Enduro Water-Based Pro Series White Polyurethane
General Finishes Enduro Pro Series White Polyurethane is a single-component self-cross linking polyurethane/acrylic topcoat designed for fast build with 2-coat hide capability. Priced competitively for the professional and industrial markets, Pro Series White is tintable and fast dry with excellent flow and leveling. Both Pro Series White and Clear Polyurethane meet or exceed KCMA standards. Recommended use is interior cabinets, trim, doors, and furniture. Use over raw, stained, or primed wood substrates. 2K White Poly is short-filled 5%, allowing room for tinting colorant for easy tinting.
Made in the U.S.A. by General Finishes. Learn more about our entire paint system of clear and pigmented primers, acrylic and polyurethane clears, 1K and 2K pigmented topcoats, and water-based stains here:  4 Reasons to Switch to Water-Based Finishes.
Spray tip recommendations are here.
General Finishes Pro Series Polyurethane White Single Component
Tinting
Step 2: Preparation
Raw Wood
  1. Sand with 120-grit sandpaper, followed by 150 or 220-grit.
Sealed Surface
  2. Dry 1-2 hours.
  3. Sand lightly with 220-320-grit sanding sponge.
  4. Remove dust.
Step 2: Priming
CAUTION: Do NOT use Enduro 2K Clear or any clear topcoat over white paint, as it may cause yellowing.
2K WHITE POLY PRIMING RECOMMENDATIONS:
INTERIOR RAW WOOD: 2K White Poly is designed to adhere to raw wood. Can be used without a sealer.
SEALED SURFACE: When applying 2K White Poly over an existing sealed surface, ALWAYS PRIME with Enduro White Undercoat for interior/exterior use or GF Stain Blocker for interior projects where tannin bleed-through is a concern.
2K CLEAR POLY PRIMING RECOMMENDATIONS:
INTERIOR RAW WOOD & STAINED SURFACES: 2K Clear Poly is designed to adhere to raw wood and newly stained wood. Can be used without a sealer. Use 1-2 coats of Enduro Sanding Sealer for an improved build. 3-4 total coats are recommended.
SEALED SURFACE: If tinted and applying over an existing sealed surface, ALWAYS PRIME with Enduro White Undercoat or Enduro Deep Base Primer for interior/exterior use or Enduro Stain Blocker for interior projects.
Disclaimer
Although Stain Blocker is engineered to prevent the most persistent bleed-through when 2 coats are applied, General Finishes cannot guarantee the prevention of bleed-through or yellowing on every project. Unknown factors and assiduous bleed-through can impact results. Stain Blocker is the most robust option and has performed extremely well in our tests.
Step 3: How to Apply Enduro Pro Series White Polyurethane
CAUTION: Do NOT use topcoat over Enduro Pro Series White Polyurethane or any other white or light paints such as GF Milk Paint, or Enduro White Poly as it may cause yellowing. Any clear coat can become reactive over wood substrates or existing finishes, causing tannin or dye bleed-though regardless of priming. All of GF's white paints are self-sealing and do NOT require a topcoat.
Join the Enduro Wood Coating Pros Facebook Group at for customer support and learning opportunities specifically for General Finishes Pro line of Enduro products. This group is a great resource for guidance regarding choosing the right product, mastering finishing techniques, troubleshooting, or sharing your finished projects with other pros.
Download 2024 Professional Water-Based Product Catalog here.
General Finishes Enduro Pro Series Topcoat Application Steps
  1. Settling is natural. Stir thoroughly to reincorporate solids that have settled to the bottom of the can before and throughout the application process. Do not shake.
  2. Test for adhesion when applying over an existing finish.
  3. Thin as desired with distilled water; start with 5%, adding up to 10% by volume.
  4. Increase open time, if needed, with 10-15% General Finishes Extender if allowed by local regulations. GF Extender will improve flow and leveling and increase open time, which is helpful in dry climates. California Residents: Adding more than 2% of GF Extender will make the products non-compliant per SCAQMD Regulations. GF assumes no liability for the improper use of these products.
  5. Ready to spray from the container. Ready to spray from the container. Apply 2-3 coats. Wear NIOSH-approved respiratory & eye protection.
  6. Two-coat hide is best achieved by using a primer such as Enduro White Under Coat or Stain Blocker.
  • Spray application: Before spraying, strain topcoat through a fine-mesh filter. Spray wet films at 3-5-mil thickness. Medium air cap. Compressed air: 0.40, HVLP: 1.3mm-1.5mm. Air Assisted Airless: 1000-1200 PSI pump, 20 PSI assist air, .011" - 013" tip or Airless Fine Finish .007"-.011". Verify tip sizes with your equipment supplier. See our general guide for spray tip sizes. Keep your gun at a 90° angle, 6-8" from the surface. On large, flat areas, use wet, even patterns 6-8" wide. For narrow surfaces, reduce the fan pattern to 2-3" wide to reduce overspray. Overlap each pass 25% to conceal lines. Wear a mask and work in a ventilated space. Read here for more information on spraying techniques.
  • Respiratory protection:
    ​​Based on the hazard and potential for exposure, select a respirator that meets the appropriate standard or certification.
  • Face frames on cabinets: Enduro professional products are engineered to be spray-only but high viscosity formulas can be successfully applied to cabinet face frames or edges with a pad or small, cabinet-specific short nap or foam roller, such as Whizz Velour brand. Larger areas may not level with a hand application.
  1. If a faster build is desired over raw wood, use 1 or 2 coats Enduro Sanding Sealer . 3-4 total coats of finish are recommended.
  2. Finish sand between coats with 220-320 grit sanding sponge to improve smoothness and adhesion.
  3. Remove dust with a vacuum, compressed air, an oil-free tack cloth or a water-dampened rag.
Compliance With Air Quality Regulations
Complies with the following air quality regulations:
SCAQMD, CARB, Canada, OTC Phase I & Phase II
Yellowing & Clear Topcoat
There is no reliable way to predict whether yellowing will occur and to what degree. Every existing finish is different and we rarely know the finishing provenance on an existing piece. Every tree is different and every piece of wood is unique. Raw wood can bleed tannins immediately after the topcoat dries or months later with seasonal temperature changes. Oak, pine, mahogany, and Douglas fir are particularly prone to bleed-through.
Summary
Tips to Prevent Yellowing
  • Use a professional product such as General Finishes Enduro White Poly. It has "increased topcoat properties," is a standalone finish when 3 coats are applied, and does not require sealing with a topcoat.
Knots
Sheen Flat (10), Satin (30), Semi-Gloss (55)
Tintable Yes
Type Urethane/Acrylic Blend
Suggested Use
Interior cabinets, trim, doors and furniture. Use over raw or primed wood substrates.
Pro Tips
Force Dry: Allow product to flash for 10 minutes at ambient temperature.
INFRARED LAMP / OVEN: Heat surface to 105F/41C. Allow to cool before sanding. Allow a minimum of 30 minutes between coats.
Usable over existing finishes Yes - see product page application instructions.
Spray Tip Sizes HVLP 1.3mm-1.5mm
Air-Assist Airless 1000-1200 PSI pump, 20 PSI assist air, .011" tip
Airless Fine Finish .007 - .011"
Dry Time - Recoat 1+ hr
Dry Time - Light Use N/A
Can Sizes Gallons, 5 Gallon pails, 55 Gallon drums
Viscosity (cPs) 600-800
Solids by Weight and Volume Volume Solids: 32 - 35% dependent on sheen
Weight Solids: 43 -47% dependent on sheen
VOC All sheens under 150 g/L.
Durability (Highest, High, Medium, Low) Medium
Chemical (105 max) 101
