Step 1: Surface Preparation Enduro Professional Tintable 2K Poly
Raw wood
- Sand no finer than 220 grit.
- Remove dust.
Sealed Surface
- Scuff clean with a non-woven abrasive pad & 50:50 mix of denatured alcohol & water.
- Dry 1-2 hours.
- Sand lightly with 220-320-grit sanding sponge.
- Remove Dust
Other substrates such as fiberglass and pre-primed steel
- Can be used with proper preparation & priming.
- Always test for performance before proceeding with your project.
Step 2: Priming
CAUTION: Do NOT use Enduro 2K Clear or any clear topcoat over white paint, as it may cause yellowing.
2K WHITE POLY PRIMING RECOMMENDATIONS:
INTERIOR RAW WOOD: 2K White Poly is designed to adhere to raw wood. Can be used without a sealer.
SEALED SURFACE: When applying 2K White Poly over an existing sealed surface, ALWAYS PRIME with Enduro White Undercoat for interior/exterior use or GF Stain Blocker for interior projects where tannin bleed-through is a concern.
2K CLEAR POLY PRIMING RECOMMENDATIONS:
INTERIOR RAW WOOD & STAINED SURFACES: 2K Clear Poly is designed to adhere to raw wood and newly stained wood. Can be used without a sealer. Use 1-2 coats of Enduro Sanding Sealer for an improved build. 3-4 total coats are recommended.
SEALED SURFACE: If tinted and applying over an existing sealed surface, ALWAYS PRIME with Enduro White Undercoat or Enduro Deep Base Primer for interior/exterior use or Enduro Stain Blocker for interior projects.
Disclaimer
Although Stain Blocker is engineered to prevent the most persistent bleed-through when 2 coats are applied, General Finishes cannot guarantee the prevention of bleed-through or yellowing on every project. Unknown factors and assiduous bleed-through can impact results. Stain Blocker is the most robust option and has performed extremely well in our tests.
Step 3: How To Apply General Finishes 2K White Poly
Enduro Tintable 2K White Poly is a post-catalyzed, high-solids, two-component urethane formulated for ultimate durability and chemical resistance and requires General Finishes Enduro NCO Catalyst. READ PROTECTION INSTRUCTIONS IN WARNINGS SECTION BELOW BEFORE USE.
Download 2024 Professional Water-Based Product Catalog Here
Enduro Tintable 2K White Poly Application Steps
- Work in a well-ventilated area.
- Stir thoroughly to reincorporate solids that have settled to the bottom of the can using a power drill and mixer (recommended) or by hand with a paint stick. Do not shake. See this video here: How To Mix 2K Conversion Varnish
- Test for adhesion when applying over an existing finish.
- Thin as desired, with distilled water (after mixing with NCO catalyst); slowly add up to 10% by volume.
- Increase open time, if needed, with 10-15% by volume of Enduro Extender if allowed by local regulations. GF Extender can be used to improve flow and leveling, and increase open time, which is helpful in dry climates. California Residents: Adding more than 2% of GF Extender will make the product non-compliant per SCAQMD Regulations. GF assumes no liability for the improper use of these products.
- Slowly add up to 10% NCO Catalyst by volume (3.2 oz. per quart; 12.8 oz. per gallon) while stirring thoroughly. Mix 2-3 minutes with a power drill. Use gloves and protective eyewear when mixing. Mix only what you are going to use and clean spray gun immediately after use. The finish can only be mixed once, and the leftover product will solidify after 4 hours. Pot life will vary by colorant dosage and manufacturer. DO NOT store in a closed container to avoid pressure build-up.
- Let rest for 15 minutes.
- Apply 2-3 coats or 3-4 total coats if using Enduro Sanding Sealer for an improved build. Additional coats will not improve durability.
- Spray application: Before spraying, strain through a fine-mesh filter. Spray wet films at 3-5-mil thickness. HVLP: 1.1mm-1.3mm spray tip, medium air cap. AIR-ASSIST AIRLESS: 375 PSI pump, 20 PSI assist air, .011”-.013” tip. AIRLESS: Fine Finish .007” - .011”. Verify tip sizes with your equipment supplier. Spray tip recommendations. Keep your gun at a 90° angle, 6-8" from the surface. On large, flat areas, use wet, even patterns 6-8" wide. For narrow surfaces, reduce the fan pattern to 2-3" wide to reduce overspray. Overlap each pass 25% to conceal lines. NOTE; 2K White Poly is used with NCO catalyst. When using a spray gun, wear self-contained breathing apparatus. In the event of insufficient ventilation: Wear self-contained breathing apparatus. When respirators are required, select NIOSH/MSHA-approved equipment and work in a ventilated space. READ ALL PROTECTION INSTRUCTIONS IN THE WARNINGS SECTION BEFORE USE.
- If a faster build is desired over raw wood, use 1-2 coats of Enduro Sanding Sealer, followed by 2 coats of 2K White Poly. No more than 3-4 total coats of finish is recommended.
- Finish sand between coats with a fine-grade (220-320) foam sanding pad or gray non-woven abrasive pad to improve smoothness and adhesion.
- Remove dust with a vacuum, compressed air, an oil-free tack cloth or a water-dampened rag.
Tinting
Warning: Do not use water-based products with Linseed Oils or Danish Oils.
Dry Time 2K Polys
Dry Time Based on ideal conditions of 70°F/21°C; 50% humidity.
Dry-time (touch): 30 minutes
Dry-time (recoat): 30 minutes -2 hours based on heat & airflow.
Cure-time: 5 days
Be sure to allow adequate dry time. You can tell if a water-based finish is dry if it forms a powder when lightly sanded with a fine-grade (220-320) foam sanding pad or 400-grit sandpaper. If in doubt, wait longer. Rushing the dry time can cause "blush," which is clouding in the finish due to moisture trapped between the layers.
- Humidity is over 80%
- Temperatures are cooler.
- 3+ coats are applied
- Thick coats are applied
- Applying over an existing sealed finish
- Applying over products from other brands
- Layering General Finishes water- and oil-based products:
- Water over oil: Let oil-based products dry 72+hr before applying water-based products
- To accelerate dry time in humid conditions, add General Finishes Accelerator and work in a space with good ventilation and air movement. If you decide to re-coat before the recommended time, test dryness.
FORCE DRY: Allow product to flash for 10 minutes at ambient temperature. INFRARED LAMP / OVEN: Heat surface to 105°F/41°C. Allow cooling before sanding. Allow a minimum of 30 minutes between coats.
Buffing 2K
The surface an be buffed after the finish has cured using wet/dry automotive sandpaper. Use GF Satin Finishing Wax as lubricant.
Do NOT use water.
Cleanup For 2K Polys
Clean hands with soap and water. Clean equipment with General Finishes Brush & Gun Cleaner immediately after use.
Discard unused product and waste in an environmentally safe manner; check with local fire and health regulations. Do not pour down drains.
Eye protection: Safety eyewear complying with an approved standard should be used when a risk assessment indicates this is necessary to avoid exposure to liquid splashes, mists, gases, or dust. If contact is possible, the following protection should be worn unless the assessment indicates a higher degree of protection: safety glasses with side shields.
| Basic Features | |
| Product Colors | White, Tintable |
| Base Type | Water |
| Ambering | No |
| Sheen | Flat (10 or less), Satin (25-35), Semi-Gloss (50-60), Gloss (85+) |
| Interior or Exterior | Interior/Exterior |
| Tintable | Yes |
| Type | Urethane |
| Suggested Use |
Interior or exterior application: raw wood, stained wood, cabinets, trim, doors, furniture, table tops & bar tops, fiberglass & pre-primed steel. If using over painted surfaces, especially white, prime and test first before completing your project. |
| Application | |
| Coats | 2 - 3 coats |
| Application Method | Spray |
| Brushable | No |
| Usable over existing finishes | Yes |
| Sprayable | Yes |
| Spray Tip Sizes | HVLP 1.1mm-1.3mm |
| Air-Assist Airless |
375 PSI pump, 20 PSI assist air, .011”-.013” tip or 409 tip. 1000 psi fluid with 18 psi air |
| Airless |
Fine Finish .007” - .011” or Airless .308 FFLP Tip at low pressure |
| Topcoat Required | Self-Sealing |
| Dry Time | |
| Dry Time - Touch | 30+ min. |
| Dry Time - Recoat | 1+ hr |
| Dry Time - Cure | 5 days |
| Dry Time - Recoat - Applied Over Oil Based Product | 72 |
| Contents | |
| Can Sizes | Gallons, 5 Gallon pails |
| Coverage | 450 sq.ft. (41.81 m²) per Gallon |
| Technical Data | |
| Viscosity | Thick |
| Viscosity (cPs) | 1000-1500 |
| Weight Solids | 45% |
| Solids by Weight and Volume |
Solids by weight Flat: 46% Satin: 44% Semi-Gloss: 43% Gloss: 42% Solids by Volume Flat: 35% Satin: 32% Semi-Gloss: 31% Gloss: 30% |
| VOC | <200 g/L. Varies by color. See color-specific SDS for exact number. |
| Durability | |
| Durability (Highest, High, Medium, Low) | Highest |
| Hardness (Koenig #) | 125 |
| Wear (Taber #) | 35.00 mg loss |
| Water (5 max) | 5 |
| Chemical (105 max) | 101 |
Enduro Water-Based Tintable 2K White Poly
Enduro Water-Based Pro Series White Polyurethane
Enduro Water-Based Conversion Varnish
Enduro Water Based Stain Blocker Primer
Hard Wax Oil & Hardener
Gel Stains
Pro Image Flooring Topcoat
Jen Poly Brushes
Stir Stix
Ultraflex Softback Sanding Sponge
TDS Enduro Tintable 2K White Poly 2025-07
