Water-Based Dye Stain Reducer
Dye Stain Reducer is the clear base we use when manufacturing General Finishes Dye Stain and can be used to make custom Dye Stain colors by mixing with GF water base stains. It can also be used to layer color under other water or oil base stains. Stain Reducer is a PFAS-free coating, and as General Finishes strives for a cleaner and healthier environment, all future product development will be free of “Forever Chemicals."
General Finishes Dye Stain Reducer, Quart
How To Use General Finishes Dye Stain Reducer
Join General Finishes University Facebook Group for customer support and learning opportunities for GF products. This group is a great resource for guidance regarding choosing the right product, mastering finishing techniques, troubleshooting, or sharing your finished projects.
General Finishes Dye Stain Reducer is the clear base we add dye to when manufacturing our Dye Stains.
Creating A Custom Color
Add 10% increments of Dye Stain Reducer to General Finishes Dye Stain or General Finishes Water Based Wood Stain until you achieve your desired color. Any percentage of stain or reducer can be added. Do NOT mix with oil based stains or sealers.
NOTE:
Dye Stain Reducer will lighten the color and thin the viscosity of thicker stains.
Using Dye Stain with a Pre-Stain Conditioner (Preferred)
Control even penetration of Dye Stain by applying a coat of Water Base Pre-Stain Conditioner over raw wood before using Dye Stain. Dye Stain Reducer could also be used, but Pre-Stain Conditioner is recommended.
Creating Custom Colors Using Dye Stain Reducer and Transtint Dye
We recommend using GF TransTint dye concentrates starting with 1-2 ounces of TransTint dye per quart of Dye Stain Reducer to create a toner. For subtle color changes, you can also use a percentage guideline- typically 5-10% dye by volume in the topcoat.
You can also use Dye Stain reducer with other manufacturer's dyes.
Always test your entire procedure, preparation through to topcoat, for adhesion and aesthetics on a hidden area of your project before mixing or layering products made by different manufacturers.
Dry 2+ hours between coats & before GF water-based stain or topcoat in ideal conditions: 70°F/20°C; 50% humidity. Cooler temperatures & higher humidity may prolong dry time. Dry 24+ hours before applying GF oil-based products.
Do NOT Use Water to Lighten General Finishes Dye Stains.
Dye Stain Reducer has ingredients that help keep color molecules dispersed evenly in the can.
Storage of Dye Stain Reducer
Water based products do not last forever, even when unopened. General Finishes products are best used within 1 year of the manufacture date listed on the bottom of the can. The life of the product may be extended with proper care and storage.
See our video: Tips on Storing Leftover Finishes
  3. Clean the chime of the can thoroughly with a paper towel before closing to create a complete seal. Paint in the chime can be minimized by using a pouring lid, such as Fitsall. Avoid wiping used brushes on the lid.
  5. Store in moderate temperatures. Avoid temperatures below 50°F/10°C or above 100°F/26°C. Frozen and heat-damaged product cannot be revitalized. Temperature-controlled spaces, such as a basement, are ideal for storage. Do not store product in an attic, garage, in direct sunlight, or next to something warm like a water heater or furnace.
  • Dye Stain Reducer + Dye Stain
  • Dye Stain Reducer + Water Based Wood Stain
  • Dye Stain + Water Based Wood Stain + Dye Stain Reducer
Test storage effectiveness first:
  • Dye Stain Reducer + Another Manufacturer's Dye
Dye Stain Reducer Warnings and Warranties
WARNING: Keep out of reach of children. Keep container tightly closed when not in use. Wash thoroughly after handling.
Product Colors Clear
Type Water Based Stain
Application Method Brush, Spray
Usable over existing finishes No
Coverage 60-80 sq.ft./pint, 120-160 sq.ft./quart, 480-640 sq.ft./gallon
Viscosity Very Thin
Weight Solids 11%
447.562 mg/L
*How Do I Correct Color Lift when Applying High Performance Over GF Water Based Dye Stain?
It is normal to see a bit of stain on the brush when applying the first coat of topcoat. Topcoats often pull a bit of color on the first pass, but good preparation will minimize this.
To prepare open grains woods such as raw Oak for a water-based stain, we recommend sanding with 180-grit followed by no more than 220-grit sandpaper.
300-grit or 400-grit sandpaper is too fine for preparing raw wood. Too fine of a grit changes the wood from a porous surface to one that is too smooth to absorb the stain, which causes the first top coat application to pull excessive color (it is like trying to apply stain to glass).
There is always a small amount of color pull when using water-based stains, but the smooth surface escalates this condition. This was evident in the areas that you used the brush to remove excess topcoat.
See recommended sanding schedules here.
Instructional Video: How to Prep Sand New or Raw Wood
Here are some options to try. Always test a small area before proceeding with your entire project.
  1. TONING: Lightly sand the light areas with a 220-grit sanding foam pad to open up the pores of the wood.
    Create a toning mix of 10-20% Dye Stain to 80-90% topcoat. Using a small brush, apply this mix over the light areas to blend with the darker areas.
    Let this dry 3-4 hours. Then apply another coat of the mix over the entire surface. If this is successful, then apply 2-3 coats of the topcoat.
  2. GLAZING: Glaze the light areas. This will change the look of your doors but is an easier remedy.
  3. START OVER: Optimally, you should sand down to bare wood and start over with this prep sanding schedule indicated able.
    You can apply the Dye Stain directly to the wood, or mix in 10% topcoat to help lock in the color.
*Why or When Should I Use a Dye Stain?*
  1. Use dye stain when you have beautiful wood grain, pattern or burl and you want to show it off! GF Dye Stains are like ink and penetrate deep into the wood grain, revealing the figure of the wood with beautiful transparency.
  2. They are a great way to layer and intensify color. We often use a yellow or amber dye stain under another type of darker stain, such as Yellow Dye Stain under Java Gel Stain. The combined colors create a lovely depth and glow.
  3. Dye stains create a brilliantly colored project while maintaining the look of the wood. They come in a range of colors from traditional wood tones to brilliant primaries and can be applied to raw wood or combined with clear coats to make a toner.
Look at this piece that Jilian Moncada of ReFind Design by Coco Clare shared. When Jilian discovered this elegant burled wood under the old finish, she wrote and asked what to use - we recommended dye stain and just look at her result!
We do not recommend the use of a wood pre-conditioner with dye stains. It is a matter of personal preference, but conditioners diminish color saturation, defeating the purpose of dye stains.
GRAIN RAISE: Water-based dye stains pop the wood grain more than solvent-based versions, but like all water-based stain products, it will raise the grain of the wood a bit. You can reduce this effect by raising the grain before applying dye stain. First, dampen the sanded surface with a cloth moistened with distilled water (tap water can contain minerals that may affect the finish). Let the surface dry and then sand lightly with the grain using 220-grit sandpaper. Never over-sand before applying any stain, as you may seal the surface so much that stain will not be able to properly penetrate. Alternatively, grain raise can easily be knocked down when finish sanding the first layer of topcoat.
CAUTION: Test the color in a hidden area before you begin your project. Once you use a Dye Stain, that is the color you are going to get. Apply liberally and evenly with a foam applicator and wipe off any excess immediately. There won't be much to wipe away; it penetrates fast.
Please share your completed Dye Stain projects on our Facebook page and in our Design Center.
Can I adjust the color of my Dye Stain?
Additionally, General Finishes Water Based Wood Stains can be mixed into the Reducer, which will lighten the color and thin the viscosity so it will penetrate deeper into the wood.
You can also mix with General Finishes TransTint liquid dye concentrate.
Note: We do NOT RECOMMEND using water to lighten dye stain. Reducer has ingredients to help keep color molecules dispersed evenly in the can.
Does adding Dye Stain Reducer to Dye Stain lighten the color?
We do not recommend using water to lighten dye stain. Reducer has ingredients to help keep color molecules dispersed evenly in the can.
