Butcher Block Oil
Butcher Block Oil is a natural protectant for all wood surfaces that come in contact with food. Use this oil-based finish on wood cutting boards, utensils, bowls and butcher blocks. The mineral oils used in General Finishes Butcher Block Oil meet all the requirements for use on wooden products that come in contact with food.
Download 2021 Retailer All Products Catalog here.
General Finishes Mineral Oil Based Butcher Block Oil, 16 oz Bottle
Step 1: Preparation for Butcher Block Oil
Preparation for New, Untreated Butcher Block
  1. Prep sand with 120-grit sandpaper.
  3. Do not over-sand with fine-grit sandpapers; this will close and seal the wood grain, preventing ideal product absorption.
Preparation of an Existing Surface that has Previously Been Treated with Butcher Block Oil
  1. Remove food residue using a pastry scraper or spatula to gently scrape areas where you find dried-on food or residue. Avoid gouging the wood by keeping the blade at an angle that just skims the surface.
  2. Scrub using a scrub brush, Scotch Brite Pad, or sponge and scrub the butcher block with hot water and mild dish soap.
  3. Rinse with hot water: Run a clean dishcloth through hot water and rinse several times.
  4. Dry thoroughly with a clean dish towel or paper towel.
  5. Let the surface dry overnight before applying another coat of Butcher Block Oil.
Step 2: How To Apply General Finishes Butcher Block Oil
General Finishes Butcher Block Oil Application Steps
  1. Apply 2 coats of Butcher Block oil with a soft cloth.
  2. Let the first coat soak in for half an hour and then wipe off the excess.
  3. Apply the second coat. Let it absorb into the raw wood for 5+ minutes, then wipe the surface completely dry with a clean cloth.
  4. Butcher Block Oil is a maintenance product. Regular applications are recommended to keep the surface stain-repellant and looking its best.
Cleanup of Butcher Block Oil
Clean application materials, hands or spills with mineral spirits.
Maintenance of Surfaces Treated with Butcher Block Oil
Wipe up food and water spills immediately. Do not leave standing water or wet materials on a butcher block. Never let cutting boards sit in a sink.
General Finishes Butcher Block Oil is a maintenance product. Regular applications are recommended to keep the surface stain-repellant and looking its best.
Storage of Maintenance Products
Maintenance products are best used within 1 year of the manufacture date listed on the bottom of the can. The following best practice will increase the life of your product:
Store in moderate temperatures of 50-100°F/10-38°C. Heat-damaged product cannot be revitalized. Temperature-controlled spaces, such as a basement, are ideal for storage. Do not store product in an attic, garage, in direct sunlight, or next appliances with heat or flame such as a furnace.
Ey protection: Safety eyewear complying with an approved standard should be used when a risk assessment indicates this is necessary to avoid exposure to liquid splashes, mists, gases, or dust. If contact is possible, the following protection should be worn unless the assessment indicates a higher degree of protection: safety glasses with side shields.
Product Colors Clear
Base Type Mineral Oil
Type Mineral Oil
Application Method Wipe On with Clean Rag
Dry Time - Recoat 5 minutes
Can Sizes 16 oz. bottles, Gallons
Weight Solids 100%
0 g/L
Butcher Block Oil FAQs
*What Finish Would You Recommend for a Butcher Block Counter Top?
It depends on the type of use you plan for your butcher-block top and the look you want.
If it is a statement piece and not intended for high use, almost any finish would work. General Finishes Arm-R-Seal Topcoat is a good choice. If you intend to prep or chop food General Finishes Butcher Block Oil should be applied.
However, neither product will withstand continuous water use or standing water, or hold up to knife cuts. We always use a cutting board just as we would on a standard kitchen counter. Basically, all horizontal wood surfaces in a kitchen must be maintained, and will easily wear with high water use.
Differences:
  • Butcher Block Oil is a maintenance product that should be reapplied over time. It has a lovely matte finish that soaks into the wood and is an excellent protectant for wood surfaces that come in contact with food. Simply wipe on, allow 5 minutes to penetrate and wipe off the excess. It can also be used on cutting boards, utensils, or bowls. It is one of our most popular finishes for butcher-block counters.
  • Arm-R-Seal is a fine furniture finish, offers several levels of sheen and is a durable finish. It has been successfully used on home bar projects with this caveat: no fine furniture finish is impervious to water. Spills must be wiped up in a timely manner.
For a more water-resistant finish, we recommend visiting a finish dealer that carries lines specifically designed for high water use such as an Epoxy or a professional two-step catalyzed finish such as General Finishes Conversion Varnish.
