Water-Based Wood Stain
General Finishes Water Based Stains have superior qualities over oil-based stains. Their high-quality pigments produce rich, dark, uniform colors on hard-to-stain woods like maple and pine. Water-Based Wood Stain is PFAS-free, and as General Finishes strives for a cleaner and healthier environment, all future product development will be free of “Forever Chemicals." Low odor, low VOC, water cleanup, and noncombustible. Looking for a "green" environment-friendly finish? These stains are formulated with more than 50% RENEWABLE RESOURCES formulated from sustainable materials that decrease the carbon footprint. Brush or spray. See our spray tip size recommendations here. Need inspiration? Visit the General Finishes Design Center OR Pinterest Board.
4 Reasons to Switch to Water-Based Finishes
Step 2: Preparation
Raw Wood
  1. Sand with 120-grit sandpaper, followed by 150 or 220-grit.
Sealed Surface
  2. Dry 1-2 hours.
  3. Sand lightly with 220-320-grit sanding sponge.
  4. Remove dust.
Step 2: How To Apply General Finishes Water-Based Wood Stain
Download 2024 Water Based Stain Brochure Here
General Finishes Water Based Wood Stain Application Steps
  1. Watch product overview video here.
  2. Watch the application video here.
  3. Work in a well-ventilated area.
  4. Stir stain to reincorporate solids that have settled to the bottom of the can before and throughout the application process.
  5. Thin as desired with distilled water; start with 5%, adding up to 10% by volume.
  6. Increase open time, if needed, with up to 5% General Finishes Extender if allowed by local regulations. GF Extender will improve flow and leveling and increase open time, which is helpful in dry climates. California Residents: Adding more than 2% of GF Extender will make the products non-compliant per SCAQMD Regulations. GF assumes no liability for the improper use of these products.
  7. An initial coat of General Finishes Pre-Stain Conditioner Natural can improve color uniformity over difficult-to-stain wood species such as pine. However, it will limit color absorption, so a darker stain may be required to get the depth of color you want. NOTES on softwoods such as Pine, Pawlonia, or Poplar, the use of Pre-Stain Conditioner will reduce blotchiness but not remove it entirely.
  8. Test your complete finishing process beforehand. Stain color can be affected by variances in wood, room lighting, and deepened with the application of topcoat.
  9. Surface preparation is essential. See "Step 1: Preparation for Water Based Wood Stain."
  10. Divide your project into manageable sections: top, side, drawer, door, table seam.
8. Apply product:
Hand-Application over Raw Wood:
  • Apply a LIBERAL amount of stain to ensure easy workability using a synthetic bristle brush, foam brush, pad applicator or microfiber roller. Work quickly. For large surfaces use a larger applicator such as the pad applicator.
    If not enough stain is used, the surface may dry too quickly, causing an uneven appearance.
    On large projects, leave a wet edge between sections to prevent lap lines until you can wipe all the excess off.
  • Stain one complete section at a time.
  • Wipe off the excess evenly with the grain using absorbant terry cloth or an absorbent paper towel. Check for missed spots and lap marks before moving to the next section. Do NOT use cotton t-shirts to wipe away stain because they will "push" the stain around and not absorb it.
  • Pull excess stain out of corners and details with a synthetic bristle brush.
  • Immediately correct lap marks by rewetting the entire working area with stain and wiping off the excess.
  • One coat is recommended. If needed, another coat will make the color darker but do not exceed two coats as that will create too much build of a low solids finish. Stains are designed to provide color but are not durable on their own.
  • Let the stain dry 2+ hours in ideal conditions when using a WATER-BASED topcoat: 50% humidity, 70°F/20°C before adding a second coat (optional) and before adding topcoat. Be sure to allow adequate dry time. If in doubt, wait longer. When using with an OIL-BASED topcoat, allow 24 hours dry time.
    • More than 2 coats are applied (not recommended)
    • increase to 24 hours if applying an oil-based topcoat over the water-based stain.
    • To accelerate dry time in humid conditions, add General Finishes Accelerator before applying and work in a space with good ventilation and air movement. If you decide to re-coat before the recommended time, test dryness.
Spray Application over Raw Wood:
  • Safety: Wear a full filter respirator (NIOSH/MSHA-approved) and work in a ventilated space.
  • Spray wet films at 3-5-mil thickness. HVLP: 1.1mm-1.3mm spray tip, medium air cap. Verify tip sizes with your equipment supplier. See our spray tip size recommendations here.
    Keep you
    r gun at a 90* angle, 6-8" from the surface. On large, flat areas, use wet, even patterns 6-8" wide.
    For narrow surfaces, reduce the fan pattern to 2-3" wide to reduce overspray.
    Overlap each pass 25-50% for even coverage. Read here for more information on spraying techniques.
  • Apply section by section. Spray liberally to a complete section and wipe off the excess evenly with the grain using a quality paper towel or shop towel. Check for missed spots and lap marks before moving to the next section. Do NOT use cotton t-shirts to wipe away stain because they will "push" the stain around and not absorb it.
  • Spray a LIBERAL amount of stain to ensure easy workability. If not enough stain is used, the surface may dry too quickly, causing an uneven appearance. On large projects, leave a wet edge between sections to prevent lap lines during application.
  • Pull excess stain out of corners and details with a bristle brush.
  • Let the stain dry 2+ hours in ideal conditions: 50-70% humidity, 70°F/20°C before adding a second coat (optional) and before adding topcoat. Be sure to allow adequate dry time. If in doubt, wait longer. Increase dry time if:
Hand-Application over Existing Finish:
See our video: How to Update Existing Finishes with Water Based Wood Stain
  • Stir contents well.
  • Prepare surface well. See Existing Finish Prep instructions in "Step 1: Preparation for Water Based Wood Stain."
  • Apply stain with a foam brush or staining pad. Feather out uneven areas and pull excess stain from corners using a bristle brush. Discharge accumulated stain from the brush onto a dry paper towel as you work. We recommend using a dry brush technique over an existing finish as outlined in this video: How to Update Existing Finishes with Water Based Wood Stain., but even with this technique, do not apply more than 3 coats. Painting on the stain will create too much film build of a low solids finish. Stains are designed to provide color but if applied too heavily, create an unstable surface even when dry and topocated.
  • Let the stain dry 2+ hours before GF water-based topcoat in ideal conditions: 50-70% humidity, 70*F/20*C before applying a second coat (optional) and before applying topcoat. Be sure to allow adequate dry time. If in doubt, wait longer.
    • More than 3 coats are applied (not recommended)
  1. Topcoat is required. Finish with 2-3 coats of General Finishes topcoat. Applying more coats will not improve the results. You can remove any grain raise after applying the first coat of topcoat. Watch this video for more information on grain raise. See "Step 3: Topcoat Over Water-Based Stain."
Always seal General Finishes Water Based Wood Stain, General Finishes Dye Stain, and General Finishes Enduro Ready-To-Match (RTM) Water Based Wood Stain with 3 coats of Top Coat. Additional coats beyond three will not improve durability.
Grain Raise
After the first coat of Top Coat has dried, you can smooth out any grain raise by lightly sanding with a 220 sanding pad. Watch Grain Raise video here.
Recommended Water-Based Top Coats
High Performance can be applied by hand or sprayed; Enduro Clear Poly is spray-only. Both Top Coats dry clear and are great for high-use surfaces, such as kitchen cabinets and tabletops. Flat Out Flat is our flattest Top Coat, suitable for projects that do not receive major wear.
Recommended Oil-Based Top Coats
When sealing with General Finishes oil-based Top Coats, Arm-R-Seal and Gel Topcoat, let the water-based stain dry a minimum of 24 hours first. Oil-based Top Coats will develop an amber tone over time.
Creative Finishing Techniques Using Water-Based Wood Stain
Color Adjustments
  1. Add up to 50% Pre-Stain Conditioner Natural to Water Based Wood Stain to lighten the color.
  2. Apply a second coat to deepen the color but no more than 2 coats.
Wood Stain as a Glaze
MATERIALS NEEDED:
SAMPLE MIX:
Water Based Wood Stain + 10% High Performance Topcoat
**mixture to be used at point of use only. Do not store.
Aged/Varnish Glaze
MATERIALS NEEDED:
  • General Finishes Water Based Wood Stain: Your choice of color
  • General Finishes High Performance Topcoat
SAMPLE MIX:
Water Based Wood Stain  + High Performance Topcoat 50:50 ratio
Custom Colors
MATERIALS NEEDED:
  • General Finishes Pre-Stain Conditioner Natural
SAMPLE MIXES:
  • Create additional colors by mixing Water Based Wood Stains and Dye Stains.
  • Lighten Water Based Wood Stains by diluting with General Finishes Pre-Stain Conditioner Natural
Toning
  • Water-Based Wood Stains Can be used for toning. Mix no more than 5%-10% stain to topcoat. Spraying lays down a more even coat, so slightly more stain can be used than when brushing. Toning mixture should be used at point of use only. Do not store for extended period of time.
Water Based Wood Stain Warnings and Warranties
  • Antique Brown, Antique Oak, Black, Black Cherry, Brown Mahogany, Cabernet, Espresso, Hickory, Onyx, Pecan, Provincial, Sedona, Tobacco, Walnut:
    WARNING: This product can expose you to Ethylene oxide, which is known to the State of California to cause cancer and birth defects or other reproductive harm. This product can expose you to chemicals including Hydrazine, 1,4-Dioxane, Propylene oxide, which are known to the State of California to cause cancer, and Ethanediol, which is known to the State of California to cause birth defects or other reproductive harm. For more information go to www.P65Warnings.ca.gov.
  • Graystone, Graphite, Whitewash:
    WARNING: This product can expose you to Ethylene oxide, which is known to the State of California to cause cancer and birth defects or other reproductive harm. This product can expose you to chemicals including Hydrazine, 1,4-Dioxane, Propylene oxide, Titanium dioxide, which are known to the State of California to cause cancer, and Ethanediol, which is known to the State of California to cause birth defects or other reproductive harm. For more information go to www.P65Warnings.ca.gov.
  • Antique Brown, Antique Oak, Black, Black Cherry, Brown Mahogany, Cabernet, Espresso, Hickory, Onyx, Pecan, Provincial, Sedona, Tobacco, Walnut, Water Based Wood Stain Base:
    CAUTION: MAY CAUSE EYE IRRITATION.
  • Graystone, Graphite:
    WARNING: HARMFUL IF SWALLOWED. CAUSES EYE IRRITATION.
  • Whitewash:
    WARNING CAUSES EYE & SKIN IRRITATION.
  • Antique Brown, Cabernet, Hickory, Onyx, Provincial, Sedona, Tobacco:
    Keep out of the reach of children. Avoid contact with eyes. Keep container tightly closed and sealed until ready for use. Wash thoroughly after handling.
  • Antique Oak, Black, Black Cherry, Brown Mahogany, Espresso, Pecan, Walnut, Water Based Wood Stain Base:
    WARNING: Keep out of reach of children. Avoid contact with eyes. Keep container tightly closed when not in use. Wash thoroughly after handling.
    Keep out of the reach of children. Do not swallow. Avoid contact with eyes. Keep container tightly closed and sealed until ready for use. Wash thoroughly after handling.
  • Whitewash:
    WARNING: Keep out of reach of children. Do not get on skin or clothing. Avoid contact with eyes. Keep container tightly closed when not in use. Wash thoroughly after handling.
Product Colors Antique Brown, Antique Oak, Black, Black Cherry, Brown Mahogany, Cabernet, Espresso, Graystone, Graphite, Hickory, Natural, Onyx, Pecan, Provincial, Sedona, Tobacco, Walnut, Whitewash, Washed Gray, Golden Oak, Red Mahogany, Natural Oak, Driftwood, Tumbleweed
Type Water Based Stain
Application Method Brush, Roll, Spray, Pad
Usable over existing finishes Yes - see product page application instructions.
Dry Time - Touch Raw Wood (30+ min.), Existing Finish (1+ hr)
Dry Time - Recoat - Applied Over Oil Based Product 24
Coverage 50-75 sq.ft./pint, 100-150 sq.ft./quart, 400-600 sq.ft./gallon
Weight Solids 22%
Antique Brown: <125 g/L
Antique Oak: <185 g/L
Black: <160 g/L
Black Cherry: <165 g/L
Brown Mahogany: <160 g/L
Cabernet: <145 g/L
Espresso: <160 g/L
Graystone: <135 g/L
Graphite: <135 g/L
Hickory: <165 g/L
Onyx: <150 g/L
Pecan: <150 g/L
Provincial: <165 g/L
Sedona: <165 g/L
Tobacco: <145 g/L
Walnut: <195 g/L
Whitewash: <150 g/L
*Can I Use Interior Wood Stains Outdoors If I Coat With an Exterior Topcoat?
Watch Exterior 450 Topcoat product overview video
Watch Exterior 450 Stain product overview video
*How Do I Prevent Bleed Through When Applying Whitewash Over Espresso Water Based Wood Stain?
Water Based Stains will always exhibit a bit of bleed through. When glazing with any color over water stains, we recommend some type of seal coat is applied first.
Unfortunately, the two colors you have chosen do not work very well together. Expresso will always bleed if Whitewash is applied directly over top. In the future, seal the Espresso stain with a coat of Shellac, and then General Finishes High Performance Topcoat. Allow both to dry, then apply Whitewash as a glaze (1 part stain, 1 part topcoat mix).
Here are two remedies we recommend to fix for bleeding that has occurred:
  1. Strip away finish and start over.
    Stain with Espresso, top with Shellac, and then with 1-2 coats High Performance. After the HIgh Performance has dried, apply the Whitewash as a glaze (1:1 stain & HPTC). Seal with High Performance.
  2. Paint over the bleeding stain.
    Seal current finish with Shellac and then paint with Seagull Gray Milk Paint.
Any time you apply a light stain over a dark stain there is a possibility of bleed through. Therefore, it's important to seal off the base color first.
If the look of the wood grain is not important, Dark Chocolate Milk Paint is an exact match to Java Gel Stain when painted, and it could be used as an alternative base color.
*How Do I Spray Water Based Finishes?
Spray Tip Guidelines from General Finishes
Click the image to download a PDF of this chart
General Finishes water-based products can be sprayed through compressed air, HVLP, airless or C.A.S. units.
DOWNLOAD SPRAY TIP CHART PDF
SURFACE PREPARATION:
All surfaces should be clean and free from dirt and oil and sanded.
Indicated below are instructional videos we have for preparing a surface for a new coat of paint or finish:
PRE SEALING:
  • Milk Paint: 1.8mm-2.0mm
  • Stain Blocker: 1.8mm-2.0mm
  • Glaze Effects: 1.8mm-2.0mm
  • High-Performance Topcoat: 1.1mm-1.3mm
  • Flat Out Flat Top Coat: 1.1mm-1.3mm
  • Enduro-Var II 1.1mm-1.3mm
  • Water-Based Wood Stain: 1.1mm-1.3mm
  • Water-Based Dye Stain: 1.1mm-1.3mm
  • Exterior 450 Topcoat:1.1mm-1.3mm
  • Exterior 450 Stain: 1.1mm-1.3mm
  • Enduro Sanding Sealer: 1.3-1.4mm
  • Enduro White Poly: 1.3mm-1.5mm
  • Enduro Black Poly: 1.3mm-1.5mm
  • Enduro White Under Coat 1.5mm-1.8mm
  • Enduro Clear Poly: 1.1mm-1.3mm
  • Enduro Pre Cat Lacquer: 1.1mm-1.3mm
  • Enduro Conversion Varnish: 1.1mm-1.3mm
Air caps should be medium-sized. Contact your supplier to verify proper tip sizes for your specific equipment.
Break your work into sections, such as dresser top or drawer fronts. Spraying too large of an area can result in a textured grainy surface. A correctly sprayed finish should appear even and glossy. It is essential to apply a sufficient amount of material to ensure proper flow and leveling of the finish.
Spray medium-wet films at 3-5 wet mL thickness. Practice makes perfect. If you have never sprayed finishes before, take a large piece of cardboard and practice your technique first. Spray water on the cardboard to learn how the gun works. Check your fluid settings and adjust the controls to get comfortable with the spray angles and to develop your technique.
SPRAYING TOPCOATS:
Watch our video how to spray water-based topcoats here.
SPRAYING WATER-BASED WOOD STAINS:
SPRAYING WATER-BASED DYE STAINS:
*What Is the Best Way to Store Water Based Finishes?
LIFE OF PRODUCT
Water-based products do not last forever, even when unopened. General Finishes products are best used within 1 year of the manufacture date listed on the bottom of the can. The life of the product may be extended to 2-3 years with proper care and storage.
SETTLING
Gravity can cause some solids to settle on the bottom of the can and slight separation on the top. This is normal. If working with older paint, use a paint mixing attachment on a drill. If the solids dissolve and clumps smooth out after mixing from the bottom, the product is in good condition for use.
STORAGE TIPS
  1. Pry open sealed lid(s) with a paint can opener by hooking under the lid's rolled edge. The use of a screwdriver can disfigure the rim and lid, impairing a complete seal.
  2. Keep lid(s) closed while working. Pour what you will use into a bowl, paper cup, or plate, and close can lid as you work.
  3. CLEAN the chime of the can(s) thoroughly with a paper towel before closing to create a complete seal. Paint in the chime can be minimized by using a pouring lid, such as Fitsall. Avoid wiping used brushes on the lid.
  4. Pound the lid(s) in place using a rubber mallet to avoid distorting the chime or lid. Dents in the lid from direct contact with a hammer can impair a complete seal. Alternatively, place a flat piece of wood over can lid and firmly pound shut.
  5. Store in moderate temperatures. Avoid temperatures below 50*F/10*C or above 80*F/26*C. Frozen and heat-damaged product cannot be revitalized. Temperature-controlled spaces, such as a basement, are ideal for storage. Do not store product in an attic, garage, in direct sunlight, or next to something warm like a water heater or furnace.
  6. Store the can(s) upside down to create a liquid seal, minimize evaporation and reduce the chance of crystallization. Decant remaining product from the can before stirring.
  1. Product combined with up to 15% General Finishes Extender or General Finishes Accelerator can be stored, with the exception of thinned General Finishes Water Based Wood Stain.
  • Any water-based product thinned with tap water; water often contains bacteria that will adversely affect stored paint.
  • Water-Based Wood Stain + Dye Stain
Can I apply General Finishes Water Based stain on green white oak timbers?
No, you cannot. The stain will not absorb due to the high moisture content of green wood and not accept the stain.
Can I thin General Finishes Water Based Stains?
Thin GF water based stains with distilled water if desired. Start with 5%, adding up to 10% by volume.
Increase open time, if needed with up to 5% General Finishes Extender if allowed by local regulations. GF Extender will improve flow and leveling and increase open time, which is helpful in dry climates.
California Residents: Adding more than 2% of GF Extender will make the products non compliant per SCAQMD Regulations. GF assumes no liability for the improper use of these products.
GF Enduro RTM stains are a thinner formula designed for professional spray applications.
Why can't I get a dark stain color on Maple wood using water based wood stain over pre-stain conditioner?
Maple is one of the most difficult woods to achieve a dark, uniform stain color on because it is a dense, closed grain wood and often absorbs stain very unevenly. General Finishes Gel Stains or Water Based Stains usually will perform very well because they are more topical than traditional liquid oil stains, and contain more colorants.
We do not recommend pre-sealing Maple with a conditioner because it closes up the grain of the wood even more, further preventing color adherence. In the future, just use our water-based stains or gel stains on their own. Do not use liquid oil-based stains on Maple because they will blotch.
Also, prep sand Maple with 120 grit, followed by 150 grit or 220 grit.
