Enduro Professional Water-Based Tintable 2K Clear Poly
For today's professional, industrial and OEM users, water-based Tintable 2K Clear Polyurethane is formulated to stop your biggest frustrations and provide ultimate durability for interior/exterior use. Key features are easy application, fast film build & production time, excellent adhesion, plus optimum water & chemical resistance. We go hard for great chemistry, so you don't have to worry when your clients are tough on the paint. Paired with Tintable 2K White Poly, you have a dynamic duo of tintable 2 component polyurethane finishes, our most durable interior/exterior coatings. You can apply confidently, knowing that you are giving your customer the best the industry offers. Perfect for new or remodeled cabinets, furniture, woodwork, pre-primed steel, fiberglass, and exterior projects. REQUIRES NCO CATALYST. Made in the U.S.A by General Finishes.
General Finishes Water Based Topcoat Enduro Tintable 2K Clear Polyurethane
Step 1: Surface Preparation Enduro Professional Tintable 2K Poly
Raw wood
Sealed Surface
  2. Dry 1-2 hours.
  4. Remove Dust
Other substrates such as fiberglass and pre-primed steel
  1. Can be used with proper preparation & priming.
  2. Always test for performance before proceeding with your project.
Step 2: Priming
CAUTION: Do NOT use Enduro 2K Clear or any clear topcoat over white paint, as it may cause yellowing.
2K WHITE POLY PRIMING RECOMMENDATIONS:
INTERIOR RAW WOOD: 2K White Poly is designed to adhere to raw wood. Can be used without a sealer.
SEALED SURFACE: When applying 2K White Poly over an existing sealed surface, ALWAYS PRIME with Enduro White Undercoat for interior/exterior use or GF Stain Blocker for interior projects where tannin bleed-through is a concern.
2K CLEAR POLY PRIMING RECOMMENDATIONS:
INTERIOR RAW WOOD & STAINED SURFACES: 2K Clear Poly is designed to adhere to raw wood and newly stained wood. Can be used without a sealer. Use 1-2 coats of Enduro Sanding Sealer for an improved build. 3-4 total coats are recommended.
SEALED SURFACE: If tinted and applying over an existing sealed surface, ALWAYS PRIME with Enduro White Undercoat or Enduro Deep Base Primer for interior/exterior use or Enduro Stain Blocker for interior projects.
Disclaimer
Although Stain Blocker is engineered to prevent the most persistent bleed-through when 2 coats are applied, General Finishes cannot guarantee the prevention of bleed-through or yellowing on every project. Unknown factors and assiduous bleed-through can impact results. Stain Blocker is the most robust option and has performed extremely well in our tests.
Step 3: How To Apply General Finishes 2K Clear Poly
Enduro Tintable 2K Clear Poly is a post-catalyzed, high-solids, two-component urethane formulated for ultimate durability and chemical resistance and requires General Finishes Enduro NCO Catalyst. READ PROTECTION INSTRUCTIONS IN WARNINGS SECTION BELOW BEFORE USE.
Download 2024 Professional Water-Based Product Catalog Here
Enduro Tintable 2K Clear Poly Application Steps
  2. Stir thoroughly to reincorporate solids that have settled to the bottom of the can using a power drill and mixer (recommended) or by hand with a paint stick. Do not shake. See this video here: How To Mix 2K Conversion Varnish
  3. Test for adhesion when applying over an existing finish.
  4. Thin as desired, with distilled water (after mixing with NCO catalyst); slowly add up to 10% by volume.
  5. Increase open time, if needed, with 10-15% by volume of Enduro Extender if allowed by local regulations. GF Extender can be used to improve flow and leveling, and increase open time, which is helpful in dry climates. California Residents: Adding more than 2% of GF Extender will make the product non-compliant per SCAQMD Regulations. GF assumes no liability for the improper use of these products.
  6. Slowly add up to 10% NCO Catalyst by volume (3.2 oz. per quart; 12.8 oz. per gallon) while stirring thoroughly. Mix 2-3 minutes with a power drill. Use gloves and protective eyewear when mixing. Mix only what you are going to use and clean spray gun immediately after use with Brush and Gun Cleaner. The finish can only be mixed once, and the leftover product will solidify after 4 hours. Pot life will vary by colorant dosage and manufacturer. DO NOT store in a closed container to avoid pressure build-up.
  7. Let rest for 15 minutes.
  8. Apply 2-3 coats or 3-4 total coats if using Enduro Sanding Sealer for an improved build. Additional coats will not improve durability.
    • Spray application: Before spraying, strain through a fine-mesh filter. Spray wet films at 3-5-mil thickness.
    • HVLP: 1.1mm-1.3mm spray tip, medium air cap.
    • AIR-ASSIST AIRLESS: 375 PSI pump, 20 PSI assist air, .011”-.013” tip.
    • AIRLESS: Fine Finish .007” - .011”. Verify tip sizes with your equipment supplier. Spray tip recommendations. Keep your gun at a 90° angle, 6-8" from the surface. On large, flat areas, use wet, even patterns 6-8" wide. For narrow surfaces, reduce the fan pattern to 2-3" wide to reduce overspray. Overlap each pass 25% to conceal lines. NOTE; 2K Clear Poly is used with NCO catalyst. When using a spray gun, wear self-contained breathing apparatus. In the event of insufficient ventilation: Wear self-contained breathing apparatus. When respirators are required, select NIOSH/MSHA-approved equipment and work in a ventilated space. READ ALL PROTECTION INSTRUCTIONS IN THE WARNINGS SECTION BEFORE USE.
  9. If a faster build is desired over raw wood, use 1-2 coats of  Enduro Sanding Sealer, followed by 2 coats of 2K Clear Poly.
  10. Finish sand between coats with a fine-grade (220-320) foam sanding pad or gray non-woven abrasive pad to improve smoothness and adhesion.
  11. Remove dust with a vacuum, compressed air, an oil-free tack cloth or a water-dampened rag.
Tinting
Tinting
Dry Time Tintable 2K Polys
Dry Times Based on ideal conditions of 70°F/21°C; 50% humidity.
Dry-time (touch): 30 minutes
Dry-time (recoat): 30 minutes -2 hours based on heat & airflow.
Cure-time: 5 days
Be sure to allow adequate dry time. You can tell if a water-based finish is dry if it forms a powder when lightly sanded with a fine-grade (220-320) foam sanding pad or 400-grit sandpaper. If in doubt, wait longer. Rushing the dry time can cause "blush," which is clouding in the finish due to moisture trapped between the layers.
  • Temperatures are cooler.
FORCE DRY: Allow product to flash for 10 minutes at ambient temperature. INFRARED LAMP / OVEN: Heat surface to 105°F/41°C. Allow cooling before sanding. Allow a minimum of 30 minutes between coats.
Buffing 2K
The surface an be buffed after the finish has cured using wet/dry automotive sandpaper. Use GF Satin Finishing Wax as lubricant.
Do NOT use water.
Cleanup Tintable 2K Polys
Clean hands with soap and water. Clean equipment with General Finishes Brush & Gun Cleaner immediately after use.
Discard unused product and waste in an environmentally safe manner; check with local fire and health regulations. Do not pour down drains.
Sheen Flat (10 or less), Satin (25-35), Semi-Gloss (50-60), Gloss (90+)
Tintable Yes
Type Urethane
Suggested Use
New or remodeled cabinets, furniture, woodwork, pre-primed steel, fiberglass, and exterior projects. If tinting and applying over a painted surface, be sure to prime and test before completing your entire project.
Coats 2 - 3 coats
Application Method Spray
Brushable No
Air-Assist Airless 375 PSI pump, 20 PSI assist air, .011”-.013” tip
Airless Fine Finish .007” - .011”
Dry Time - Recoat 1+ hr
Dry Time - Light Use N/A
Dry Time - Cure 5 days
Dry Time - Recoat - Applied Over Oil Based Product 72
Can Sizes Gallons, 5 Gallon pails
Viscosity Thick
Viscosity (cPs) 1000-1500
Weight Solids 29%
Flat: 33%
Satin: 30%
Semi-Gloss: 28%
Gloss: 28%
Solids by Volume
Flat: 30%
Satin: 28%
Semi-Gloss: 26.5%
Gloss: 26%
Flat: < 215 g/L
Satin: < 215 g/L
Semi-Gloss: < 200 g/L
Gloss: < 215 g/L
Durability (Highest, High, Medium, Low) Highest
Hardness (Koenig #) 125
Wear (Taber #) 35.00 mg loss
Chemical (105 max) 101
What makes 2K Professional-Industrial-OEM coatings really perform?
Photo of Tintable-2K-dark-color-Under IR
Photo of Enduro Tintable 2K Clear and 2K White Poly
A high-performance 2K coating has a base specifically formulated to be catalyzed with Isocyanates to crosslink the polymer fully. This catalyst provides superior performance over 1 K coatings that have been hardened with PolyAzuradine or Carbodiiamide. To create Enduro Tintable 2K; General Finishes tested over 30 polymers, resins, and other ingredients sourced from around the world. These new coatings are engineered to prevent the biggest frustrations for today's professional, industrial and OEM users providing ultimate durability for interior/exterior use. General Finishes goes hard for great chemistry, so you don't have to worry when your clients are tough on the paint. Paired with Tintable 2K Clear Poly, you have a dynamic duo of 2 component finishes, the most durable interior/exterior coatings General Finishes has ever created. You can apply confidently, knowing that you are giving your customer the best the industry offers. Perfect for new or remodeled cabinets, furniture, woodwork, pre-primed steel, fiberglass, and exterior projects. Made in the U.S.A.
KEY FEATURES
  1. Ease of application. Whether in a shop or on-site, Enduro 2K is designed to flow and level for Professionals/Industrial users that apply with AAA, HVLP, Airless, or flatline systems.
  2. Tintable to any major manufacturer's color deck. Enduro 2K hits the deepest darks, the bright whites, and everything in between. General Finishes recommends ColourFal Zero colorants.
  3. Higher gloss standards for white and clear, with 90+ degrees on a 60-degree angle.
  4. Fast production time: You can spray 3-4 coats of Enduro 2K and sand in between coats in one day. Enduro 2K cures for use in 5 days.
  5. Fast film build: Enduro 2K'S are engineered with a combo of larger and smaller-sized resin particles, which, when combined with the catalyst, allows for a thicker, quicker film build than any 1K. It provides a better vertical hang when spraying built-in surfaces on-site, with fewer drips or sags.
  6. Water and chemical resistance: Combining our new resin with catalyzation allows Enduro 2K to hit a commercial level of water and chemical resistance that *exceeds industry requirements and guidelines”. This is the perfect coating to stand the test of time on Wisconsin bar tops.
  7. Excellent adhesion properties on properly cleaned and prepped wood, plastics, fiberglass, and pre-rimed steel. (It Sticks).
  8. Exterior use: This new finish has an unusual balance of durability and flexibility, making it the professional’s choice for outdoor projects such as doors, benches, furniture, and tables. Do not use on deck surfaces.
  9. Consistency. General Finishes prides itself on superior quality control to meet and exceed the customer’s expectations.
Available in Flat, Satin, Semi-gloss, and Gloss
Which General Finishes Coatings are suitable for OEM applications?
Enduro Tintable 2K Poly by General Finishes
Photo of Tintable 2K Poly under IR Light
If you have interest, inquire here to be contacted by a rep: We currently provide coatings and finishes for the following markets:
  • Wood Flooring
  • Kitchen Cabinets
  • Windows, Doors, and Millwork
  • Furniture
  • Specialty Wood Applications
  • Pre-primed Steel, Plastics, and Fiber Glass
General Finishes offers 6 stock water-based coatings in the OEM market space:
  1. Enduro Tintable 2K White Poly
  2. Enduro Tintable 2K Clear Poly
  3. Enduro 2K Conversion Varnish
  4. Enduro Clear 1K Poly
  5. Enduro Pre-Cat Lacquer
  6. Enduro RTM Stains
Our newest addition, Enduro Tintable 2K White Poly and Tintable 2K Clear Poly, offers the following features and functionality:
  1. Ease of application. Whether you’re in a shop or on-site, Enduro 2K was designed to flow and level for users applying with AAA, HVLP, Airless, or flatline systems.
  2. Tintable to any major manufacturer's color deck. Enduro 2k hits the deepest darks, the bright whites, and everything in between.
  4. Fast production time: You can spray 3-4 coats of Enduro 2K and sand in between coats in one day. Enduro 2K cures in 5 days.
  5. Fast film build: Enduro 2k is engineered with a combo of larger and smaller-sized resin particles, which, when combined with the catalyst, allows for a thicker, quicker film build than any 1k. It provides a better vertical hang when spraying built-in surfaces on-site, with fewer drips or sags.
  6. Water and chemical resistance: Combining our new resin with catalyzation allows Enduro 2k to hit a commercial level of water and chemical resistance that *exceeds industry requirements and guidelines”. This is the perfect coating to stand the test of time on high-use projects.
  7. Excellent adhesion properties on properly cleaned and prepped wood, plastics, fiberglass, and Pre-Primed steel. (It Sticks).
  8. Exterior use: This new finish has an unusual balance of durability and flexibility, making it the choice for outdoor projects such as doors, benches, furniture, and tables. Do not use on deck surfaces.
  • Enduro Professional 1K Black Poly
  • Enduro Professional Pro Series Clear Poly
  • Enduro Professional Pro Series White Poly
  • High Performance Topcoat
  • Flat Out Flat Topcoat
  • Enduro-Var II Topcoat
  • Exterior 450 Topcoat
  • Wood Turners Finish
  • Exterior 450 White
  • Arm-R-Seal
  • Seal-A-Cell
  • Gel Satin Topcoat
  • Wood Bowl Finish
  • Butcher Block Oil
  • Outdoor Oil
  • Hard Wax Oil
GENERAL PRACTICE:
  1. Oil-based topcoats and ENDURO-VAR II will amber over time.
Compare all topcoats
