Oil Based Pre-Stain Wood Conditioner
Pre-Stain Wood Conditioner is designed for use before staining new, soft and porous wood surfaces, such as aspen, cherry, birch, poplar or pine with an oil-based stain. It penetrates the grain of the wood to promote uniform acceptance of oil-based wood stain and reduces streaking and blotching to help ensure beautiful, even coverage.
General Finishes Natural Oil Based Pre-Stain Wood Conditioner, Quart
All raw wood projects require preparation sanding before applying stain or wood conditioners. If you skip this critical step, your finish may be rough and uneven.
Preparation for Raw Wood
  1. Sand open grain wood with 120-grit sandpaper followed by 150-grit, then 180 grit. Sand closed grain wood with no finer than 180 grit sandpaper.
  3. Do not over-sand with fine-grit sandpapers; this will close and seal the wood grain, preventing ideal product absorption.
How To Apply General Finishes Oil Based Pre-Stain Conditioner
General Finishes Oil Based Pre-Stain Conditioner Application Steps
For use with oil-based stains.
  2. Stir General Finishes Oil Based Pre-Stain Conditioner to reincorporate solids that have settled to the bottom of the can.
  3. Do NOT thin.
  4. Apply 1 coat of Pre-Stain Conditioner to raw wood using a clean cotton rag, natural bristle or foam brush, staining pad or pad applicator.
  5. Pre-Stain Conditioner Natural can improve color uniformity over difficult-to-stain wood species such as pine. However, it will limit color absorption, so a darker wood stain may be required to get the desired depth of color.
  6. Let Pre-Stain Conditioner penetrate the wood for 10+ minutes.
  7. Wipe off excess with a clean, dry cloth.
  8. Apply stain over conditioner.
  9. Let Pre-Stain Conditioner dry at least 30 minutes, but no longer than 2 hours before applying stain, in ideal conditions: 70°F/20°C; 50% humidity. Do not wait longer than 2 hours, and never let Pre-Stain Conditioner dry overnight before applying a stain over it.
Dilute Oil Based Stain: Add 5% GF Oil Based Pre-Stain Conditioner to GF oil based stains by volume; increase up to 15% as desired.
Storage of Oil Based Products
Oil-Based Pre-Stain Conditioner Warnings and Warranties
Prop 65 WARNING: This product can expose you to Ethylbenzene, which is known to the State of California to cause cancer. For more information go to www.P65Warnings.ca.gov.
DANGER: COMBUSTIBLE LIQUID AND VAPOR. HARMFUL OR FATAL IF SWALLOWED. CAUSES EYE IRRITATION.
DANGER: Can enter lungs and cause damage.
DANGER: Keep out of reach of children. Keep away from heat and flame. Use only with adequate ventilation. Do not breathe vapor or mist. Do not swallow. Avoid contact with eyes. Keep container tightly closed when not in use. Wash thoroughly after handling.
Product Colors Amber (dries amber)
Ambering Yes
Interior or Exterior Interior
Type Wood Conditioner
Coats 1 coat
Application Method Brush, Roll
Usable over existing finishes No
Dry Time - Recoat 30-120 min. before adding stain (no longer than 2 hrs, no less than 30 min.)
Can Sizes Half-Pints, Pints, Quarts
Coverage 45-50 sq.ft./half pint, 180-200 sq.ft./quart
<686.514 g/L
