Enduro Professional Water-Based Clear Poly
A favorite of professional/industrial finishers and OEM manufacturing facilities, Enduro Clear 1K Poly is a premium non-yellowing water-based self-crosslinking polyurethane-fortified topcoat that delivers a clear, tough, durable, and abrasion-resistant finish. Now available in a Dead Flat sheen, it is clear drying, low odor, and easy to use. Clear 1K Poly can be used on any project where more solids (28%) and durability are desired. Learn more about General Finishes' entire finishing system of clear and pigmented primers, acrylic and polyurethane clears, pigmented topcoats and water-based stains: 4 Reasons to Switch to Water-Based Finishes. Made in the U.S.A. by General Finishes, the Gold Standard for Professional Water-Based Finishes.
General Finishes Water Based Clear Polyurethane Topcoat: Enduro Clear Poly Dead Flat Finish
Raw wood
New Stained Surface: Do not sand. Apply directly to the stained surface.
Sealed Surface
  2. Dry 1-2 hours.
  4. Remove Dust
Step 2: How To Apply General Finishes Enduro Clear Poly
CAUTION: Do NOT use GF Clear Poly or any other clear coat, over white or light paints such as GF Milk Paint, or GF White Poly as it may cause yellowing. Any clear coat can become reactive over wood substrates or existing finishes, causing tannin or dye bleed-though regardless of priming. All of GF's white paints are self-sealing and do NOT require a topcoat.
Download 2021 Professional Water Based Product Catalog here.
General Finishes Enduro Professional Topcoat Application Steps
  1. Watch Product Overview Video or Watch a comparison video of our topcoats here.
  2. Work in a well-ventilated area.
  3. Stir topcoat thoroughly to reincorporate solids that have settled to the bottom of the can before and throughout the application process. Do not shake.
  4. Test for adhesion when applying over an existing finish.
  5. Thin as desired with distilled water; start with 5%, adding up to 10% by volume.
  6. Increase open time, if needed, with 10-15% General Finishes Extender if allowed by local regulations. GF Extender will improve flow and leveling and increase open time, which is helpful in dry climates. California Residents: Adding more than 2% of GF Extender will make the products non-compliant per SCAQMD Regulations. GF assumes no liability for the improper use of these products.
  7. Ready to spray from the container. Ready to spray from container. Apply 2-3 coats. Wear NIOSH-approved respiratory & eye protection.
    • Spray application: Before spraying, strain topcoat through a fine-mesh filter. Spray wet films at 3-5-mil thickness. Medium air cap. Compressed air: 0.40, HVLP: 1.1mm-1.3mm or Airless .009-.011. Verify tip sizes with your equipment supplier. See our general guide for spray tip sizes. Keep your gun at a 90° angle, 6-8" from the surface. On large, flat areas, use wet, even patterns 6-8" wide. For narrow surfaces, reduce the fan pattern to 2-3" wide to reduce overspray. Overlap each pass 25% to conceal lines. Wear a mask and work in a ventilated space. Read here for more information on spraying techniques.
    • Respiratory protection:
      Based on the hazard and potential for exposure, select a respirator that meets the appropriate standard or certification.
    • Face frames on cabinets: Enduro professional products are engineered to be spray-only but can be successfully applied to cabinet face frames or edges with a pad or small, cabinet-specific roller, such as Whizz Velour brand. Larger areas may not level with a hand application. Alternative: Use the same sheen of General Finishes High Performance Topcoat on areas that must be brushed.
  8. If a faster build is desired over raw wood, use General Finishes Sanding Sealer for the first coat.
  9. Finish sand between coats with 220-320 grit sanding sponge to improve smoothness and adhesion.
  10. Remove dust with a vacuum, compressed air, an oil-free tack cloth or a water-dampened rag.
Dry Time Based on ideal conditions of 70°F 21°C; 50% humidity.
Tack-Free: 5-10 minutes
Ready to Sand: 30-40 minutes
Recoat: 1-2 hours
Be sure to allow adequate dry time. You can tell if a water-based finish is dry if it forms a powder when lightly sanded with a fine-grade (220-320) foam sanding pad or 400-grit sandpaper. If in doubt, wait longer. Rushing the dry time can cause "blush," which is clouding in the finish due to moisture trapped between the layers.
  • Temperatures are cooler.
Yellowing & Clear Topcoat
There is no reliable way to predict whether yellowing will occur and to what degree. Every existing finish is different and we rarely know the finishing provenance on an existing piece. Every tree is different and every piece of wood is unique. Raw wood can bleed tannins immediately after the topcoat dries or months later with seasonal temperature changes. Oak, pine, mahogany, and douglas fir are particularly prone to bleed-through.
Summary
Tips to Prevent Yellowing
  • Use a professional spray such as General Finishes Enduro White Poly. It has "increased topcoat properties," is a standalone finish when 3 coats are applied, and does not require sealing with a topcoat.
Knots
Ey protection: Safety eyewear complying with an approved standard should be used when a risk assessment indicates this is necessary to avoid exposure to liquid splashes, mists, gases, or dust. If contact is possible, the following protection should be worn unless the assessment indicates a higher degree of protection: safety glasses with side shields.
Sheen Dead Flat (<5), Flat (10 or less), Satin (25-35), Semi-Gloss (50-60), Gloss (80+)
Tintable No
Type Urethane/Acrylic Blend
Application Method Spray
Brushable No
Air-Assist Airless 375 PSI pump, 20 PSI assist air, .011"-.013" tip
Airless Fine Finish .007" - .011"
Dry Time - Recoat 1+ hr
Can Sizes Gallons, 5 Gallon pails, 55 Gallon drums
Coverage 450 sq. ft/gal
Viscosity (cPs) 350-450
Dead Flat: 33%
Flat: 33%
Satin: 29%
Semi-Gloss: 28%
Gloss: 29%
Solids by Volume
Dead Flat 35%
Flat: 30%
Satin: 26%
Semi-Gloss: 25%
Gloss: 26%
Dead Flat: 225 g/L
Flat: 227 g/L
Satin: 230 g/L
Semi-Gloss: 210 g/L
Gloss: 233 g/L
Hardness (Koenig #) 100
Wear (Taber #) 35.70 mg loss
Chemical (105 max) 98
*How Do I Spray Water Based Finishes?
Spray Tip Guidelines from General Finishes
Click the image to download a PDF of this chart
General Finishes water-based products can be sprayed through compressed air, HVLP, airless or C.A.S. units.
DOWNLOAD SPRAY TIP CHART PDF
SURFACE PREPARATION:
All surfaces should be clean and free from dirt and oil and sanded.
Indicated below are instructional videos we have for preparing a surface for a new coat of paint or finish:
PRE SEALING:
  • Milk Paint: 1.8mm-2.0mm
  • Brushable White Enamel 1.8mm-2.0mm
  • Stain Blocker: 1.8mm-2.0mm
  • Pearl Effects: 1.8mm-2.0mm
  • Glaze Effects: 1.8mm-2.0mm
  • High-Performance Topcoat: 1.1mm-1.3mm
  • Flat Out Flat Top Coat: 1.1mm-1.3mm
  • Enduro-Var 1.1mm-1.3mm
  • Water-Based Wood Stain: 1.1mm-1.3mm
  • Water-Based Dye Stain: 1.1mm-1.3mm
  • Exterior 450 Topcoat:1.1mm-1.3mm
  • Exterior 450 Stain: 1.1mm-1.3mm
  • Enduro Sanding Sealer: 1.3-1.4mm
  • Enduro White Poly: 1.3mm-1.5mm
  • Enduro Black Poly: 1.3mm-1.5mm
  • Enduro White Under Coat 1.5mm-1.8mm
  • Enduro Clear Poly: 1.1mm-1.3mm
  • Enduro Pre Cat Lacquer: 1.1mm-1.3mm
  • Enduro Conversion Varnish: 1.1mm-1.3mm
SPRAYING TOPCOATS:
Watch our video how to spray water-based topcoats here.
SPRAYING WATER BASED WOOD STAINS:
*What Is the Best Way to Store Water Based Finishes?
LIFE OF PRODUCT
Water-based products do not last forever, even when unopened. General Finishes products are best used within 1 year of the manufacture date listed on the bottom of the can. The life of the product may be extended to 2-3 years with proper care and storage.
SETTLING
Gravity can cause some solids to settle on the bottom of the can and slight separation on the top. This is normal. If working with older paint, use a paint mixing attachment on a drill. If the solids dissolve and clumps smooth out after mixing from the bottom, the product is in good condition for use.
STORAGE TIPS
  1. Pry open sealed lid(s) with a paint can opener by hooking under the lid's rolled edge. The use of a screwdriver can disfigure the rim and lid, impairing a complete seal.
  2. Keep lid(s) closed while working. Pour what you will use into a bowl, paper cup, or plate, and close can lid as you work.
  3. CLEAN the chime of the can(s) thoroughly with a paper towel before closing to create a complete seal. Paint in the chime can be minimized by using a pouring lid, such as Fitsall. Avoid wiping used brushes on the lid.
  4. Pound the lid(s) in place using a rubber mallet to avoid distorting the chime or lid. Dents in the lid from direct contact with a hammer can impair a complete seal. Alternatively, place a flat piece of wood over can lid and firmly pound shut.
  5. Store in moderate temperatures. Avoid temperatures below 50*F/10*C or above 80*F/26*C. Frozen and heat-damaged product cannot be revitalized. Temperature-controlled spaces, such as a basement, are ideal for storage. Do not store product in an attic, garage, in direct sunlight, or next to something warm like a water heater or furnace.
  6. Store the can(s) upside down to create a liquid seal, minimize evaporation and reduce the chance of crystallization. Decant remaining product from the can before stirring.
  1. Product combined with up to 15% General Finishes Extender or General Finishes Accelerator can be stored, with the exception of thinned General Finishes Water Based Wood Stain.
  • Any water-based product with thinned tap water; water often contains bacteria that will adversely affect stored paint.
  • Water
  • Water-Based Wood Stain + Dye Stain
Can the Dead Flat sheen of Enduro Clear Poly be tinted?
Yes! Enduro Clear Poly in Dead Flat can be tinted in the same way as other sheens. The color may be softer, but it can be done.
As always, we recommend that you test on a hidden area of your project or a test board to make sure you are happy with the result before starting your project.
How Do General Finishes Water Based Topcoats Differ?
Compare all GF Topcoats Here
Watch Video: Comparison of All GF Water Based Finishes Here
PROFESSIONAL TOPCOATS
ENDURO PRE CAT LACQUER (Spray only)
Looking for hardness, clarity and fast stack time? Pre Cat Lacquer is the choice. Use in applications where there is little risk of chemical contamination issues from substances such as ketchup, soap, chemical cleaners, or ammonia. This is the perfect spray finish for interior doors, casing, moldings, door jambs and furniture that receives light use. When you think about it, interior doors don't take a lot of wear. You might wipe them down or dust them once in a while but that is about it. PreCat Lacquer is a hard finish that provides excellent build and superior clarity at a phenomenal price point. If you are not finishing a surface such as a tabletop where you anticipate chemical contamination during use, why pay for a more expensive finish?
Dries clear.
Watch Pre Cat Lacquer Product Overview Video Here
ENDURO CLEAR POLY (Spray only)
Poly is the go-to cabinet finish. It has all the durability you need at a lower price point than Conversion Varnish. It is similar to High Performance in test measurements for chemical, water and wear resistance, but HP can be brushed and Clear Poly can't - it is already thinned for spraying. Clear Poly has a bit of an edge over High Performance in overall chemical resistance, a 98 rating vs 92.
Dries clear.
Watch Clear Poly product overview video here
ENDURO CONVERSION VARNISH (2K-Spray only)
This is our top of the line. Conversion Varnish is a post catalyzed high solids, two component urethane formulated for professionals who need the highest level of durability and chemical resistance. Varnish will cure the fastest. Requires NCO Catalyst. It is recommended for commercial applications or extremely high-wear surfaces such as countertops and bar tops
Dries clear.
Watch Conversion Varnish Product Overview Video Here
RETAIL TOPCOATS
HIGH PERFORMANCE (Brush or Spray)
GF's best performing brush on finish with very similar performance testing as our Poly. (High Performance can be thinned for spraying).
Dries clear.
Watch High Performance Product Overview Video Here
FLAT OUT FLAT (Brush or Spray)
Flat Out Flat is formulated with a self cross-linking acrylic, and is designed to mimic the look and feel of a wax finish. Because of the increased matting agents used to create the "Flat look", this finish will have less clarity. Like wax, it dries softer to the touch than High Performance when completely cured, and will show more fingerprints. FOF finish will mark up more easily because of increased matting agents used to reduce the sheen, so it is not recommended for high-use tabletops.
Dries clear.
Watch Flat Out Flat Product Overview Video Here
BOTH PROFESSIONAL AND RETAIL TOPCOATS
ENDURO-VAR (Spray or brush)
Enduro-Var is an oil modified water-based alternative for customers that want the warm look of an oil finish in a water based coating. It looks more like an oil finish than a water coating, and can be sprayed or brushed. The original Enduro-Var adheres well ONLY over WATER STAINS, DYE STAINS, and RAW WOOD. Use over other finishes at your own risk. The new formula of Enduro-Var II is compatible with all GF products and dries to a lighter amber than the previous formula.
Dries Amber
Watch Enduro-Var II Product Overview Video Here
EXTERIOR 45O TOPCOAT
Exterior 450 provides a clear drying tough, protective finish that will withstand the rigors of the sun, rain, and wind. It is suitable for vertical surfaces such as fences, patio furniture, garage doors, entrance doors, outdoor kitchens and interior windows. It is not recommended as a deck finish. Fortified with UV absorbers to stabilize the finish, Exterior 450's built-in mildewcide retards mold and mildew growth.
Dries Clear
How do you maintain clarity of a Dead Flat sheen over dark colors?
Traditionally, flat topcoats were created by adding matting agents to gloss topcoat. These agents decreased the durability of the topcoat and produced a slight haze that reduced the vibrancy of an underlying stain or paint.
Using newly patented polymer resin technology, matting agents are no longer required.  Our new Dead Flat topcoats produce a brilliant clear finish while providing significant improvements to chemical, water and mar resistance.
The new Dead Flat Matte sheen formula is available in the High Performance and Clear Poly lines. You can now achieve the look of our original Flat Out Flat while maintaining clarity and GF's high performance standards.
What is the best, most durable paint for cabinets? Check out Water-Based Tintable 2K Clear and White Poly
Enduro 2K Tintable 2K White and 2K Clear Poly
Enduro tintable 2K Clear poly drying under IR
Superior water-based Enduro Tintable 2K Polys made in Wisconsin for professional, industrial, and OEM users. We hope you try it out; you’ll like it.
The term 2K references a product that is a 2-component polyurethane specifically catalyzed with Isocyanate to crosslink the polymer fully, which provides superior performance 1K coatings hardened PolyAzuradine or Carbodiiamide. To create Enduro Tintable 2K, General Finishes tested over 30 polymers, resins, and other ingredients sourced from around the world.
These new coatings are engineered to prevent the biggest frustrations for today's professional, industrial and OEM users providing ultimate durability for interior/exterior use.
General Finishes goes hard for great chemistry, so you don't have to worry when your clients are tough on the paint. Paired with Tintable 2K Clear Poly, you have a dynamic duo of 2 component finishes, the most durable interior/exterior coatings General Finishes has ever created. You can apply confidently, knowing that you are giving your customer the best the industry offers.
Perfect for new or remodeled cabinets, furniture, woodwork, pre-primed steel, fiberglass, and exterior projects. Made in the U.S.A.
KEY FEATURES
  1. Ease of application. Whether in a shop or on-site, Enduro 2K is designed to flow and level for Professionals/Industrial users that apply with AAA, HVLP, Airless, or flatline systems.
  2. Tintable to any major manufacturer's color deck. Enduro 2K hits the deepest darks, the bright whites, and everything in between. General Finishes recommends ColourFal Zero colorants.
  3. Higher gloss standards for white and clear, with 90+ degrees on a 60-degree angle.
  4. Fast production time: You can spray 3-4 coats of Enduro 2K and sand in between coats in one day. Enduro 2K cures for use in 5 days.
  5. Fast film build: Enduro 2K'S are engineered with a combo of larger and smaller-sized resin particles, which, when combined with the catalyst, allows for a thicker, quicker film build than any 1K. It provides a better vertical hang when spraying built-in surfaces on-site, with fewer drips or sags.
  6. Water and chemical resistance: Combining our new resin with catalyzation allows Enduro 2K to hit a commercial level of water and chemical resistance that *exceeds industry requirements and guidelines”. This is the perfect coating to stand the test of time on Wisconsin bar tops.
  7. Excellent adhesion properties on properly cleaned and prepped wood, plastics, fiberglass, and pre-rimed steel. (It Sticks).
  8. Exterior use: This new finish has an unusual balance of durability and flexibility, making it the professional’s choice for outdoor projects such as doors, benches, furniture, and tables. Do not use on deck surfaces.
  9. Consistency. General Finishes prides itself on superior quality control to meet and exceed the customer’s expectations.
Available in Flat, Satin, Semi-gloss, and Gloss
What is the difference between professional Enduro Clear Poly and High Performance Topcoat?
  • Enduro Clear Poly is slightly more durable than High Performance in the categories of wear, water, and chemical resistance.
  • Even though Enduro Clear poly is more durable and more water resistant than High Performance, High Performance is extremely durable and also recommended for high-use surfaces like kitchen cabinets and table tops.
  • Both products can be sprayed.
  • High Performance can also be applied by hand with a foam/bristle brush.
  • Clear Poly and High Performance are both Urethane/Acrylic blends.
  • High Performance is sold in Pints, Quarts & Gallons by GF Retailers, Clear Poly is Gallon, 5-gallon pails and 55-gallon drums by GF Distributors. Cost is determined by Retailer/Distributor.
Compare all General Finishes Topcoats in our comparison chart.
What makes GF's Dead Flat sheens different?
General Finishes Water Based Topcoat High Performance Dead FlatGeneral Finishes Water Based Topcoat Enduro Clear Poly Dead Flat
Until now, Matte sheens always came with a compromise in durability. Consumers have been asking for an ultra-flat topcoat that is as durable as our other sheens, and we are finally able to deliver!
Thanks to brand new patented polymer technology, we are now able to create a Matte sheen without waxes and matting agents that decrease durability.
Defining Durability
All of our testing shows High Performance Dead Flat is as durable as High Performance Satin, which is a drastic improvement over Flat Out Flat topcoat.
Flat: (degree sheen)
Flat Out Flat: <5
High Performance Dead Flat: <5
Water Resistance: (max 5)
Flat Out Flat: 2
High Performance, Dead Flat: 4
Chemical Resistance: (0-100)
Flat Out Flat: 82
High Performance, Dead Flat: 92
Scratch Resistance and Marring:
Scratch Resistance is strong with both products.
Marring is better than Flat Out Flat and comparable to the Satin and Flat.
High Performance vs. Clear Poly
The main differentiator between these products is that Clear Poly is a spray-only product and High Performance can be applied with a brush or sprayed. Clear Poly is popular among high production contractors but both products produce professional results.
Upgraded Features
  • Patented self-matting polyurethane
  • Uses renewable resources, with no Prop 65 chemicals
  • Meets KCMA standards
  • VOC compliant nationwide
Warning: Do Not Mix!
Topcoat with a Dead Flat sheen CAN NOT be mixed with another sheen because a completely different polymer is used and the combined formulas will not perform well as one.
Leaders in Water-Based Finishing Innovation
General Finishes actively works to improve our products on an ongoing basis. As new finishing technology is released, we test and experiment to stay on the leading edge. Our chemist travels around the world and is sent new ingredients when they are discovered on a regular basis. We are one of the rare companies capable of incorporating new innovations and ingredients into our products, no expense spared, because of our dedication to staying on the leading edge and providing the highest quality product on the market.
Ordering soon?
High Performance Dead Flat is available in pints, quarts and gallons. Clear Poly Dead Flat is available in gallons. 5-gallon pails may be delayed due to label production and Canadian labels are pending translations.
  • High Performance Topcoat
  • Flat Out Flat
  • Enduro-Var Topcoat
  • Exterior 450
  • Exterior 450
  • Arm-R-Seal
  • Gel Satin Topcoat
  • Wood Bowl Finish
  • Butcher Block Oil
  • Outdoor Oil
GENERAL PRACTICE:
  1. Oil-based topcoats and ENDURO-VAR will amber over time.
Compare all topcoats
