Enduro Water Based Deep Base Undercoat
General Finishes Enduro Deep Base Undercoat is formulated for professional, industrial & OEM applications. This is a tintable interior/exterior polyurethane/acrylic water-based physical primer that can be used under all General Finishes tintable topcoats. Need to tint to a lighter color? Use Enduro White Undercoat instead. Recommended use is interior/exterior applications over raw wood, MDF, and existing finishes. Deep Base Undercoat is short-filled 10%, allowing room for colorant for tinting darker colors.
General Finishes Enduro Water-Based Deep Base Undercoat for Professional
Tinting
All wood projects require preparation sanding, and all existing finishes require prep cleaning and sanding. If you skip this critical step, your finish may fail.
  1. Sand with 120-grit sandpaper followed by 150- or 220-grit sandpaper.
  2. Remove dust with a water-dampened rag or oil-free tack cloth.
  3. Let dry completely before applying GF product.
  4. Do not over-sand with fine-grit sandpapers; this will close and seal the wood grain, preventing ideal color absorption.
  5. Do NOT use steel wool with water-based finishes; the particles will get trapped in the finish and rust.
Preparation for Sealed Surface
See our video: How to Prep Existing Finishes
  1. Scuff clean with a Scotch-Brite™ pad or maroon synthetic steel wool & 50:50 mix of denatured alcohol & water.
  2. Dry 1-2 hours.
  3. Sand lightly with 220-320-grit foam sanding sponge.
  4. Remove dust.
Step 2: How To Apply General Finishes Enduro Deep Base Undercoat
Enduro Deep Base Undercoat can be brushed, rolled or sprayed and applied over raw wood, MDF, existing finishes. Perfect for using as an undercoat for darker-colored pigmented topcoats and paints. It acts as a physical barrier rather than a chemical barrier. For priming darker colors, Use Enduro White Undercoat. For woods that exhibit tannin bleed-through, use General Finishes Stain Blocker
Download 2024 Professional Water Based Product Catalog here.
Application Steps
  1. Product overview video coming soon.
  3. Stir General Finishes Enduro Deep Base Undercoat thoroughly to reincorporate solids that have settled to the bottom of the can before and throughout the application process.
  4. Test for adhesion over existing sealed surfaces.
  5. Thin as desired with distilled water; start with 5%, adding up to 10% by volume.
  6. Increase open time, if needed, with 10-15% by volume of General Finishes Extender, if allowed by local regulations. GF Extender will improve flow and leveling and increase open time, which is helpful in dry climates.
  7. Ready to spray from the container. Apply 1-2 coats, depending on the substrate, the amount applied, and the application method. If you apply 1 light coat you can sand through, add another coat. If you apply 1 solid first coat and sand lightly, then you only need one.
    • Spray application: Before spraying, strain through a medium-mesh filter. Spray wet films at 3-5-mil thickness. Medium air cap. Fluid tip sizes: Compressed air: .040, HVLP: .072 or Airless: .011-.013. medium air cap. Verify tip sizes with your equipment supplier. See our spray tip size recommendations here. Keep your gun at a 90° angle, 6-8" from the surface. On large, flat areas, use wet, even patterns 6-8" wide. For narrow surfaces, reduce the fan pattern to 2-3" wide to reduce overspray. Overlap each pass 25% to conceal lines. Wear a full filter (NIOSH/MSHA approved) respiratory & eye protection and work in a ventilated space. Read here for more information on spraying techniques.
    • Face frames on cabinets: Enduro professional products are engineered to be spray-only but can be applied successfully to cabinet face frames, edges, or drawer fronts with a brush, staining pad, or small cabinet-specific 3/8" nap microfiber roller such as Whizz or AllPro brand. Larger areas may not level with hand application.
  8. If a faster build is desired over raw wood, use General Finishes Sanding Sealer for the first coat.
  9. Dry time based on ideal conditions: 70°F/20°C; 50% humidity. To touch: 30 minutes. Re-coat: 1+ hours. Inadequate dry time is one of the top reasons for product failure. Dry times are dependent on application method and environmental conditions. You can tell if a water-based finish is dry if it forms a powder when lightly sanded with a fine-grade (220-320) foam sanding pad. If in doubt, wait longer. Increase dry time if:
  10. Finish sand between coats with a fine-grade (220-320) foam sanding pad to improve smoothness and adhesion.
  11. Remove dust with a vacuum, compressed air, an oil-free tack cloth or a water-dampened rag.
Tinting
Not applicable
Dry Time Based on ideal conditions of 70°F 21°C; 50% humidity.
To touch: 30+ minutes
Recoat: 1+ hours
Be sure to allow adequate dry time. Dry times are dependent on application method and environmental conditions. You can tell if a water-based finish is dry if it forms a powder when lightly sanded with a fine-grade (220-320) foam sanding pad or 400-grit sandpaper. If in doubt, wait longer. Rushing the dry time can cause "blush," which is clouding in the finish due to moisture trapped between the layers.
  • Temperatures are cooler.
Product Colors Off-White
Ambering N/A
Sheen N/A
Tintable Yes
Type Primer
Suggested Use
Use over interior & exterior raw wood, MDF or existing finishes on projects such as & painted cabinets, millwork, doors & furniture.
Pro Tips
Short-filled for easy tinting. Improves adhesion over existing finishes.
Air-Assist Airless 1400 PSI assist pump, 40 PSI assist air .013 tip
Airless Fine Finish .015”-.025”
Topcoat Required N/A
Dry Time - Touch 5-10 min.
Dry Time - Recoat 1+ hr
Dry Time - Light Use N/A
Dry Time - Cure N/A
Dry Time - Recoat - Applied Over Water Based Product 1
Can Sizes Gallons, 5 Gallon pails
Viscosity Thick
Viscosity (cPs) 1000-2000
Weight Solids 53%
Solids by Weight and Volume Weight solids: 53%
Volume Solids: 33%
VOC <50 g/L. Varies by color. See color-specific SDS for exact number.
Durability (Highest, High, Medium, Low) N/A
