Raw Wood
- Sand with 120-grit sandpaper, followed by 150 or 220-grit.
- Remove dust.
Sealed Surface
- Scuff clean with a non-woven abrasive pad & 50:50 mix of denatured alcohol & water.
- Dry 1-2 hours.
- Sand lightly with 220-320-grit sanding sponge.
- Remove dust.
Step 2: Priming
CAUTION: Do NOT use any type of clear topcoat over GF White Poly, as it may cause yellowing.
RAW WOOD: If needed, apply 2 coats of GF Stain Blocker or GF White Undercoat
SEALED SURFACE: 2 coats of GF Stain Blocker or GF White Undercoat are recommended.
- Raw Wood Tannin Bleed-Through is unpredictable; yellowing can appear immediately or months later with seasonal temperature changes. Oak, pine, mahogany, and Douglas fir are particularly prone to bleed-through.
- Knots in Wood tend to bleed and are dense, making paint adhesion a challenge. Stain Blocker may improve adhesion and prevent bleed-through.
- Existing Finishes Bleed-Through may be caused by wood tannins, previous stains or aniline dyes, surface contamination, and incompatibility between brands.
ALWAYS apply 2 coats General Finishes Stain Blocker before applying Enduro White Poly over an existing finish for adhesion and to prevent bleed-through. - Non-Wood Surfaces may be able to take paint if primed first. Primer may improve adhesion over laminate and prevent bleed-through from MDF. Metal requires a primer made specifically for metal. Always test first before completing your entire project.
NOTE: Do not tint or use General Finishes Stain Blocker on projects that will be stored outdoors.
Priming Non-Wood Surfaces for Paint
Always test for adhesion on a hidden area of your project before getting started.
Metal
Enduro Pigmented White Poly is engineered for wood surfaces, but may adhere to pre-primed steel, if a metal primer is applied first.
- Clean the surface well.
- Apply primer.
- Dry 48-72 hours before painting.
Laminate
Enduro Pigmented White Poly MAY adhere to laminate with a bonding primer; however, we cannot guarantee it. You may increase your chances of success by abrading the surface.
- Prep: Deep clean, dry thoroughly, sand with 150- then 180-grit sandpaper, and wipe off dust.
- Prime: Apply bonding primer, dry 12+ hours before painting.
MDF
Enduro Pigmented White Poly can be applied directly to MDF, but the MDF may cast a brown color if not primed first. Two base coats of white-pigmented shellac-based stain-blocking primer, or Stain Blocker, may prevent bleed-through.
Disclaimer
Although Stain Blocker is engineered to prevent the most persistent bleed-through when 2 coats are applied, General Finishes cannot guarantee prevention of bleed-through or yellowing on every project. Unknown factors and assiduous bleed-through can impact results. Stain Blocker is the strongest option we are aware of at this time and has performed extremely well in our tests.
Step 3: How To Apply General Finishes Enduro White Poly
CAUTION: General Finishes Enduro White Poly is engineered to adhere well to raw wood, General Finishes White Undercoat and General Finishes Stain Blocker. See priming instructions in Step 2. It can also used over existing finishes if properly primed.
Download 2024 Professional Water-Based Professional Product Brochure Here
General Finishes Enduro White Poly Spray Application: Raw Wood & Sealed Surface
- Watch product overview video here or comparison of GF paints and pigmented topcoats here.
- Work in a well-ventilated area.
- Stir thoroughly to reincorporate solids that have settled to the bottom of the can before and throughout the application process.
- Test for color & adhesion over existing sealed surfaces.
- Thin as desired with distilled water; start with 5%, adding up to 10% by volume.
- Increase open time, if needed, with 10-15% by volume of General Finishes Extender if allowed by local regulations. GF Extender will improve flow and leveling and increase open time, which is helpful in dry climates. California Residents: Adding more than 2% of GF Extender will make the product
snon-compliant per SCAQMD Regulations. GF assumes no liability for the improper use of these products. - Ready to spray from container. Wear NIOSH-approved respiratory and eye protection.
- Spray application: Before spraying, strain through a fine-mesh filter. Spray wet films at 3-5-mil thickness. Medium air cap. Compressed air: .040, HVLP: .043 -.051 or Airless: .1 -.15. Verify tip sizes with your equipment supplier. See our spray tip size recommendations here. Keep your gun at a 90° angle, 6-8" from the surface. On large, flat areas, use wet, even patterns 6-8" wide. For narrow surfaces, reduce the fan pattern to 2-3" wide to reduce overspray. Overlap each pass 25% to conceal lines. Wear a mask and work in a ventilated space. Read here for more information on spraying techniques.
- Face frames: Enduro professional products are engineered to be spray-only but can be successfully applied successfully to cabinet face frames, edges or drawer fronts with a small cabinet-specific 3/8" nap microfiber roller such as Whizz or AllPro brand. Larger areas may not level with a roller application. Add 10-20% Extender for improved results.
- If a faster build is desired over raw wood, use General Finishes Sanding Sealer for the first coat, followed by 2 coats of White Poly.
- Dry time based on ideal conditions: 70°F/21°C; 50% humidity. Tack free 5-10 minutes. Ready to sand 30-45 minutes. Recoat in 1+ hours. Be sure to allow adequate dry time. Dry times are dependent on application method and environmental conditions. You can tell if a water-based finish is dry if it forms a powder when lightly sanded with a 220-320 sanding sponge. If in doubt, wait longer. Rushing the dry time can cause "blush," which is clouding in the finish due to moisture trapped between the layers. Increase dry time if:
- Higher humidity
- Cooler temperatures
- 3+ coats are applied
- Thick coats are applied
- Applying over a sealed surface
- Applying over products from other brands
- Layering General Finishes water- and oil-based products:
- Water over oil: Let oil-based products dry 72+hr before applying water-based products
- Oil over water: Let water-based products dry 24+hr before applying oil-based products
- To accelerate dry time in humid conditions, add General Finishes Accelerator and work in a space with good ventilation and air movement. If you decide to re-coat before the recommended time, test dryness.
- Finish sand between coats with a 220-320 sanding sponge to improve smoothness and adhesion.
- Remove dust with a vacuum, compressed air, an oil-free tack cloth or a water-dampened rag.
- A topcoat is not required.
Tinting
Product that is 3 years old will not look like product that is 6 months to 1 year old. You will see more stratification or separation as the product ages. Settling is natural. Always stir thoroughly before using.
Foul Smell
If your product has a foul smell, it is contaminated and no longer in useable condition.
Water-based finishes crystalize and form a skin due to evaporation when the air-tight seal on a can is broken at first use. The following best practices will increase the life of your product:
- Pry open sealed lids with a paint can opener by hooking under the lid's rolled edge. The use of a screwdriver can disfigure the rim and lid, impairing a complete seal.
- Keep lid closed while working. Pour what you will use into a bowl, paper cup, or plate, and close can lid as you work.
- Clean the chime of the can thoroughly with a paper towel before closing to create a complete seal. Product falling into the chime can be minimized by using a pouring lid, such as Fitsall. Avoid wiping used brushes on the lid.
- Pound the lid in place using a rubber mallet to avoid distorting the chime or lid. Dents in the lid from direct contact with a hammer can impair a complete seal. Alternatively, place a flat piece of wood over can lid and firmly pound shut.
- Store in moderate temperatures. Avoid temperatures below 50°F/10°C or above 100°F/26°C. Keep from freezing. Frozen and heat-damaged product cannot be revitalized. Temperature-controlled spaces, such as a basement, are ideal for storage. Do not store product in an attic, garage, in direct sunlight, or next to something warm like a water heater or furnace.
- Store can upside down to create a liquid seal, minimize evaporation and reduce the chance of crystallization. Decant remaining product from the can before stirring.
- Decant leftovers to a smaller container when the finish is almost used up. Alternative storage containers for water-based products are plastic FIFO bottles or glass bottles. Do not fill metal-lidded containers completely to prevent them from rusting.
- Product thinned with up to 15% General Finishes Extender or General Finishes Accelerator can be stored, with the exception of thinned General Finishes Water Based Wood Stain.
- Mixtures involving colors & sheens within the same product line, such as:
- High Performance Satin + High Performance Gloss
- Snow White Milk Paint + Coastal Blue Milk Paint
- Amber Dye Stain + Merlot Dye Stain
The following product mixtures should NOT be stored:
- Any water based product with thinned tap water; water often contains bacteria that will adversely affect stored paint.
- Topcoat + Stain or Paint
- Milk Paint + Chalk Style Paint
- Water Based Wood Stain + Dye Stain
- Remove dust with a water-dampened cloth. Dust can build up over time and may scratch or dull finishes if not removed regularly.
- Remove fingerprints, cooking fumes and smoking residue with mild soap and water. These contaminants will not harm the finish, but they accumulate on surfaces and dull the original luster.
- As with all fine furniture finishes, avoid using furniture polish, cleaners or dusting sprays that contain silicone, alcohol, ammonia and anything acidic. Exception: We have successfully cleaned with Clorox wipes for occasional cleanups.
- Clean up water, alcohol and food spills in a timely manner and use placemats & coasters to protect the finish.
- Future finishes or touch-ups may not adhere properly or perform as desired over a contaminated surface. Some contaminants, such as silicone, seep through finish into the wood and often cannot be removed.
- Avoid excessive exposure to direct sunlight, high temperatures or high humidity. These can damage furniture and finishes.
Eye protection: Safety eyewear complying with an approved standard should be used when a risk assessment indicates this is necessary to avoid exposure to liquid splashes, mists, gases, or dust. If contact is possible, the following protection should be worn unless the assessment indicates a higher degree of protection: safety glasses with side shields.
| Basic Features | |
| Product Colors | White |
| Base Type | Water |
| Sheen | Flat (10 or less), Satin (25-35), Semi-Gloss (50-60) |
| Interior or Exterior | Interior only |
| Tintable | Yes |
| Type | Urethane/Acrylic Blend |
| Application | |
| Coats | 3 coats |
| Application Method | Spray |
| Brushable | No |
| Usable over existing finishes | Yes - see product page application instructions. |
| Sprayable | Yes |
| Spray Tip Sizes | HVLP 1.3mm-1.5mm |
| Topcoat Required | Self-Sealing |
| Dry Time | |
| Dry Time - Touch | 30+ min. |
| Dry Time - Recoat | 1+ hr |
| Dry Time - Light Use | 7-10 days |
| Dry Time - Cure | 21 days |
| Contents | |
| Can Sizes | Quarts, Gallons, 5 Gallon pails, 55 Gallon drums |
| Can Size Exceptions |
Quarts only available in Satin |
| Coverage | 450 sq.ft. (41.81 m²) per Gallon |
| Technical Data | |
| Viscosity | Medium |
| Viscosity (cPs) | 600-800 |
| Solids by Weight and Volume |
Solids by Weight Flat: 45% Satin: 45% Semi-Gloss: 44% Solids by Volume Flat: 33% Satin: 33% Semi-Gloss: 32% |
| VOC |
US VOC Flat: <250 g/L Satin: <250 g/L Semi-Gloss: <150 g/L |
| Durability | |
| Durability (Highest, High, Medium, Low) | High |
| Hardness (Koenig #) | 59 |
| Wear (Taber #) | 109.80 mg loss |
| Water (5 max) | 5 |
| Chemical (105 max) | 88 |
Enduro Water-Based Conversion Varnish
Enduro Water Based Stain Blocker Primer
Enduro Water-Based Tintable 2K White Poly
Enduro Water-Based Pro Series White Polyurethane
Hard Wax Oil & Hardener
Gel Stains
Pro Image Flooring Topcoat
Jen Poly Brushes
Stir Stix
Ultraflex Softback Sanding Sponge
TDS: Enduro White Poly - 2020-03
