Water Based Wood Turners Finishes
Wood Turner's Finish is a water-oil urethane hybrid for use on wood turnings, bowls and other lathe-turned projects, now made with more than 50% RENEWABLE RESOURCES formulated from sustainable materials that decrease the carbon footprint. This water-based wood finish produces a slight amber tone and dries to recoat in minutes. Because of its unique chemistry, Wood Turner’s Finish is best used as a standalone product on raw wood or over GF water-based stain.
Need some inspiration? Visit the General Finishes Design Center or Pinterest Board for woodturning ideas.
Step 1. Preparation
Wood Turners Finish is not recommended over existing finishes or other non wood substrates.
Preparation for Raw Wood
  1. Always ensure the surface is clean of contaminants and dust.
  2. Ensure any freshly stained surface has dried thoroughly and completely.
  3. Sand with no finer than 400 grit. Sanding any surface too smoothly can reduce adhesion and create application issues like orange peel.
  4. Do not use Sanding Sealer or shellac under Wood Turner’s Finish.
  5. Wipe oily exotic woods with acetone prior to using Wood Turner’s Finish.
  6. Do NOT use steel wool with water-based finishes; the particles will get trapped in the finish and rust
Step 2: How To Apply General Finishes Wood Turners Finish
Wood Turners Finish Application Steps:
  1. Stir topcoat to reincorporate solids that have settled to the bottom of the can before and throughout the application process.
  2. 3+ coats recommended. The number of coats will vary by application technique and personal preference.
  3. Apply with a synthetic bristle or foam brush, staining pad, rag/towel or spray with HVLP airbrush.
  4. If desired, thin with distilled water.
  5. For more open time, add General Finishes Extender.  Start with 5%, increase up to 15% by volume.
  6. Finish sand between coats with a fine-grade (220-320) foam sanding pad, 400-grit sandpaper or gray non-woven pad to improve smoothness and adhesion.
  7. Remove dust with a vacuum, compressed air, an oil-free tack cloth or a water-dampened rag.
  8. Wood Turners Finish should not be tinted.
Lathe
Apply on the lathe at 3000 rpm using a staining pad, bristle brush, and/or foam brush.
Buffing
Buffing can be done using wet/dry automotive sandpaper after the finish has cured. Use GF Finishing Wax as lubricant. Do NOT use water.
Dry Time Between Coats
Dry 30-60 minutes between heavier coats in ideal conditions: 70°F/20°C; 50% humidity.
Dry 10+ minutes when working on a lathe.
Inadequate dry time is one of the top reasons for finish failure. You can tell if a water-based finish is dry if it forms a powder when lightly sanded with a fine-grade (220-320) foam sanding pad or 400-grit sandpaper. If in doubt, wait longer.
  • Working over a previously existing finish
  • Layering General Finishes water and oil based products:
    • Water over oil: Let oil dry 72+hr
    • Oil over water: Let water dry 24+hr
Lathe Dry Time
General Finishes Wood Turners Finish will dry in less time (10 minutes between coats) when working on a lathe. Accelerator will further speed dry time. Apply on the lathe at 3000 rpm using a pad, bristle brush, and/or foam brush.
Cure Time Before Use
Water-based finishes cure/ harden completely after 21 days in ideal conditions. Avoid placing heavy objects on surfaces that have not cured completely, treat gently, and do not clean with commercial products during the curing period.
Please be mindful of the manner in which water-based products are stored and how long they have been in storage. They not a forever product.
Water-based products do not last forever, even when unopened. General Finishes products are best used within 1 year. However, the life of the product may be extended several more years with proper care and storage (see Storage Tips below).
Ey protection: Safety eyewear complying with an approved standard should be used when a risk assessment indicates this is necessary to avoid exposure to liquid splashes, mists, gases, or dust. If contact is possible, the following protection should be worn unless the assessment indicates a higher degree of protection: safety glasses with side shields.
Uses
Wood Turners Finish has a little bit of an amber cast to it so it's perfect for woods like mahogany walnut and cherry
Ideal to use on a lathe.
Product Colors Appears slightly pink in the the bottle. Dries to an amber tone.
Base Type Hybrid Oil/Water Urethane
Ambering Yes
Sheen Gloss (80+)
Type Oil-modified Urethane
Application Method Brush, Spray
Dry Time - Touch 10-30 min., under 10 min. on lathe
Dry Time - Recoat 30+ min., 10 min. on lathe
Can Sizes 8 oz. bottles
Coverage 38 sq. ft. per 8 oz Bottle
Viscosity Thin
Viscosity (cPs) 100-200
Weight Solids 20%
235 g/L
Durability (Highest, High, Medium, Low) Medium
Hardness (Koenig #) 140
Wear (Taber #) 60.00 mg loss
Water (5 max) 3
Chemical (105 max) 80
Do I need to wet sand Wood Turners Finish?
Wood Turner's Finish does not need wet sanding. If feel the need for more sheen, dry polish with Merka Abralon 1500-4000 grit or Micro Mesh 4000-8000.
