Compatibility: Do not use water-based products with Linseed Oils or Danish Oils.
Disposal: Discard unused product and waste in an environmentally safe manner; check with local fire and health regulations.
CAUTION: Contains ALIPHATIC HYDROCARBONS. VAPOR HARMFUL. Use only with adequate ventilation. DELAYED EFFECTS FROM LONG-TERM OVEREXPOSURE. Contains solvents which can cause permanent brain and nervous system damage. Intentional misuse by deliberately concentrating & inhaling the contents can be harmful or fatal.
Keep out of reach of children. Do not swallow. Do not get on skin or clothing. Avoid contact with eyes. Keep container tightly closed when not in use. Wash thoroughly after handling.
FIRST AID: Seek immediate medical attention if symptoms occur due to the following. EYE CONTACT: Remove any contact lenses. Flush eyes with water for 20+ minutes while lifting upper and lower eyelids. SKIN CONTACT: Flush skin with water. Remove contaminated clothing and shoes and clean before reuse. INHALATION: Move to fresh air. Loosen tight clothing. If not breathing, if breathing is irregular, or if respiratory arrest occurs, trained personnel should provide artificial respiration or oxygen. INGESTION: Call physician immediately. Wash out mouth with water. Do not induce vomiting unless directed to do so by medical personnel. Never give anything by mouth to an unconscious person.
