Enduro-Var II is a reformulation of our original oil-modified, ambering, water-based topcoat. It replaces original Endurovar and is made with more than 70% RENEWABLE RESOURCES formulated from sustainable materials that decrease the carbon footprint and is compatible with ALL GF products. The newer environment-friendly formula dries to a lighter amber than the previous formula, is highly water-resistant, and is both sprayable and brushable. Learn more about General Finishes' entire finishing system of clear and pigmented primers, acrylic and polyurethane clears, pigmented topcoats and water-based stains here: 4 Reasons to Switch to Water-Based Finishes. See our spray tip size recommendations here. Download 2021 Professional Water Based Product Catalog here. Download 2021 Retailer All Products Catalog here.
Sanding Schedule: 120-grit followed by 150- or 220-grit sandpaper.
Remove dust with a vacuum, compressed air, an oil-free tack cloth or a water-dampened rag.
Let dry completely before applying GF product.
Do NOT use steel wool with water-based finishes; the particles will get trapped in the finish and rust.
Preparation for Projects with an Existing Sealed Surface 1. Completely remove existing finish prior to use.
2. Test entire finishing process over raw wood for adhesion before getting started. Contaminants from an existing finish can seep into the wood and impact results.
How to Apply General Finishes Enduro-Var Water Based Topcoat
CAUTION: Do not use over bright whites as the finish will yellow. Enduro-Var has a slight pink cast to the color in the can. This is normal. It will dry to a light amber color.
Stir topcoat thoroughly to reincorporate solids that have settled to the bottom of the can before and throughout the application process.
Test for adhesion.
Thinas desired with distilled water; start with 5%, adding up to 10% by volume.
Increase open time, if needed, with 10-15% General Finishes Extender if allowed by local regulations. GF Extender will improve flow and leveling and increase open time, which is helpful in dry climates.
Apply 3 coats. More coats will not improve durability.
Hand application: Apply a liberal amount of product using a synthetic bristle brush, foam brush, pad applicator, or roller along the wood grain with smooth, even strokes & light lap lines. Avoid pressure and back brushing. Lap lines will tighten down as they dry.
Spray application: Before spraying, strain topcoat through a fine-mesh filter. Spray wet films at 3-5-mil thickness. HVLP: 1.1mm-1.3mm spray tip, medium air cap. Verify tip sizes with your equipment supplier. See our spray tip size recommendations here. Keep your gun at a 90° angle, 6-8" from the surface. On large, flat areas, use wet, even patterns 6-8" wide. For narrow surfaces, reduce the fan pattern to 2-3" wide to reduce overspray. Overlap each pass 25% to conceal lines. Wear a full filter respirator (NIOSH/MSHA-approved) and work in a ventilated space. Visit this FAQ for more information on spraying techniques.
Finish sand between coats with a fine-grade (220-320) foam sanding pad to improve smoothness and adhesion.
Enduro-Var Ambers
General Finishes Enduro-Var is water-based, but it imparts a warm amber tone and brings out grain definition as a traditional solvent urethane would on exotic woods such as Paduk, Cocobolo, and Bubinga.
Tinting & Toning Enduro-Var
Enduro-Var II can be used as a toner by mixing by volume with 5- 10% General Finishes Dye Stain or to enhance color tone. General Finishes Amber Dye Stain or General Finishes Vintage Cherry Dye Stain work well, or a 50:50 combination of both. Apply 2 coats of the tinted topcoat for a deeper, more vibrant color.
Dry 2+ hours between coats in ideal conditions: 70*F/20°C; 50-70% humidity.You can tell if a water-based finish is dry if it forms a powder when lightly sanded with a fine-grade (220-320) foam sanding pad. If in doubt, wait longer. Inadequate dry time can trap moisture and cause clouding. Cooler temperatures, high humidity and sealed substrates may prolong dry time.
Humidity is over 80%
3+ coats are applied
Thick coats are applied
Applying over products from other brands
Layering General Finishes water and oil based products:
Water over oil: Let oil-based products dry 72+hr before applying water-based products
Oil over water: Let water-based products dry 24+hr before applying oil based products
To speed up drying in humid conditions add General Finishes Accelerator and work in a space with good ventilation and air movement. If you decide to re-coat before the recommended time, test dryness.
Cure Time Before Use
Water-based finishes cure and harden for full use after 21 days in ideal conditions. Avoid placing heavy objects on surfaces that have not cured completely. Treat gently, and do not clean with commercial products during the curing period.
Please be mindful of the manner in which water-based products are stored and how long they have been in storage. They not a forever product.
Water-based products do not last forever, even when unopened. General Finishes products are best used within 1 year. However, the life of the product may be extended several more years with proper care and storage (see Storage Tips below).
Product that is 3 years old will not look like product that is 6 months to 1 year old. You will see more stratification or separation as the product ages. Always stir thoroughlybefore using.
Foul Smell
Water-based finishes crystalize and form a skin due to evaporation when the air-tight seal on a can is broken at first use. The following best practices will increase the life of your product:
Remove dust with a water-dampened cloth. Dust can build up over time and may scratch or dull finishes if not removed regularly.
Remove fingerprints, cooking fumes and smoking residue with mild soap and water. These contaminants will not harm the finish, but they accumulate on surfaces and dull the original luster.
As with all fine furniture finishes, avoid using furniture polish, cleaners or dusting sprays that contain silicone, alcohol, ammonia and anything acidic. Exception: We have successfully cleaned with Clorox wipes for occasional cleanups.
Clean up water, alcohol and food spills in a timely manner and use placemats & coasters to protect the finish.
Future finishes or touch-ups may not adhere properly or perform as desired over a contaminated surface. Some contaminants, such as silicone, seep through finish into the wood and often cannot be removed.
Avoid excessive exposure to direct sunlight, high temperatures or high humidity. These can damage furniture and finishes.
FIRST AID: Seek immediate medical attention if symptoms occur due to the following. EYE CONTACT: Remove any contact lenses. Flush eyes with water for 20+ minutes while lifting upper and lower eyelids. SKIN CONTACT: Wash skin immediately upon contact. Remove contaminated shoes and clothing; clean and wash before re-use. INHALATION: Move to fresh air and loosen clothing. If not breathing, if breathing is irregular or if respiratory arrest occurs, provide artificial respiration or oxygen by trained personnel. INGESTION: Call physician immediately. Wash out mouth with water. Do not induce vomiting unless directed to do so by medical personnel. Never give anything by mouth to an unconscious person.
Prop 65 WARNING: This product can expose you to N-methyl-2-pyrrolidone, which is known to the State of California to cause birth defects or other reproductive harm. For more information go to www.P65Warnings.ca.gov.
Flat:
Keep out of the reach of children. Use only with adequate ventilation. Do not swallow. Do not get on skin or clothing. Avoid contact with eyes. Avoid breathing vapor or mist. Keep container tightly closed when not in use. Wash thoroughly after handling.
Satin, Semi-Gloss, Gloss:
DANGER CAUSES SEVERE EYE AND SKIN BURNS. HARMFUL IF SWALLOWED. CAUSES RESPIRATORY TRACT IRRITATION.
Keep out of the reach of children. Use only with adequate ventilation. Do not swallow. Do not get in eyes or on skin or clothing. Avoid breathing vapor or mist. Keep container tightly closed when not in use. Wash thoroughly after handling.
Product Colors
Dries Amber
Base Type
Water
Ambering
Yes
Sheen
Flat (10 or less), Satin (25-35), Semi-Gloss (50-60), Gloss (80+)
Enduro Clear Poly is slightly more durable than High Performance in the categories of wear, water, and chemical resistance.
Even though Enduro Clear poly is more durable and more water resistant than High Performance, High Performance is extremely durable and also recommended for high-use surfaces like kitchen cabinets and table tops.
Both products can be sprayed
High Performance can also be applied by hand with a foam/bristle brush.
Clear Poly and High Performance are both Urethane/Acrylic blends.
High Performance is sold in Pints, Quarts & Gallons by GF Retailers, Clear Poly is Gallon, 5-gallon pails and 55-gallon drums by GF Distributors. Cost is determined by Retailer/Distributor.
Our first concern is the use of the epoxy. Although you have may had success with this process previously, we do not recommend the use of Enduro-Var with epoxy or any oil based products. Enduro-Var works well on its own or with GFs water based finishes. There is a great possibility that future finishes can fail.
Nor do we recommend adding denatured alcohol, which should not be used in any of General Finishes water based products. Denatured alcohol can change the polarity of a finish formula, kicking out polymer particles that would look like grit on the surface. Denatured alcohol could also deactivate the defoamers in the formula.
The use of Extender won't help you. It is a water based product and will not melt through existing layers of finish in the same manner that solvent finishes do.
We interpret that you are trying to remove witness lines which are basically sanding marks. For your current situation, we recommend attempting to build the area with just Enduro-Var, then buffing out with a 2000-3000 grit. You may have to sand down and start over if that is not successful.
Future forward. Use Enduro-Var on its own. Although it is a favorite among Luthiers, it is a unique hybrid finish that does not pay well with other finishes.
Enduro-Var sprays beautifully if the gun is absolutely clean and does not have any other finish residue. Proper cleaning with acetone followed with hot water should purge the fluid passage. Enduro-Var itself will not cause gun failure.
Another possibility is the power of the gun. Some of the lower quality guns can overheat causing the product to cure in the gun - they need a rest once in a while if you are using them all day.
Also note that Enduro-Var ADHERES WELL only over WATER STAINS, DYE STAINS, and RAW WOOD.
PRE SEALING:
Milk Paint: 1.8mm-2.0mm
Brushable White Enamel 1.8mm-2.0mm
Stain Blocker: 1.8mm-2.0mm
Pearl Effects: 1.8mm-2.0mm
Glaze Effects: 1.8mm-2.0mm
Enduro-Var 1.1mm-1.3mm
SPRAYING TOPCOATS:
All of General Finishes water-based topcoats with the exception of Conversion Vanish can be tinted to create lightly colored finishes for toning. It is YOUR RESPONSIBILITY TO TEST to your satisfaction before application to your entire project.
There are limits anytime you add pigments or dyes to water-based topcoats. Toning should always be done in small increments to achieve the desired color. If you are starting with a light honey tone door and you want to create an Espresso color this will take multiple coats of color including base coat of stain followed by several toning coats. It is impossible to achieve a radical change in color in coat application.
A good rule to follow when toning is starting with a minimal amount of stain or dye, 5-10% by volume. Some colors work better than others. Normally 1-2 ounces or stain per quart of clear topcoat is sufficient to create a toner. Always test color first and strain material through a fine mesh filter to remove any undissolved particle of pigment. Once you have achieved the desired color tone apply a clear topcoat to lock in the color.
Oil based topcoats and Enduro-Var will amber over time.
Water based Flat Out Flat and High Performance top coats dry clear.
Never use any water based topcoat with long oils such as Danish, Tung or Linseed.
Water based top coats clean up with water. Oil based topcoats require mineral spirits for clean up.
Original formula of Enduro-Var ADHERES WELL only over WATER STAINS, DYE STAINS, and RAW WOOD. The new formula of Enduro-Var II is compatible with all GF products.
If you use water based topcoats over oil based finishes, make sure that you wait 72 hours between the two products. It is essential to let the oil finish dry longer.
For more complex projects that have a lot of nooks and crannies or projects with large surface areas such as cabinets, we recommend either ARM-R-SEAL liquid oil based topcoat or any of our water based topcoats. Large surfaces such as cabinets or tables and complex projects with lots of detail are easier to cover with liquid topcoat rather than a Gel top coat.
Enduro Professional Topcoats are thinner and intended to be sprayed
High Performance and Flat Out Flat can also be sprayed. If needed, it can be thinned by adding 5-10% distilled water.
