Exterior 450 Water-Based Wood Stain
GF's Exterior 450 Stains are low VOC premium quality, exterior pigmented water-based wood stains designed for outdoor projects with vertical surfaces such as garage doors, entrance doors and furniture. Can be applied to wood, MDF, and fiberglass and are also made with more than 50% RENEWABLE RESOURCES formulated from sustainable materials that decrease the carbon footprint. These stains are not recommended for large horizontal surfaces such as decks. Exterior 450 Stains contain U.V. absorbers to protect the finish and mildewcides to slow mold and mildew growth, but will not prevent the wood from changing color in sunlight. Brush or spray. See our spray tip size recommendations here.
4 Reasons to Switch to Water-Based Finishes
Step 1: Preparation of Raw Wood for Water Based Stain
Before applying stain, all raw wood projects require preparation sanding, and all existing finishes require prep cleaning and sanding. If you skip this critical step, your finish may fail.
Prep Sanding for Raw Wood Projects
  1. Sand open-grain wood (e.g., oak, ash, mahogany, parawood) with 120-grit sandpaper, followed by 150-grit, then 180-grit.
  2. Sand closed-grain wood (e.g., cherry, pine, maple, birch, alder) with 150-grit sandpaper followed by 220-grit.
  3. Remove dust with a vacuum, compressed air, an oil-free tack cloth or a water-dampened rag.
  4. Do not over-sand with fine-grit sandpapers; this will close and seal the wood grain, preventing ideal color absorption.
  5. Do NOT use steel wool with water-based finishes; the particles will get trapped in the finish and rust.
Prep Sanding for Existing Finish
  1. Remove any existing finish by sanding with 120-grit-sandpaper & scuffing with a wire brush if needed.
Reducing Grain Raise on Raw Wood
To reduce grain raise, dampen the wood with water after prep sanding. Let dry completely, then lightly sand with fine-grade (220-320) foam sanding pad.
Step 2: How To Apply General Finishes Exterior 450 Stain
General Finishes Exterior 450 Water Based Wood Stain Application Steps
NOTE: Exterior 450 stain is not intended for decks. It can be used on tabletops that do not receive direct exposure to sun and rain. As with all fine furniture finishes, wipe up spills in a timely manner to protect the finish.
Download 2024 Exterior 450 Stain Brochure Here
  1. Watch 450 Exterior Stain overview video here.
  3. Stir stain thoroughly to reincorporate solids that have settled to the bottom of the can before and throughout the application process.
  4. Test your complete finishing process before starting. Stain color is affected by variances in wood and deepened by the application of topcoat. To lighten, dilute with water-based GF Exterior 450 Natural Base.
  5. Thin as desired with distilled water; start with 5%, adding up to 10% by volume.
  6. Increase open time, if needed, with 10-15% General Finishes Extender if allowed by local regulations. GF Extender will improve flow and leveling and increase open time, which is helpful in dry climates. California Residents: Adding more than 2% of GF Extender will make the products non-compliant per SCAQMD Regulations. GF assumes no liability for the improper use of these products.
  7. Divide your project into manageable sections: top, side, drawer, door, table seam.
  8. Hand-Application Over Raw Wood:
    • Working quickly, apply a LIBERAL amount of stain to ensure easy workability using a synthetic bristle brush, foam brush, pad applicator, or microfiber roller with smooth, even strokes. Stain one section at a time. If not enough stain is used, the surface may dry too quickly, causing an uneven appearance. On large projects, leave wet edge between sections to prevent lap lines between sections.
    • Wipe off the excess evenly with the grain using a cloth or quality paper towel. Check for missed spots and lap marks before moving to the next section. Do NOT use cotton t-shirts to wipe away stain because they will "push" the stain around and not absorb it.
    • Immediately correct lap marks by rewetting the entire working area with stain and wiping off the excess.
    • Pull excess stain out of corners and detail with a synthetic bristle brush.
    • Let the stain dry 2+ hours when applying 1 coat in ideal conditions, 70°F/20°C, 50% humidity. Increase dry time if:
      • A second coat is applied
        • To accelerate drying in humid conditions add General Finishes Accelerator to Exterior 450 Stain before applying and work in a space with good ventilation and air movement. If you decide to re-coat before the recommended time, test dryness.
  9. Spray Application over raw wood:
    • Before spraying, strain topcoat through a fine-mesh filter.
    • Spray wet films at 3-5-mil thickness. HVLP: 1.1mm-1.3mm spray tip, medium air cap. Verify tip sizes with your equipment supplier. See our spray tip size recommendations here. Wear a full filter respirator (NIOSH/MSHA-approved) and, if spraying in an interior space, make sure there is good ventilation. Keep your gun at a 90° angle, 6-8" from the surface. On large, flat areas, use wet, even patterns 6-8" wide. For narrow surfaces, reduce the fan pattern to 2-3" wide to reduce overspray. Overlap each pass 50% for even coverage. Wipe back the excess with an absorbent cloth. Read here for more information on spraying techniques.
    • Let the stain dry 2+ hours in ideal conditions (50-70% humidity, 70*F). Increase dry time if:
      • Additional coats are applied
  10. Optional: apply a second coat to deepen the color. Apply no more than 2 coats.
  11. Finish with 3 coats of General Finishes Exterior 450 Topcoat.
Step 3: Topcoat Over Exterior 450 Stain
Always seal General Finishes Exterior 450 Stain with 3 coats exterior-rated topcoat. We recommend General Finishes Exterior 450 Topcoat, which is formulated to be compatible with Exterior 450 Stain.
Exterior 450 topcoat and stain are not intended for decks. It can be used on tabletops that do not receive direct exposure to sun and rain. As with all fine furniture finishes, wipe up spills in a timely manner to protect the finish.
Exterior 450 Topcoat is designed to allow water to permeate the finish and, as it dries, the water releases back out to allow the finish to tighten down again.
Horizontal surfaces and uncured surfaces with sitting water may cloud or blush temporarily as the finish dries. Once fully cured, any blushing that occurs should be minimal.
Exterior 450 Stain Warnings and Warranties
  • Black Walnut, Butternut, Cedar, Chestnut, Olde Cherry, Red Mahogany:
    This product can expose you to chemicals including Carbon black, respirable powder, Crystalline silica, respirable powder, which are known to the State of California to cause cancer, and N-methyl-2-pyrrolidone, which is known to the State of California to cause birth defects or other reproductive harm. For more information go to www.P65Warnings.ca.gov.
  • Coffee Bean:
    This product can expose you to chemicals including Ethylene oxide, 4-Methylpentan-2-one, which are known to the State of California to cause cancer and birth defects or other reproductive harm. This product can expose you to chemicals including Carbon black, respirable powder, Crystalline silica, respirable powder, Acetaldehyde, 1,4-Dioxane, which are known to the State of California to cause cancer, and N-methyl- 2-pyrrolidone, Ethanediol, which are known to the State of California to cause birth defects or other reproductive harm. For more information go to www.P65Warnings.ca.gov.
  • Natural Base, Sugar Maple:
    This product can expose you to N-methyl-2-pyrrolidone, which is known to the State of California to cause birth defects or other reproductive harm. For more information go to www.P65Warnings.ca.gov.
WARNING: Keep out of reach of children. Do not swallow. Avoid contact with eyes. Keep container tightly closed when not in use. Wash thoroughly after handling.
Product Colors Aged Gray, Black Walnut, Butternut, Cedar, Chestnut, Coffee Bean, Mesquite, Natural Base, Red Mahogany, Stormy Gray
Interior or Exterior Exterior only
Type Exterior Water Based Stain
Can Sizes Quarts, Gallons
Coverage 140-160 sq.ft./quart, 560-640 sq.ft./gallon
Weight Solids 21%
Aged Gray: <180 g/L
Black Walnut: <175 g/L
Butternut: <175 g/L
Cedar: <175 g/L
Chestnut: <175 g/L
Coffee Bean: <75 g/L
Mesquite: <165 g/L
Natural Base: <215 g/L
Red Mahogany: <175 g/L
Stormy Gray: <149 g/L
*I Used Exterior 450 Over a Mix of Mineral Spirits & TransTint Dye Stain and the Finish is Peeling - How Do I Fix the Peeling?*
A water-based finish, such as Exterior 450, cannot be used in conjunction with mineral spirits, even with an extended dry time. Solvents do not play well with water-based finishes.
Unfortunately, there is no fix for the peeling finish. You will have to sand the project down, apply an exterior stain and recoat with Exterior 450. Also, advise your customer that no finish will withstand the sun indefinitely. All exterior finishes need recoating and maintenance over time.
Should I use Pre-Stain Conditioner Before Staining a Douglas Fir Door to prevent blotching?
Douglas Fir is a difficult wood to stain evenly. A 50|50 mix of your Exterior 450 stain color and Exterior 450 Clear would be a better choice for an exterior conditioner. Blotching may still occur even with this procedure.
After applying the conditioner mix, let it dry 2-3 hours. Allow more time in humid weather. Then a apply the stain color of your choice. Multiple coats will deepen the color.
Watch Exterior 450 Stain Overview Video Here
What is the difference between General Finishes Outdoor Oil and Exterior 450 Outdoor Water-based Topcoat?
General Finishes Exterior 450 Topcoat & Outdoor Oil
When comparing General Finishes Outdoor Oil and Exterior 450 outdoor water-based topcoat , there are several key differences to consider:
Application and Protection
Outdoor Oil:
  • Penetrates into the wood fibers rather than forming a film on top
  • Simpler and quicker to apply - can be sprayed, rolled or brushed on and wiped off
  • Provides less overall protection compared to topcoats
  • Requires more frequent reapplication, typically annually, dependent on environmental conditions
  • Can be used on decks.
Exterior 450 Outdoor Topcoat:
  • Forms a protective film layer on the wood surface
  • More complex application process, often requiring multiple coats
  • Offers superior protection against moisture and UV damage
  • Not intended for large horizontal surfaces such as deck.
  • Lasts longer before needing reapplication, typically 3-5 years dependent on environmental conditions
Appearance and Maintenance
Outdoor Oil:
  • Enhances the natural look of the wood
  • Easier to maintain - simply clean and reapply
  • May darken the wood slightly
  • Can provide a range of sheens from matte to glossy
  • Requires more effort to refinish - may need stripping and sanding
Durability and Longevity
Outdoor Oil:
  • Less durable overall, but easy to reapply
  • Typically lasts 1-2 years before needing reapplication
  • More durable and longer-lasting protection
  • Can last 3-5 years or more with proper care
  • Includes UV protection of the film (not the wood) and mildewicides to retard the growth of mold
Composition
Outdoor Oil:
  • Contains UV inhibitors and mildewcides
  • Organic oil
  • Water-based self-crosslinking polyurethane/acrylic.
  • Often includes UV protection and other additives for durability.
In summary, outdoor oils offer more a straightforward application and maintenance but less protection. In contrast, outdoor topcoats provide superior durability and protection at the cost of more complex application and refinishing processes. Their choice depends on the specific project requirements, desired appearance, and willingness to perform regular maintenance.
What is toning finishes?
General Finishes Dye Stain
All of General Finishes water-based topcoats with the exception of Conversion Vanish can be tinted to create lightly colored finishes for toning.  It is YOUR RESPONSIBILITY TO TEST to your satisfaction before application to your entire project.
There are limits anytime you add pigments or dyes to water-based topcoats. Toning should always be done in small increments to achieve the desired color. If you are starting with a light honey tone door and you want to create an Espresso color this will take multiple coats of color including base coat of stain followed by several toning coats. It is impossible to achieve a radical color change with just 1 coat of toner.
  • Enduro Professional 1K Black Poly
  • Enduro Professional Pro Series Clear Poly
  • Enduro Professional Pro Series White Poly
  • High Performance Topcoat
  • Flat Out Flat Topcoat
  • Enduro-Var II Topcoat
  • Exterior 450 Topcoat
  • Wood Turners Finish
  • Exterior 450 White
  • Arm-R-Seal
  • Seal-A-Cell
  • Gel Satin Topcoat
  • Wood Bowl Finish
  • Butcher Block Oil
  • Outdoor Oil
  • Hard Wax Oil
GENERAL PRACTICE:
  1. Oil-based topcoats and ENDURO-VAR II will amber over time.
Compare all topcoats
