Gel Topcoat: Oil Based Urethane
Gel Satin Topcoat has been a long-time favorite finish of woodworkers, with a heavy-duty oil-and-urethane base that produces a beautiful, hand-rubbed look. Gel Satin Topcoat has a thick consistency, so there are no drips, or runs.Need some oil-based finishes inspiration? Visit the General Finishes Design Center or Pinterest Board for project ideas.
General Finishes Satin Oil Based Gel Topcoat, Quart
RAW WOOD:
1. Sand open grain wood with 120 grit sandpaper, followed by 150 grit, then 180 grit. Sand closed grain wood with 150 grit sandpaper followed by 220 grit.
Step 2: How To Apply General Finishes Gel Topcoat
General Finishes Gel Topcoat Application Steps
  1. Work in a well-ventilated area. Open windows and doors, or use other means, to maintain fresh air flow during application and drying.
  2. Stir thoroughly. Even though General Finishes Gel Topcoat is thick, be sure to stir it well to reincorporate solids that have settled to the bottom of the can.
  3. 3 coats of topcoat are recommended. Additional coats will not improve durability. Apply thin coats with a cotton cloth, natural bristle or foam brush, staining pad or pad applicator with smooth, even strokes. Avoid heavy pressure & back-brushing. The larger the surface the larger the applicator needed.
  4. Wipe off the excess evenly with the grain & with light pressure using a clean cloth or high-quality absorbent paper towel.
  5. Finish sand between coats with a 220-320-grit foam sanding sponge or '0000' steel wool. Do not sand final coat.
  6. Remove dust with a vacuum, tack cloth or clean water dampened rag before re-coating.
Dry Time Between Coats
Dry 12-24+ hours between coats when applying over raw or newly stained raw wood, and dry up 72+ hours between coats when working over a sealed surface. Dry times based on ideal conditions: 70°F/21°C; 50% humidity. The more layers of finish there are on a project, the longer it takes to dry. Do NOT rush the dry times!
Inadequate dry time can trap moisture & cause clouding.
  • Cooler temperatures
  • To accelerate dry time in humid conditions, work in a space with good ventilation and air movement. If you decide to re-coat before the recommended time, test dryness.
Cure Time Before Use
Oil-based finishes cure and harden completely after 30 days. Avoid placing heavy objects on surfaces that have not completely cured. Treat gently, and do not clean with commercial products during the cure period.
Storage of Oil Based Products
Gel Topcoat Warnings and Warranties
FIRST AID: Seek immediate medical attention if symptoms occur due to the following. EYE CONTACT Remove any contact lenses. Flush eyes with water for 20+ minutes while lifting upper and lower eyelids. SKIN CONTACT Flush skin with water. Remove contaminated clothing and shoes and clean before reuse. INHALATION Move to fresh air. Loosen tight clothing. If not breathing, if breathing is irregular, or if respiratory arrest occurs, trained personnel should provide artificial respiration or oxygen. INGESTION Call physician immediately. Wash out mouth with water. Do not induce vomiting unless directed to do so by medical personnel. Never give anything by mouth to an unconscious person.
Prop 65 WARNING: California to cause cancer, and Toluene, which is known to the State of California to cause birth defects or other reproductive harm. For more information go to www.P65Warnings.ca.gov.
WARNING: COMBUSTIBLE LIQUID AND VAPOR.HARMFUL IF INHALED.
WARNING: Keep out of reach of children. Keep away from heat and flame. Use only with adequate ventilation. Do not breathe vapor or mist. Do not get on skin or clothing. Keep container tightly closed when not in use. Wash thoroughly after handling.
Product Colors Dries Amber
Ambering Yes
Sheen Satin (25-35)
Type Oil & Urethane
Application Method Brush, Roll
Dry Time - Touch 8+ hr
Dry Time - Recoat 12-24+ hr raw wood, 72+ hr existing finish until non-tacky. (Add more time with subsequent coats.)
Dry Time - Cure 30 days
Can Sizes Half-Pints, Pints, Quarts, Gallons
Coverage 25-40 sq.ft./half pint, 50-75 sq.ft./pint, 100-150 sq.ft./quart, 400-600 sq.ft./gallon
Viscosity Thick
Viscosity (cPs) 1000-2000
Weight Solids 34%
<565.023 g/L
Durability (Highest, High, Medium, Low) Highest
Hardness (Koenig #) 49
Wear (Taber #) 82.60 mg loss
Chemical (105 max) 102
Gel Stain Topcoat FAQs
*How Do I Reduce the Sheen of an Oil Based Topcoat?
Rub down the finish with 0000 steel wool and General Finishes Orange Oil to lower the sheen.
Liberon 0000 Steel Wool is a good choice for steel wool, as it does not shred as easily as the hardware store brands.
Never use steel wool with water-based finishes. The steel wool particles can become embedded into your project and rust.
*How Can I Reduce the Sheen of an Oil-Based Topcoat? I Used Semi-Gloss and It's Too Shiny.
You can rub down the finish with 0000 steel wool and General Finishes Orange Oil to lower the sheen.
Pro Tip: GF does not recommend using steel wool with water-based finishes because the particles can become embedded and rust.
*How Do I Correct the Haze That Appeared When I Applied Gel Satin Topcoat Over 3 Coats of Gel Stain?*
Haze (the technical term is blush) is caused by too many coats applied too quickly. A recoat time of 12 hours is not enough dry time when applying over an EXISTING finish. To remove the blush or haze, you can either wipe the area with a strong solvent, like xylene or lacquer thinner, or you can try sanding out the haze and then reapply the topcoat.
Always allow more dry time when applying oil-based products over an existing finish. Here are General Finishes recommended dry times for applying multiple coats of Gel Stain and Gel Topcoat over an existing finish.
  • Dry-Time to Touch: 4-6 hours
  • Dry-Time to Recoat with Stain When "Wiping Off": 72 hours. Do not recoat until you are sure the stain is dry. If in doubt, wait longer. Humidity or cold temperatures will increase dry times.
  • Dry-Time to Recoat with Stain When "Painting On": 72 hours. Do not recoat until you are SURE the stain is dry. If in doubt, wait longer. Humidity or cold temperatures will increase dry times.
  • Dry-Time to Apply Oil-Based Topcoat over Gel Stain: 72 hours
  • Dry-Time to Apply Water-Based Topcoat: 72 hours
  • Dry-Time for Light Use: 7-10 days
  • Dry-Time Over Laminate or Other Non-Porous Surfaces: At least 72 hours, likely more. Test to your satisfaction before proceeding.
  • CURE TIME: Cure time for all General Finishes oil-based products is about 30 days. During the curing process, protect your flat surfaces and avoid placing heavy items on horizontal surfaces or sliding anything across the surface.
Dry time and cure time are unrelated. In simplest terms, here is the difference between drying and curing: Drying is the evaporation of solvents in oil-based products, and water in water-based products. Curing is when the product hardens for full use.
