Enduro Professional Water-Based Tintable 2K White Poly
Water-based Tintable 2K White Polyurethane is engineered to address the biggest frustrations for today's professional, industrial, and OEM users, providing ultimate durability for interior/exterior use. Key features are easy application, fast film build & production time, excellent adhesion, plus optimum water and & chemical resistance. We go hard for great chemistry, so you don't have to worry when your clients are tough on the paint. Paired with Tintable 2K Clear Poly, you have a dynamic duo of the most durable interior/exterior coatings General Finishes has ever created. You can apply confidently, knowing that you are giving your customer the best the industry offers. Perfect for new or remodeled cabinets, furniture, woodwork, pre-primed steel, fiberglass, and exterior projects. Requires NCO Catalyst. Made in the U.S.A. by General Finishes. 2K White Poly is short-filled 10%, allowing room for tinting colorant.
General Finishes Enduro Tintable 2K White Poly from General Finishes for Industrial and OEM
Tinting
Step 1: Surface Preparation Enduro Professional Tintable 2K Poly
Raw wood
Sealed Surface
  2. Dry 1-2 hours.
  4. Remove Dust
Other substrates such as fiberglass and pre-primed steel
  1. Can be used with proper preparation & priming.
  2. Always test for performance before proceeding with your project.
Step 2: Priming
CAUTION: Do NOT use Enduro 2K Clear or any clear topcoat over white paint, as it may cause yellowing.
2K WHITE POLY PRIMING RECOMMENDATIONS:
INTERIOR RAW WOOD: 2K White Poly is designed to adhere to raw wood. Can be used without a sealer.
SEALED SURFACE: When applying 2K White Poly over an existing sealed surface, ALWAYS PRIME with Enduro White Undercoat for interior/exterior use or GF Stain Blocker for interior projects where tannin bleed-through is a concern.
2K CLEAR POLY PRIMING RECOMMENDATIONS:
INTERIOR RAW WOOD & STAINED SURFACES: 2K Clear Poly is designed to adhere to raw wood and newly stained wood. Can be used without a sealer. Use 1-2 coats of Enduro Sanding Sealer for an improved build. 3-4 total coats are recommended.
SEALED SURFACE: If tinted and applying over an existing sealed surface, ALWAYS PRIME with Enduro White Undercoat or Enduro Deep Base Primer for interior/exterior use or Enduro Stain Blocker for interior projects.
Disclaimer
Although Stain Blocker is engineered to prevent the most persistent bleed-through when 2 coats are applied, General Finishes cannot guarantee the prevention of bleed-through or yellowing on every project. Unknown factors and assiduous bleed-through can impact results. Stain Blocker is the most robust option and has performed extremely well in our tests.
Step 3: How To Apply General Finishes 2K White Poly
Enduro Tintable 2K White Poly is a post-catalyzed, high-solids, two-component urethane formulated for ultimate durability and chemical resistance and requires General Finishes Enduro NCO Catalyst. READ PROTECTION INSTRUCTIONS IN WARNINGS SECTION BELOW BEFORE USE.
Download 2024 Professional Water-Based Product Catalog Here
Enduro Tintable 2K White Poly Application Steps
  2. Stir thoroughly to reincorporate solids that have settled to the bottom of the can using a power drill and mixer (recommended) or by hand with a paint stick. Do not shake. See this video here: How To Mix 2K Conversion Varnish
  3. Test for adhesion when applying over an existing finish.
  4. Thin as desired, with distilled water (after mixing with NCO catalyst); slowly add up to 10% by volume.
  5. Increase open time, if needed, with 10-15% by volume of Enduro Extender if allowed by local regulations. GF Extender can be used to improve flow and leveling, and increase open time, which is helpful in dry climates. California Residents: Adding more than 2% of GF Extender will make the product non-compliant per SCAQMD Regulations. GF assumes no liability for the improper use of these products.
  6. Slowly add up to 10% NCO Catalyst by volume (3.2 oz. per quart; 12.8 oz. per gallon) while stirring thoroughly. Mix 2-3 minutes with a power drill. Use gloves and protective eyewear when mixing. Mix only what you are going to use and clean spray gun immediately after use. The finish can only be mixed once, and the leftover product will solidify after 4 hours. Pot life will vary by colorant dosage and manufacturer. DO NOT store in a closed container to avoid pressure build-up.
  7. Let rest for 15 minutes.
  8. Apply 2-3 coats or 3-4 total coats if using Enduro Sanding Sealer for an improved build. Additional coats will not improve durability.
    • Spray application: Before spraying, strain through a fine-mesh filter. Spray wet films at 3-5-mil thickness. HVLP: 1.1mm-1.3mm spray tip, medium air cap. AIR-ASSIST AIRLESS: 375 PSI pump, 20 PSI assist air, .011”-.013” tip. AIRLESS: Fine Finish .007” - .011”. Verify tip sizes with your equipment supplier. Spray tip recommendations. Keep your gun at a 90° angle, 6-8" from the surface. On large, flat areas, use wet, even patterns 6-8" wide. For narrow surfaces, reduce the fan pattern to 2-3" wide to reduce overspray. Overlap each pass 25% to conceal lines. NOTE; 2K White Poly is used with NCO catalyst. When using a spray gun, wear self-contained breathing apparatus. In the event of insufficient ventilation: Wear self-contained breathing apparatus. When respirators are required, select NIOSH/MSHA-approved equipment and work in a ventilated space. READ ALL PROTECTION INSTRUCTIONS IN THE WARNINGS SECTION BEFORE USE.
  9. If a faster build is desired over raw wood, use 1-2 coats of  Enduro Sanding Sealer, followed by 2 coats of 2K White Poly. No more than 3-4 total coats of finish is recommended.
  10. Finish sand between coats with a fine-grade (220-320) foam sanding pad or gray non-woven abrasive pad to improve smoothness and adhesion.
  11. Remove dust with a vacuum, compressed air, an oil-free tack cloth or a water-dampened rag.
Tinting
Dry Time 2K Polys
Dry Time Based on ideal conditions of 70°F/21°C; 50% humidity.
Dry-time (touch): 30 minutes
Dry-time (recoat): 30 minutes -2 hours based on heat & airflow.
Cure-time: 5 days
Be sure to allow adequate dry time. You can tell if a water-based finish is dry if it forms a powder when lightly sanded with a fine-grade (220-320) foam sanding pad or 400-grit sandpaper. If in doubt, wait longer. Rushing the dry time can cause "blush," which is clouding in the finish due to moisture trapped between the layers.
  • Temperatures are cooler.
    • Water over oil: Let oil-based products dry 72+hr before applying water-based products
FORCE DRY: Allow product to flash for 10 minutes at ambient temperature. INFRARED LAMP / OVEN: Heat surface to 105°F/41°C. Allow cooling before sanding. Allow a minimum of 30 minutes between coats.
Buffing 2K
The surface an be buffed after the finish has cured using wet/dry automotive sandpaper. Use GF Satin Finishing Wax as lubricant.
Do NOT use water.
Cleanup For 2K Polys
Clean hands with soap and water. Clean equipment with General Finishes Brush & Gun Cleaner immediately after use.
Discard unused product and waste in an environmentally safe manner; check with local fire and health regulations.  Do not pour down drains.
Product Colors White, Tintable
Sheen Flat (10 or less), Satin (25-35), Semi-Gloss (50-60), Gloss (85+)
Tintable Yes
Type Urethane
Suggested Use
Interior or exterior application: raw wood, stained wood, cabinets, trim, doors, furniture, table tops & bar tops, fiberglass & pre-primed steel. If using over painted surfaces, especially white, prime and test first before completing your project.
Coats 2 - 3 coats
Application Method Spray
Brushable No
Air-Assist Airless 375 PSI pump, 20 PSI assist air, .011”-.013” tip
or
409 tip. 1000 psi fluid with 18 psi air
Airless Fine Finish .007” - .011”
or
Airless .308 FFLP Tip at low pressure
Dry Time - Recoat 1+ hr
Dry Time - Cure 5 days
Dry Time - Recoat - Applied Over Oil Based Product 72
Can Sizes Gallons, 5 Gallon pails
Viscosity Thick
Viscosity (cPs) 1000-1500
Weight Solids 45%
Solids by Weight and Volume Solids by
weight
Flat: 46%
Satin: 44%
Semi-Gloss: 43%
Gloss: 42%
Solids by Volume
Flat: 35%
Satin: 32%
Semi-Gloss: 31%
Gloss: 30%
VOC <200 g/L. Varies by color. See color-specific SDS for exact number.
Durability (Highest, High, Medium, Low) Highest
Hardness (Koenig #) 125
Wear (Taber #) 35.00 mg loss
Chemical (105 max) 101
