Enduro Professional Water-Based Black Poly
Enduro Black Pigmented Poly is a professional spray only, high-solids, pigmented water-based coating ideal for cabinets and millwork. Stocked in Black and White, custom colors are available for wholesale customers upon request. White and Clear can be used as tint bases to achieve endless colors. Learn more about General Finishes' entire finishing system of clear and pigmented primers, acrylic and polyurethane clears, pigmented topcoats and water-based stains here: 4 Reasons to Switch to Water-Based Finishes.
See our spray tip size recommendations here.
enduro water based polyurethane cabinert finish black semi-gloss
Raw Wood
1. Sand with 120-grit sandpaper, followed by 150 or 220-grit.
Sealed Surface
2. Dry 1-2 hours.
3. Sand lightly with 220-320-grit sanding sponge.
4. Remove dust.
Step 2: Priming
Raw Wood & Sealed Surface
GF Black Poly covers great on its own or can be applied over a primed surface.
Prime with GF Lamp Black Milk Paint to block grain or cover existing color.
Prime with GF Sanding Sealer for a smooth surface and to fill in voids.
Step on 3: How To Apply General Finishes Enduro Black Poly
General Finishes Enduro Black Poly Spray Application Steps for Raw Wood & Sealed Surface
  1. Black Poly product overview video here.
  2. Watch a comparison of GF paints and pigmented topcoats here.
  3. Work in a well-ventilated area.
  4. Stir thoroughly to reincorporate solids that have settled to the bottom of the can before and throughout the application process.
  5. Test for color & adhesion over existing sealed surfaces.
  6. Thin as desired with distilled water; start with 5%, increase up to 10% by volume. Increase open time, if needed, with up to 10-15% General Finishes Extender if allowed by local regulations. GF Extender will improve flow and leveling and increase open time, which is helpful in dry climates. California Residents: Adding more than 2% of GF Extender will make the products non-compliant per SCAQMD Regulations. GF assumes no liability for the improper use of these products.
  7. Ready to spray from container. Apply up to 2 coats of a primer, plus 2 coats of GF Black Poly. Wear NIOSH-approved respiratory & eye protection.
    • Spray Application: Before spraying, strain through a medium-mesh filter. Spray wet films at 3-5-mil thickness. Medium air cap. Fluid tip sizes Compressed air: .040, HVLP: .043 -.051 or Airless: .1 -.15. Verify tip sizes with equipment supplier. See our spray tip size recommendations here. Read here for more information on spraying techniques.
      • Face frames: Enduro professional products are engineered to be spray-only but can be successfully applied to cabinet face frames, edges, or drawer fronts with a small cabinet-specific 3/8" nap microfiber roller such as Whizz or AllPro brand. Larger areas may not level. Add 10-20% Extender for improved results.
  8. If a faster build is desired over raw wood, use General Finishes Sanding Sealer for the first coat, followed by 2 coats of Black Poly.
  9. Dry 2+ hours between coats in ideal conditions: 70°F 20°C; 50% humidity. Be sure to allow adequate dry time. You can tell if a water-based finish is dry if it forms a powder when lightly sanded with a fine-grade (220-320) foam sanding pad. If in doubt, wait longer. Rushing the dry time can cause "blush," which is clouding in the finish due to moisture trapped between the layers. Increase dry time if:
  10. Finish sand between coats with a fine-grade (220-320) foam sanding pad to improve smoothness and adhesion.
  11. Remove dust with a vacuum, compressed air, an oil-free tack cloth or a water-dampened rag.
Please be mindful of the manner in which water-based products are stored and how long they have been in storage. They not a forever product.
Water-based products do not last forever, even when unopened. General Finishes products are best used within 1 year. However, the life of the product may be extended several more years with proper care and storage (see Storage Tips below).
Ey protection: Safety eyewear complying with an approved standard should be used when a risk assessment indicates this is necessary to avoid exposure to liquid splashes, mists, gases, or dust. If contact is possible, the following protection should be worn unless the assessment indicates a higher degree of protection: safety glasses with side shields.
Product Colors Black
Sheen Satin (25-35), Semi-Gloss (50-60)
Type Urethane/Acrylic Blend
Application Method Spray
Brushable No
Usable over existing finishes Yes - see product page application instructions.
Spray Tip Sizes HVLP 1.3mm-1.5mm
Can Sizes Gallons, 5 Gallon pails
Coverage 450 sq. ft/gal
Viscosity (cPs) 600-800
Satin: 31%
Semi-Gloss: 30%
Solids by Volume
Satin: 28%
Semi-Gloss: 28%
Satin: 238.752 g/L
Semi-Gloss: 240.720 g/L
Gloss: 241.470 g/L
Hardness (Koenig #) 62
Wear (Taber #) 105.40 mg loss
Chemical (105 max) 92
