Winner of Fine Woodworking's "Best Overall Choice Award," High Performance Topcoat was voted as the hardest, most durable consumer polyurethane topcoat. It is so versatile, it can be brushed or sprayed.
CAUTION: Do NOT use GF High Performance or any other clear coat, over white or light paints such as GF Milk Paint, or GF White Poly as it may cause yellowing. Any clear coat can become reactive over wood substrates or existing finishes causing tannin, stain or dye bleed-through. All of GF's White Paints, brushable or spray versions, do NOT require a topcoat.
General Finishes High Performance Water Based Topcoat Application Steps for Raw Wood & Sealed Surface
Watch the High Performance Product Overview Video Here (2:07)
Work in a well-ventilated area.
Stir thoroughly to reincorporate solids that have settled to the bottom of the can before and throughout the application process.
Test for adhesion.
Thin as desired with distilled water; start with 5%, adding up to 10% by volume.
Increase open time, if needed, with 10-15% General Finishes Extender if allowed by local regulations. GF Extender will improve flow and leveling and increase open time, which is helpful in dry climates. California Residents: Adding more than 2% of GF Extender will make the products non-compliant per SCAQMD Regulations. GF assumes no liability for the improper use of these products.
Apply 2-3 coats of High Performance. More coats will not improve durability.
Hand application: Apply a liberal amount of product using a synthetic bristle brush, foam brush, pad applicator or roller such as Whizz or AllPro Velour brand. Avoid pressure and excessive back brushing. Brush along the wood grain using smooth, even strokes with light lap marks. Let lap marks dry - they WILL tighten down.
Spray application: Before spraying, strain topcoat through a fine-mesh filter. Spray wet films at 3-5-mil thickness. HVLP: 1.1mm-1.3mm spray tip, medium air cap. Verify tip sizes with your equipment supplier. See our general guide for spray tip sizes. Keep your gun at a 90° angle, 6-8" from the surface. On large, flat areas, use wet, even patterns 6-8" wide. For narrow surfaces, reduce the fan pattern to 2-3" wide to reduce overspray. Overlap each pass 25% to conceal lines. Wear a full filter respirator (NIOSH/MSHA-approved) and work in a ventilated space. Read here for more information on spraying techniques.
Face frames and drawers on cabinets: High Performance can be successfully applied by hand to cabinet face frames or edges with a brush, pad or small, cabinet-specific roller such as Whizz or AllPro Velour brand.
If a faster build is desired over raw wood, use General Finishes Sanding Sealer for the first coat, followed by 2 coats of High Performance Topcoat.
Finish sand between coats with a fine-grade (220-320) sanding pad to improve smoothness and adhesion. Do not use steel wool.
Remove dust with a vacuum, compressed air, an oil-free tack cloth or a water-dampened rag.
Use a semi-gloss or gloss sheen with little to no flatting agents. The more flatting agents, the more likely a topcoat will streak when applied.
To avoid streaking with the flatter sheens, apply a liberal amount of product and avoid using pressure and back-brushing. Wipe along the wood grain using smooth, even strokes. For large surfaces, apply topcoat with a large applicator, such as a paint pad.
Remove any streaks that occur by buffing with fine-grade (220-320) sanding pad, or sanding well and re-coating.
For the smoothest result, apply with a spray gun.
Mixing Sheens
You mix can High Performance Topcoat sheens to adjust your sheen. For example, you can mix High Performance Flat and High Performance Gloss to obtain a different sheen.
Warning: Do not use water-based products with Linseed Oils or Danish Oils.
Dry 2+ hours between coats in ideal conditions: 70°F 21°C; 50% humidity.
Be sure to allow adequate dry time. You can tell if a water-based finish is dry if it forms a powder when lightly sanded with a fine-grade (220-320) foam sanding pad or 400-grit sandpaper. If in doubt, wait longer. Rushing the dry time can cause "blush," which is clouding in the finish due to moisture trapped between the layers.
Humidity is over 80%
Temperatures are cooler.
3+ coats are applied
Thick coats are applied
Applying over an existing sealed finish
Applying over products from other brands
Layering General Finishes water- and oil-based products:
Water over oil: Let oil-based products dry 72+hr before applying water-based products
Oil over water: Let water-based products dry 24+hr before applying oil-based products
To accelerate dry time in humid conditions, add General Finishes Accelerator and work in a space with good ventilation and air movement. If you decide to re-coat before the recommended time, test dryness.
As is true of most "water-white" topcoats, General Finishes water-based topcoats dry clear over non-reactive substrates, such as plastic or metal, except General Finishes Enduro-Var, which ambers. When white paint sealed with a water-white topcoat is applied to something as unpredictable as wood, all bets are off and the reason for yellowing is often unknown. It can be caused by topcoat activating tannins in raw wood or aniline dyes, stains, or contaminants in a pre-existing finish. This is most evident when using BRIGHT WHITE paint and most prevalent in sculpted details of furniture where the topcoat can collect, intensifying color change to an unacceptable level.
There is no reliable way to predict whether yellowing will occur and to what degree. Every existing finish is different and we rarely know the finishing provenance on an existing piece. Every tree is different and every piece of wood is unique. Raw wood can bleed tannins immediately after the topcoat dries or months later with seasonal temperature changes. Oak, pine, mahogany, and douglas fir are particularly prone to bleed-through.
Summary
Whites have a lower “hide” quality and are more transparent than most other colors. Nearly all bright whites require additional coats to achieve the desired color and minimize color variation. This can increase the cost of paint finishing. Always include a clause in your contracts addressing the need for additional coats to achieve coverage.
All bright white paint will yellow slightly with time, with or without topcoat. You have probably tried to touch up white woodwork in your home after several years and noticed the new paint is brighter.
The underlying finish or wood species can affect the final color of light paint.
Details and inside corners are difficult to cover with any paint color, but it tends to be more noticeable with whites. This is a naturally occurring phenomenon in paint application and does not necessarily constitute a defect in the paint finish or your technique.
The more porous the paint, such as a chalk paint, the more likely that yellowing will occur. The topcoat is seeping through the spaces caused by the larger particles of filler that give Chalk Paints their texture.
Tips to Prevent Yellowing
If it is a low-use project, use a premium white paint that is self-sealing and does not require a topcoat. A clear topcoat is not required on General Finishes Milk Paint for increased durability, as it is a self-sealing, exterior-rated coating with high durability and chemical and water resistance. However, topcoats do provide a smooth surface that is easier to clean and boosts durability for high-use projects, such as tabletops and kitchen cabinets.
Use a professional spray such as General Finishes Enduro White Poly. It has "increased topcoat properties," is a standalone finish when 3 coats are applied, and does not require sealing with a topcoat.
We recommend using General Finishes Stain Blocker, an engineered chemical barrier, to prevent persistent bleed-through for interior-use projects.
Stain Blocker does not adhere to melamine cabinet veneers.
Stain Blocker cannot be tinted.
Always test your project's ENTIRE finishing schedule (from cleaning to topcoat) on an inside door or a more hidden area of the piece. This will not help if the yellowing occurs later, but at least you will know if there is an immediate problem.
Avoid painting period furniture, such as a 1940s serpentine mahogany desk, with light colors. The pieces were often finished in stain that contained aniline dyes, which cast a pinkish bleed-through under light paint. Not every piece of furniture is suitable for upcycling with a light paint color. Pine, mahogany, and furniture of the 1940s and 50s are a red flag.
Last, not all manufacturers' topcoats are compatible with other finishes and may react with a color change. Always follow best practices by not rushing, and testing to your satisfaction first.
Knots
Knots in wood tend to bleed and are dense, making paint and stain adhesion a challenge. Stain Blocker may improve adhesion and prevent bleed-through for painting projects. Pine knots are especially difficult to cover with white or light paints. If you decide to paint over them, apply 3 coats of Stain Blocker first; however, we cannot guarantee adhesion or bleed-through blockage. You are better off using a dark paint on pine.
Please be mindful of the manner in which water-based products are stored and how long they have been in storage. They not a forever product.
Water-based products do not last forever, even when unopened. General Finishes products are best used within 1 year. However, the life of the product may be extended several more years with proper care and storage (see Storage Tips below).
Product that is 3 years old will not look like product that is 6 months to 1 year old. You will see more stratification or separation as the product ages. Always stir thoroughlybefore using.
Foul Smell
Water-based finishes crystalize and form a skin due to evaporation when the air-tight seal on a can is broken at first use. The following best practices will increase the life of your product:
Remove dust with a water-dampened cloth. Dust can build up over time and may scratch or dull finishes if not removed regularly.
Remove fingerprints, cooking fumes and smoking residue with mild soap and water. These contaminants will not harm the finish, but they accumulate on surfaces and dull the original luster.
As with all fine furniture finishes, avoid using furniture polish, cleaners or dusting sprays that contain silicone, alcohol, ammonia and anything acidic. Exception: We have successfully cleaned with Clorox wipes for occasional cleanups.
Clean up water, alcohol and food spills in a timely manner and use placemats & coasters to protect the finish.
Future finishes or touch-ups may not adhere properly or perform as desired over a contaminated surface. Some contaminants, such as silicone, seep through finish into the wood and often cannot be removed.
Avoid excessive exposure to direct sunlight, high temperatures or high humidity. These can damage furniture and finishes.
Flat:
FIRST AID: Seek immediate medical attention if symptoms occur due to the following. EYE CONTACT: Remove any contact lenses. Flush eyes with water for 20+ minutes while lifting upper and lower eyelids. SKIN CONTACT: Wash skin immediately upon contact. Remove contaminated shoes and clothing; clean and wash before re-use. INHALATION: Move to fresh air and loosen clothing. If not breathing, if breathing is irregular or if respiratory arrest occurs, provide artificial respiration or oxygen by trained personnel. INGESTION: Call physician immediately. Wash out mouth with water. Do not induce vomiting unless directed to do so by medical personnel. Never give anything by mouth to an unconscious person.
Satin, Semi-Gloss, Gloss:
Prop 65 WARNING: This product can expose you to Ethylene oxide, which is known to the State of California to cause cancer and birth defects or other reproductive harm. This product can expose you to chemicals including 1,4-Dioxane, Ethylbenzene, Dibromoacetonitrile, which are known to the State of California to cause cancer. For more information go to www.P65Warnings.ca.gov.
Flat:
WARNING HARMFUL IF SWALLOWED. MAY CAUSE EYE IRRITATION.
Keep out of reach of children. Use only with adequate ventilation. Do not swallow. Do not get on skin or clothing. Avoid contact with eyes. Avoid breathing vapor or mist. Keep container tightly closed when not in use. Wash thoroughly after handling.
Product Colors
Water White in can (dries clear)
Base Type
Water
Ambering
No
Sheen
Flat (10 or less), Satin (25-35), Semi-Gloss (50-60), Gloss (80+)
Flat Out Flat is a matte water based topcoat with a velvety feel and was developed as a durable alternative to our Satin Wax. Choose this product if you want a finish that looks more like wax and your project will not require high use. Like wax, it dries softer to the touch than High Performance when completely cured, and it will show more marring and fingerprints. Flat Out Flat is made with a stable self cross-linking acrylic instead of urethane. High Performance is urethane based and contains less matting agents which result in a slightly harder finish. For that reason, High Performance is the best choice for high use areas such as table tops and kitchen cabinets. Both topcoats have similar water resistance, but High Performance offers greater clarity. Use with Oil Based Finishes: Let oil-based finishes dry for 72 hours before applying High Performance or Flat Out Flat top coat.
The term for a cloudy, milky appearance in the finish is Blush. There are three causes:
1. The most common reason is an incompatible stain. For example, using a water-based topcoat over an oil-based based stain. When the top coat is applied, the oil in the stain seeps up through the finish and reacts with the acrylic causing a chemical blush.
To prevent this, either use a quick-drying water-based stain or allow the oil-based stain to dry for 72 hours. You can also seal an oil-based stain with a coat of shellac or lacquer sealer to provide a barrier between the oil and the acrylic.
2. Another cause for blushing is high humidity. Applying a water-based finish in humidities of over 75% may cause blushing because moisture becomes trapped beneath the finish and cannot evaporate.
You can prevent this condition by increasing air movement in the finishing area with a fan. All water needs to evaporate is sufficient air movement. You can also improve drying conditions by increasing the temperature in the drying area.
3. Another common cause is a wet object or a water spill left two long on the surface. In most cases, the white mark will recover and fade within an hour if the spill is cleaned up in a timely manner. If the water has been sitting on that area for an extended period of time then it might not be able to bounce back.
To fix this, the surface needs to be scuffed and sanded first. Second, we recommend applying a sanding sealer to protect the top. Sanding sealer has a larger resin particle, so it will provide a better build for the next sanding step. Then finish with your topcoat.
Enduro Clear Poly is slightly more durable than High Performance in the categories of wear, water, and chemical resistance.
Even though Enduro Clear poly is more durable and more water resistant than High Performance, High Performance is extremely durable and also recommended for high-use surfaces like kitchen cabinets and table tops.
Both products can be sprayed
High Performance can also be applied by hand with a foam/bristle brush.
Clear Poly and High Performance are both Urethane/Acrylic blends.
High Performance is sold in Pints, Quarts & Gallons by GF Retailers, Clear Poly is Gallon, 5-gallon pails and 55-gallon drums by GF Distributors. Cost is determined by Retailer/Distributor.
This is a guesstimate as GF cannot assist with the performance of another manufacturer's product used in conjunction with our own finishes.
It looks like Annie Sloan Chalk Paint is absorbing some of the topcoat because it is so porous. High Performance does not streak over a sealed surface when properly applied. Most likely the chalk paint is so dry it is pulling some of the solvents away from the High Performance, causing an uneven finish or the appearance of streaking. This happens on the original powder Chalk or Milk Paints also.
Possible solution: Porous paints such as chalk paint may require additional coats of High Performance Topcoat to seal off the paint. If the first coat absorbs into the paint it will require multiple coats of High Performance to build a film of sealer above the paint. Using a foam brush will accent the streaking due to the number of strokes needed. We suggest a fairly liberal application with a large applicator such as a foam roller or a pad applicator.
Always test before proceeding with the entire project when using General Finishes projects with other manufacturer's products.
It is normal to see a bit of stain on the brush when applying the first coat of topcoat. Topcoats often pull a bit of color on the first pass, but good preparation will minimize this.
To prepare open grains woods such as raw Oak for a water-based stain, we recommend sanding with 180-grit followed by no more than 220-grit sandpaper.
300-grit or 400-grit sandpaper is too fine for preparing raw wood. Too fine of a grit changes the wood from a porous surface to one that is too smooth to absorb the stain, which causes the first top coat application to pull excessive color (it is like trying to apply stain to glass).
There is always a small amount of color pull when using water-based stains, but the smooth surface escalates this condition. This was evident in the areas that you used the brush to remove excess topcoat.
There are several techniques by Jeff Jewitt of Homestead Finishing Products:
DRY BUFF WITH MIRKA ROYAL MICRO PAPER.
Using Mirka Royal Micro sandpaper, always start with 1500-grit sandpaper. Begin with a small area, make 2-3 passes, then evaluate results. Go to a heavier grit if surface irregularities are not fully removed. Finish with 1500-grit paper.
DRY/WET BUFF WITH ABRALON POLISHING DISCS.
Start by dry sanding with Abralon 2000-grit, and then 4000-grit. Start slowly, monitor to see if buildup is occurring. A large sized table might take 5-25 sheets of paper.
If lubricated, one sheet of 1000-grit or 1500-grit should do the entire table.
BUFFING/POLISHING WITH PRESTA POLISHING KITS.
Spray Presta polish on buffing pad stuff to lubricate the pad. Apply a quarter-sized dab of polish to sand one section. Spread with pad. Continue section by section. Mist buffing pad with Presta lubricating material when it gets too dry. You should be able to use a buffing pad on 10-20 tables before washing and reusing.
When done, mist entire surface with and buff with a micro-cloth to remove splatter
Either bristle or foam brushes will work well with Milk Paint and Top Coat. The folks at GF might use several types of brushes for a project.
For example:
We like to use a bristle brush (which loads up more paint) to get Milk Paint on the surface, and then use a water or Extender dampened foam brush to smooth out the finish.
Bristle brushes are particularly helpful on vertical and detailed surfaces but they can produce subtle texture.
Foam brushes tend to produce a smoother finish which can be particularly helpful on flat horizontal surfaces.
Pad Applicators or paint rollers are also helpful on larger horizontal surfaces such as a table top.
For folks who don't want to invest in several brushes, the foam brush is our recommendation.
If you want to change the sheen, you can re-coat with a different sheen over top. The second layer of top coat will replace the appearance of the first.
Sand lightly with a used 220 sanding PAD to knock down the original finish before re-coating. It may take two or 3 coats to get complete coverage.
All bright white paint will yellow slightly with time, even without topcoat. You have probably tried to touch up white woodwork in your home after several years and noticed that the new paint is brighter.
But white and light paints can react if clear coated with a waterbased finish; water-based topcoats are reactive and may draw out substances in the wood such as tannins, dyes or unknown substances in existing finishes causing the topcoat to yellow. This is an industry-wide issue and can happen right away, years later or never.
There is no way to reliably predict yellowing ahead of time. Every existing finish is different and we rarely know the finishing provenance on a previously finished piece. Every tree is different; every piece of wood is unique. Wood can bleed tannins immediately after the topcoat dries or months later with a change in temperature that comes with a change in seasons. Oak, pine, mahogany, and Douglas Fir are particularly prone to bleed-through.
Throughout all of our testing, General Finishes water-based topcoats are clear drying over a non-reactive substrate such as plastic or metal but when applied to something as unpredictable as wood, it is best to play it safe.
To reduce the occurrence of yellowing, we formulated Stain Blocker, a chemical stain and tannin blocking primer, and Brushable White Enamel. But the safest route is no use of topcoat over whites and light paint. As all of our white pigmented paints are self-sealing and do not require a topcoat, we warn users as follows:
CAUTION: Do NOT use any water-based clear coat over bright whites such as GF Snow White Milk Paint, or GF White Poly as it may cause yellowing. Lighter-colored paints may alter slightly with a topcoat application, but the color shift is less noticeable. Any clear coat can become reactive over wood substrates or existing finishes, causing tannin or dye bleed-though regardless of priming. All of GF's white paints do NOT require a topcoat.
TIPS FOR PROTECTING YOURSELF AND PREVENTING YELLOWING
Don't apply any clear coat when using light or white paints. Topcoat is perfectly fine over darker colors.
Always prime white paint with a paint system: Gf recommends either 2 coats of Stain Blocker or White Undercoat.
Over raw wood: Apply two coats of Stain Blocker or Enduro White Undercoat, then 1-2 coats of Brushable White Enamel, White Poly (spray only), or Milk Paint.
Over an existing finish: Apply two coats of Stain Blocker, then 1-2 coats of Brushable White Enamel, White Poly (spray only), or Milk Paint. Always let any primer dry overnight. Many primers suggest a 3-hour dry time and that is not enough.
We offer three types of self-sealing pigmented paint.
Milk Paint: A clear topcoat is not required on our Milk Paint for increased durability. It is a self-sealing, exterior rated coating with very high-performance properties. However, higher sheen topcoats provide a smoother surface that is easier to clean for high use projects such as tabletops and kitchen cabinets.
Topcoat is fine for darker colors, but not for light or white Milk Paint. In those cases, use Brushable White Enamel (available in Satin or Semigloss) or spray our pigmented White Poly (available in Flat Satin or Semigloss.)
Enduro White Poly: Use a professional sprayable "white coat" such as our professional Enduro White Poly. It is a white paint with "increased topcoat properties", is a stand-alone finish when 3 coats are applied and does not require sealing with a topcoat.
Brushable White Enamel was developed as a stand-alone finish for those who want a bright white but do not use spray equipment.
Use disclaimers in your contracts. Upcharge for the extra coats needed and never guarantee a white finish over a piece when the customer wants a topcoat. Here is a suggestion for your contracts:
Terms of Agreement and Warranties: ________ (Initials) I have been informed that more coats are required when painting with bright whites, reds, greens or yellows. I understand that white paint can yellow over time and water-based topcoats can react with the substrate or existing finish under white paints causing yellowing, even if a stain-blocking primer is used. I have been informed that topcoat over white or light paints should NOT be used.
Always test your project's ENTIRE finishing schedule (from cleaning to topcoat) on an inside door or a more hidden area of the piece. This does not help if the yellowing occurs later but you will at least know if there is an immediate problem.
If you are working on period pieces such as a 1940's serpentine mahogany desk which were often finished in stain containing aniline dyes that cast a pinkish bleed-through under light paint, stay away from light colors. Not every piece of furniture is suitable for up-cycling with a light paint color. Pine, Mahogany, and furniture of the 1940's and 50's are a red flag.
Last, not all manufacturer's topcoats are compatible with other finishes and may react with a color change. Always follow best practices by not rushing, and testing to your satisfaction first.
WHAT YOU NEED TO KNOW ABOUT WHITE PAINT:
Bright white paints can yellow over time with or without topcoat. It is the nature of oxidation.
Details and inside corners are difficult to cover with any paint color, but this property tends to be more noticeable with whites. This is a naturally occurring phenomenon in paint application and does not necessarily constitute a defect in the paint finish or your technique.
The more porous the paint (chalk paint vs an acrylic paint), the more likely that yellowing will occur. The topcoat is actually seeping through the spaces caused by the larger particles of filler that give chalk style paints their texture.
Whites have a lower “hide” quality and are more transparent than other colors. Most bright whites require additional coats to achieve the desired color and minimize color variation. This can increase the cost of paint finishing. Always include a clause in your contracts addressing the need for additional coats to achieve coverage.
IF YOU ARE A PAINTING PROFESSIONAL, DO NOT CARRY THE COST OF WHITE PAINT YOURSELF – include the cost of the increased labor for applying white paints with a fair, reasonable up-charge. White paints, even if they did not yellow, require more coats and high-quality primers to achieve coverage. See our video How to Achieve a Bright White Finish that Lasts for more information.
If your white cabinets have yellowed, we recommend prep cleaning and scuff sanding, applying a coat of General Finishes Stain Blocker primer, finish sand and re-coat with another coat of paint.
Sand down the final finish with a 220-grit foam sanding pad, and then add another layer of General Finishes High Performance PolyurethaneTopcoat. Apply liberally than you did previously without heavy back-brushing.
Let the topcoat self-level a bit - it will tighten down as it dries.
If it's above 80°F or if the humidity is less than 70% in the space you're working, we recommend adding 10% GF Extender to the topcoat to improve open time.
PRE SEALING:
Milk Paint: 1.8mm-2.0mm
Brushable White Enamel 1.8mm-2.0mm
Stain Blocker: 1.8mm-2.0mm
Pearl Effects: 1.8mm-2.0mm
Glaze Effects: 1.8mm-2.0mm
Enduro-Var 1.1mm-1.3mm
SPRAYING TOPCOATS:
For example:
Furthermore, nothing adheres well to wax, which can impact future finish changes. Even though there is internet chatter about removing wax with 3rd party products or mineral spirits, the risk of a failure in re-coating over a wax finish is very high and sometimes impossible.
Looking for hardness, clarity and fast stack time? Pre Cat Lacquer is the choice. Use in applications where there is little risk of chemical contamination issues from substances such as ketchup, soap, chemical cleaners, or ammonia. This is the perfect spray finish for interior doors, casing, moldings, door jambs and furniture that receives light use. When you think about it, interior doors don't take a lot of wear. You might wipe them down or dust them once in a while but that is about it. PreCat Lacquer is a hard finish that provides excellent build and superior clarity at a phenomenal price point. If you are not finishing a surface such as a tabletop where you anticipate chemical contamination during use, why pay for a more expensive finish?
Poly is the go-to cabinet finish. It has all the durability you need at a lower price point than Conversion Varnish. It is similar to High Performance in test measurements for chemical, water and wear resistance, but HP can be brushed and Clear Poly can't - it is already thinned for spraying. Clear Poly has a bit of an edge over High Performance in overall chemical resistance, a 98 rating vs 92.
This is our top of the line. Conversion Varnish is a post catalyzed high solids, two component urethane formulated for professionals who need the highest level of durability and chemical resistance. Varnish will cure the fastest. Requires NCO Catalyst. It is recommended for commercial applications or extremely high-wear surfaces such as countertops and bar tops
Flat Out Flat is formulated with a self cross-linking acrylic, and is designed to mimic the look and feel of a wax finish. Because of the increased matting agents used to create the "Flat look", this finish will have less clarity. Like wax, it dries softer to the touch than High Performance when completely cured, and will show more fingerprints. FOF finish will mark up more easily because of increased matting agents used to reduce the sheen, so it is not recommended for high-use tabletops.
Enduro-Var is an oil modified water-based alternative for customers that want the warm look of an oil finish in a water based coating. It looks more like an oil finish than a water coating, and can be sprayed or brushed. The original Enduro-Var adheres well ONLY over WATER STAINS, DYE STAINS, and RAW WOOD. Use over other finishes at your own risk. The new formula of Enduro-Var II is compatible with all GF products and dries to a lighter amber than the previous formula.
Exterior 450 provides a clear drying tough, protective finish that will withstand the rigors of the sun, rain, and wind. It is suitable for vertical surfaces such as fences, patio furniture, garage doors, entrance doors, outdoor kitchens and interior windows. It is not recommended as a deck finish. Fortified with UV absorbers to stabilize the finish, Exterior 450's built-in mildewcide retards mold and mildew growth.
One of the causes of orange peel is the application of too much fluid and not enough atomization to break the product up into smaller droplets. It's similar to putting your finger over the end of a garden hose. Increase the atomization by using smaller fluid tips or a larger spray unit. See General Finishes comparison chart for generally recommended spray tips. Contact your spray equipment manufacturer's recommendations as well.
Another cause can be temperature. Refinishing furniture in a space that is below or above the 65-75 degrees F range can lead to problems, and a space below 55 degrees F is definitely too cold.
The popular flat sheens are lovely but they have different attributes than glossy finishes. The flatting agents required to reduce sheen in flat or matte topcoats also slightly reduce clarity, water resistance, durability and resistance to chemicals such as ketchup, soap, chemical cleaners, or ammonia. This is not much of a concern in low use areas but is important for table tops or kitchen cabinets.
Here is a tip to improve the performance of your finish and still obtain a matte sheen:
Use a semi-gloss sheen for the first two coats and a flat for the third for optimum performance.
General Finishes is constantly seeking new resins and additives to improve the performance of our finishes.
All of General Finishes water-based topcoats with the exception of Conversion Vanish can be tinted to create lightly colored finishes for toning. It is YOUR RESPONSIBILITY TO TEST to your satisfaction before application to your entire project.
There are limits anytime you add pigments or dyes to water-based topcoats. Toning should always be done in small increments to achieve the desired color. If you are starting with a light honey tone door and you want to create an Espresso color this will take multiple coats of color including base coat of stain followed by several toning coats. It is impossible to achieve a radical change in color in coat application.
A good rule to follow when toning is starting with a minimal amount of stain or dye, 5-10% by volume. Some colors work better than others. Normally 1-2 ounces or stain per quart of clear topcoat is sufficient to create a toner. Always test color first and strain material through a fine mesh filter to remove any undissolved particle of pigment. Once you have achieved the desired color tone apply a clear topcoat to lock in the color.
Oil based topcoats and Enduro-Var will amber over time.
Water based Flat Out Flat and High Performance top coats dry clear.
Never use any water based topcoat with long oils such as Danish, Tung or Linseed.
Water based top coats clean up with water. Oil based topcoats require mineral spirits for clean up.
Original formula of Enduro-Var ADHERES WELL only over WATER STAINS, DYE STAINS, and RAW WOOD. The new formula of Enduro-Var II is compatible with all GF products.
If you use water based topcoats over oil based finishes, make sure that you wait 72 hours between the two products. It is essential to let the oil finish dry longer.
For more complex projects that have a lot of nooks and crannies or projects with large surface areas such as cabinets, we recommend either ARM-R-SEAL liquid oil based topcoat or any of our water based topcoats. Large surfaces such as cabinets or tables and complex projects with lots of detail are easier to cover with liquid topcoat rather than a Gel top coat.
Enduro Professional Topcoats are thinner and intended to be sprayed
High Performance and Flat Out Flat can also be sprayed. If needed, it can be thinned by adding 5-10% distilled water.
