Application Steps
  1. Settling is natural. Stir thoroughly to reincorporate solids that have settled to the bottom of the can before and throughout the application process. Do not shake.
  2. Test for adhesion when applying over an existing finish.
  3. Thin as desired with distilled water; start with 5%, adding up to 10% by volume.
  4. Increase open time, if needed, with 10-15% General Finishes Extender if allowed by local regulations. GF Extender will improve flow and leveling and increase open time, which is helpful in dry climates. California Residents: Adding more than 2% of GF Extender will make the products non-compliant per SCAQMD Regulations. GF assumes no liability for the improper use of these products.
  5. Ready to spray from the container. Apply 2-3 coats. Wear NIOSH-approved respiratory & eye protection.
  • Spray application: Before spraying, strain topcoat through a fine-mesh filter. Spray wet films at 3-5-mil thickness. Medium air cap. Compressed air: 0.40, HVLP: 1.3mm-1.5mm. Air Assisted Airless: 1000-1200 PSI pump, 20 PSI assist air, .011" - 013" tip or Airless Fine Finish .007"-.011". Verify tip sizes with your equipment supplier. See our general guide for spray tip sizes. Keep your gun at a 90° angle, 6-8" from the surface. On large, flat areas, use wet, even patterns 6-8" wide. For narrow surfaces, reduce the fan pattern to 2-3" wide to reduce overspray. Overlap each pass 25% to conceal lines. Wear a mask and work in a ventilated space. Read here for more information on spraying techniques.
  • Hand application: Apply a liberal amount with smooth, even strokes & light lap lines. Avoid heavy pressure & back brushing. Lap lines will tighten down as they dry.
  • Respiratory protection:
    ​​Based on the hazard and potential for exposure, select a respirator that meets the appropriate standard or certification, such as NIOSH-approved respiratory & eye protection.
  • Face frames on cabinets: Enduro professional products are engineered to be spray-only but can be successfully applied to cabinet face frames or edges with a pad or small, cabinet-specific short nap or foam roller, such as Whizz Velour brand. Larger areas may not level with a hand application.
Sanding between coats:
  1. Finish sand between coats with 220-320 grit sanding sponge to improve smoothness and adhesion. No not use steel wool.
Dry Time: 2+ hours between coats in ideal conditions: 70°F/21°C; 50% humidity. Cooler temperatures, higher humidity & sealed substrates may prolong dry time. Allow finish to dry for 5 days before exposing to the exterior elements.
Compliance With Air Quality Regulations
Complies with the following air quality regulations:
SCAQMD, CARB, Canada, OTC Phase I & Phase II
Product Colors White
Ambering N/A
Sheen Flat (10), Satin (30), Semi-Gloss (55)
Interior or Exterior Exterior only
Tintable Yes
Type Urethane/Acrylic Blend
Suggested Use
Outdoor wood furniture & projects with vertical surfaces such as garage or entrance doors. Not intended for decks.
Coats 2 - 3 coats
Application Method Brush: Synthetic or foam brush, Roll: Short nap or foam, Spray
Spray Tip Sizes HVLP 1.1mm-1.5mm
Air-Assist Airless 600 PSI pump, 20 PSI assist air, .011" - .013" tip
OR 409 tip, 1000 PSI fluid with 10 PSI air
Airless Fine Finish .007”-.011” tip.
OR .308 FFLP Tip at low pressure
Can Sizes Quarts, Gallons, 5 Gallon pails
Viscosity (cPs) 600-800
Weight Solids 46%
46%, dependent on sheen
Solids by Volume
35%, dependent on sheen
VOC <140 g/L. Varies by color. See color-specific SDS for exact number.
Hardness (Koenig #) 43
Chemical (105 max) 82
