SURFACE PREPARATION
- Sand with 120-grit sandpaper, followed by final 220-grit.
- Remove dust.
- Wipe surface down with mineral spirits on a clean cloth to remove dust from pores.
- Allow mineral spirits to dry before applying the GF Hard Wax Oil.
This is General Finishes' easiest finish ever and the best oil and wax finish on the market. Hard Wax Oil is a high-quality urethane-solids polymer in a blend of oil & wax that enhances the natural look of wood. The urethane gives Hard Wax Oil improved chemical and mechanical properties over standard oil & wax finishes. Best used with optional GF Hardener to substantially shorten dry time and provide superior durability, and chemical and water resistance. The recommended use is for interior raw wood furniture, millwork & woodworking projects. What results can you expect? It will not crack or peel, can be buffed to a slightly higher sheen, and is very EASY to use. This is a maintenance product. Reapply when wear becomes evident.
Ideal conditions: 70°F/21°C; 50% humidity. Cooler temperatures, and higher humidity may prolong dry time. Use of the Hardener will shorten dry times.
After the surface has dried for 24 hours, you can buff to a slightly higher sheen with a white non-woven pad or terry cloth.
Clean up application materials and hands with mineral spirits.
Take GREAT CARE when disposing of product-soaked applicators. Application materials containing Hard Wax Oil products may spontaneously catch fire if improperly discarded. Immediately place all application materials soaked with this product in a sealed, water-filled metal container. Dispose of in accordance with local fire regulations.
Clean up spills with mineral spirits immediately while wet. If oil and wax finishes dry, they are difficult to clean off any surface, clothes or carpet. Carpet may discolor if cleaned with mineral spirits.
General Finishes products do not last forever, even when unopened. They are best used within 1 year. The life of the product may be extended with proper can closure and storage conditions.
Oil-based products start to harden and cure when exposed to oxygen. The following best practices will increase the life of your product:
Hard Wax Oil Warnings and Warranties
DANGER: COMBUSTIBLE LIQUID AND VAPOR. HARMFUL OR FATAL IF SWALLOWED. CAUSES EYE IRRITATION.
DANGER: Can enter lungs and cause damage. DANGER: Keep out of reach of children. Keep away from heat and flame. Use only with adequate ventilation. Do not breathe vapor or mist. Do not swallow. Avoid contact with eyes. Keep container tightly closed when not in use. Wash thoroughly after handling.
Basic Features | |
Base Type | Oil & Wax |
Ambering | Yes |
Sheen | N/A |
Interior or Exterior | Interior only |
Type | Oil & Wax Blend |
Suggested Use |
Furniture, millwork & woodworking projects |
Application | |
Application Method | Wipe on with synthetic non-woven pad, Trowel on with a blade applicator |
Brushable | No |
Usable over existing finishes | No |
Sprayable | No |
Dry Time | |
Dry Time - Touch | N/A |
Dry Time - Recoat | 24+ hr |
Dry Time - Light Use | N/A |
Dry Time - Cure | N/A |
Contents | |
Can Sizes | Half-Pints, Pints |
Coverage | 30 Sq.Ft. (2 m²)/Half-Pint, 60 Sq.Ft. (5 m²)/Pint. |
Technical Data | |
Viscosity | Very Thick |
VOC | <50 g/L |
Durability | |
Durability (Highest, High, Medium, Low) | Low |
