Glaze Effects: Water Based
Glaze Effects are translucent water-based colors used to create beautiful decorative finishes such as marbling, shabby chic, burnishing and color washing. Use over Water Based Wood Stains, and Milk Paints. Glaze Effects can be intermixed to create custom colors. They may also be layered over one another to create deeper, richer looks.
Need some inspiration? Visit the General Finishes Design Center OR Pinterest Board for Glaze Effects ideas.
General Finishes Van Dyke Brown Water Based Glaze Effects, Quart
RAW WOOD: Not recommended. Apply over a SEALED surface such as GF Milk Paint or topcoat.
NEWLY SEALED: Does not require prep cleaning. Sand lightly with 220-320 grit foam sanding sponge and remove dust.
EXISTING SEALED SURFACE: Scuff clean with a Scotch-Brite™ pad or maroon synthetic steel wool & 50/50 mix of denatured alcohol and water. Dry 1-2 hours. Sand lightly with 220-320 grit foam sanding sponge. Remove dust. Watch our video How to Prep and Existing Finish
Step 2: How To Apply General Finishes Glaze Effects
Download 2024 Glaze Effects Brochure Here
General Finishes Glaze Effects Application Steps
For less color & more control of depth and placement of glaze color, apply Glaze Effects over 1 coat of General Finishes High Performance Topcoat, any sheen. For a deeper color, apply directly over stain or paint. Test for adhesion over existing finishes before completing the project.
  2. Stir thoroughly to reincorporate solids that have settled to the bottom of the can before and throughout the application process.
  3. Test color. To lighten, dilute with water based GF Glaze Effects Clear Base.
  4. Thin as desired with distilled water; start with 5%, adding up to 10% by volume.
  5. Increase open time, if needed, with 10-15% General Finishes Extender if allowed by local regulations. GF Extender will improve flow and leveling and increase open time, which is helpful in dry climates. California Residents: Adding more than 2% of GF Extender will make the products non-compliant per SCAQMD Regulations. GF assumes no liability for the improper use of these products.
  6. Apply 1+ coats:
    • Hand application: Apply a liberal coat using a synthetic bristle brush, foam brush, pad applicator or microfiber roller with smooth, even strokes. Wipe off excess with a cloth, high-quality absorbent paper towel or dry bristle brush. Do not use t-shirts.
    • Spray application: Strain with a medium-mesh filter. Spray wet films at 3-5-mil thickness. HVLP: 1.3mm-2.0mm spray tip, medium air cap. Verify tip sizes with equipment supplier. See our general guide for spray tip sizes. Wear NIOSH-approved respiratory & eye protection. Read here for more information on spraying techniques. Wipe off excess with a cloth, high-quality absorbent paper towel or dry bristle brush. Do not use t-shirts.
  7. Sand between coats with 220-320 grit foam sanding sponge. Do not use conventional steel wool. Remove dust.
  8. Seal with 3 coats of topcoat.
  9. Dry 3+ hours between coats and before GF water based topcoat in ideal conditions: 70°F/21°C; 50% humidity. Dry times may vary based on additive and mix-concentration used. Cooler temperatures & higher humidity may prolong dry time. Dry 24+ hours before applying GF oil-based products.  Increase dry time if:
    • A thick coat is applied
Step 3: Topcoat over Glaze Effects
ALWAYS seal General Finishes Glaze Effects with 3 coats of clear topcoat, e.g. General Finishes High Performance Topcoat. Apply a total of 3+ coats of topcoat altogether. If 1 coat of topcoat is applied before Glaze Effects, add at least 2 more coats over the glaze to seal in the color.
Topcoat Recommendations
Creative Techniques Using Glaze Effects
Creating Custom Colors
You can design your own custom glazes, stains, washes and varnishes with General Finishes intermixable water-based products **Do not mix Glaze Effects with Water Based Stain (including water based pre-stain natural).
For the mixes listed below, General Finishes recommends the following two steps:
  1. Applying a base layer of General Finishes High Performance Topcoat before applying your custom glaze.
  2. Protect all of these finishes with 2-3 coats of topcoat when you are finished.
Pastel Glaze/Whitewash:
MATERIALS NEEDED:
  • General Finishes Milk PaintYour choice of colors
  • General Finishes Glaze Effects: Winter White
SAMPLE MIX:
Milk Paint + Winter White Glaze Effect
Experiment with proportions and colors. Do not add more than 50% paint to the glaze, or else there will be so much pigment it will be difficult to wipe away the finish.
Custom Glaze:
MATERIALS NEEDED:
  • General Finishes Glaze Effects: Your choice of colors
SAMPLE MIX:
Pitch Black Glaze Effects + Winter White Glaze Effects.
Custom Stain Colors:
MATERIALS NEEDED:
  • General Finishes Milk Paint: Your choice of color
  • General Finishes Glaze Effects: Clear Base
SAMPLE MIX:
  1. 1 part Milk Paint + 1 part Glaze Effects Clear Base [50:50 mix]
Proportions are relative to the color you are reducing. Some colors may require 2 parts Clear Base to reduce strength, others may require 1.
Begin with a 50:50 mix, and add more Clear Base as needed.
Increase your color palette by mixing 2 or 3 Milk Paint colors together before adding the Clear Base.
Milk Paint & Glaze Effects Samples
Glaze Effects Warnings and Warranties
  • Burnt Umber:
    This product can expose you to Ethylene oxide, which is known to the State of California to cause cancer and birth defects or other reproductive harm. This product can expose you to chemicals including 1,4-Dioxane, which is known to the State of California to cause cancer, and Ethanediol, which is known to the State of California to cause birth defects or other reproductive harm. For more information go to www.P65Warnings.ca.gov.
  • Pitch Black:
    This product can expose you to Ethylene oxide, which is known to the State of California to cause cancer and birth defects or other reproductive harm. This product can expose you to chemicals including 1,4-Dioxane, Carbon black, respirable powder, which are known to the State of California to cause cancer, and Ethanediol, which is known to the State of California to cause birth defects or other reproductive harm. For more information go to www.P65Warnings.ca.gov.
  • Van Dyke Brown:
  • Winter White:
    This product can expose you to Ethylene oxide, which is known to the State of California to cause cancer and birth defects or other reproductive harm. This product can expose you to chemicals including 1,4-Dioxane, Titanium dioxide, which are known to the State of California to cause cancer, and Ethanediol, which is known to the State of California to cause birth defects or other reproductive harm. For more information go to www.P65Warnings.ca.gov.
CAUTION: MAY CAUSE EYE IRRITATION.
Product Colors Van Dyke Brown, Pitch Black, Winter White, Burnt Umber, Smokey Gray
Interior or Exterior Interior
Type Glaze
Spray Tip Sizes HVLP 1.3mm-2.0mm
Dry Time - Recoat 1+ hr
Coverage 60-80 sq.ft./pint, 120-160 sq.ft./quart, 480-640 sq.ft./gallon
Weight Solids 22%
Burnt Umber: <293.554 g/L
Pitch Black: <303.733 g/L
Smokey Gray: <268.553 g/L
Van Dyke Brown: <274.496 g/L
Winter White: <273.767 g/L
Glaze Effects FAQs
*Does Glaze Effects Require Topcoat?
Absolutely. All stains and glazes require a sealant. Think of the stain or glaze as the color and the topcoat as protection.
Can Glaze Effects be sealed with wax instead of top coat?
Yes, you can use Satin Wax instead of top coat if you prefer. Although GF loves the look of wax, we recommend using top coat because wax is not as durable. Wax requires annual maintenance and it must be removed if you want to apply topcoat in the future.
*How Can I Create a Custom Glaze, Wash, Varnish or Stain?
  1. Applying a base layer of High Performance Top Coat before applying your custom glaze.
  2. Protect all of these finishes with 2-3 coats of top coat when you are finished.
PASTEL GLAZE/WHITEWASH:
Milk Paint + Winter White Glaze Effects OR Milk Paint + Water Based Whitewash Wood Stain
NOTE: Do not add more than 50% paint. If you add more than 50% you will have so much pigment that it will be difficult to wipe away the finish. **Do not mix Glaze Effects with Water Based Wood Stain.
CUSTOM GLAZE:
For example, Pitch Black Glaze Effects + Winter White Glaze Effects
WOOD STAIN AS A GLAZE:
Water Based Wood Stain + 10% High Performance Top Coat
OR
Oil Based Wood Stain + 10% Mineral Spirits
Note: Make sure that you wait 72 hours before applying a water-based topcoat on top of an oil-based stain.
AGED/VARNISH GLAZE:
Water Based Wood Stain  + High Performance Top Coat 50:50 ratio
OR
Dye Stain + High Performance Top Coat 50:50 ratio
CUSTOM STAIN COLORS:
1 part Milk Paint + 1 part Pre-Stain Natural [50:50 mix]
OR
1 part Milk Paint + 1 part Glaze Effects - Clear Base [50:50 mix]
OR
1 part Milk Paint +  2 parts Water Based Stain Natural [1:2 parts]
Note: Proportions are relative to the color you are reducing. Some colors may require 2 parts clear base to reduce strength, others may require 1. Begin with a 50:50 mix, and add more clear base if necessary.
You can further increase the color palette by mixing 2 or 3 Milk Paint colors together before adding the clear base.
CUSTOM GLAZE:
OR
AGED/VARNISH GLAZE:
OR
OR
OR
*Is Topcoat Required Between Gel Stain and Water Based Glaze Effects?
Yes - this is not a good place to take shortcuts. GF Gel Stain gets its deep rich hue from a large number of colorants. Seal the stain with a topcoat before applying glaze to prevent "color pull."
The glaze will also glide more easily over the surface after topcoat is applied, allowing you greater control of how much color you want to use. Be sure to wait 72 hours when applying water-based finishes over oil-based finishes.
Here is a sample finish schedule:
  1. Prep sand and clean
  2. Apply stain
  3. Apply a layer of topcoat to prevent color bleed thru and make glazing easier
  4. Apply Glaze Effects
  5. Apply 2-3 coats of topcoat to protect the entire project
