General Finishes Water-Based Pre-Stain Conditioner is essentially a water-based stain formula without added color. Apply it before a water-based stain to minimize blotchiness on woods like maple, pine, and cherry. It works by soaking into and partially sealing the more porous areas of the wood, thereby controlling the amount of stain they absorb. This helps stain cover more evenly so soft or absorbent regions do not end up darker than the hard grain, yielding consistent color saturation.
Water-Based Pre-Stain Conditioner is a PFAS-free formula, and as General Finishes strives for a cleaner and healthier environment, all future product development will be free of “Forever Chemicals."
Sand open-grain wood (e.g., oak, ash, mahogany, parawood) with 120-grit sandpaper, followed by 150-grit, then 180-grit.
Sand closed-grain wood (e.g., cherry, pine, maple, birch, alder) with 150-grit sandpaper followed by 220-grit.
Remove dust with a vacuum, compressed air, an oil-free tack cloth or a water-dampened rag.
Do not over-sand with fine-grit sandpapers; this will close and seal the wood grain, preventing ideal color absorption.
Do NOT use steel wool with water-based finishes; the particles will get trapped in the finish and rust.
Reducing Grain Raise on Raw Wood To reduce grain raise, dampen the wood with water after prep sanding. Let dry completely, then lightly sand with fine-grade (220-320) foam sanding pad.
General Finishes Water Based Pre-Stain Conditioner Application Steps
For use with water-based stains. Pre-Stain Conditioner Natural can improve color uniformity over difficult-to-stain wood species such as pine. However, it will limit color absorption, so a darker wood stain may be required to get the desired depth of color.
Hand-Application Over Raw Wood:
Work in a well-ventilated area.
Stir thoroughly to reincorporate solids that have settled to the bottom of the can before and throughout the application process.
Test your complete finishing process before starting. The color of stain is affected by variances in wood and deepened by the application of topcoat.
Thin as desired with distilled water; start with 5%, adding up to 10% by volume.
Increase open time, if needed, 10-15% General Finishes Extender if allowed by local regulations. GF Extender will improve flow and leveling and increase open time, which is helpful in dry climates.
To accelerate dry time in humid conditions, add General Finishes Acceleratorbefore applying and work in a space with good ventilation and air movement.
Divide your project into manageable sections: top, side, drawer, door, table seam.
Apply a LIBERAL amount of Pre-Stain Conditioner to ensure easy workability using a synthetic bristle brush, foam brush, pad applicator or roller.
Wipe off the excess evenly with the grain using quality paper or shop towels.
Let Pre-stain Conditioner dry 20 minutes but no more than 30 minutes before applying GF water-based stain in ideal conditions: 50-70% humidity, 70°F/20°C. Cooler temperatures and higher humidity may prolong dry time.
Before spraying, strain topcoat through a fine-mesh filter.
Spray wet films at 3-5-mil thickness. HVLP: 1.1mm-1.3mm spray tip, medium air cap. Verify tip sizes with your equipment supplier. See our general guide for spray tip sizes.
Wear a full filter respirator (NIOSH/MSHA-approved) and work in a ventilated space.
Keep your gun at a 90° angle, 6-8" from the surface. On large, flat areas, use wet, even patterns 6-8" wide. For narrow surfaces, reduce the fan pattern to 2-3" wide to reduce overspray. Overlap each pass 25% to conceal lines.
Let Pre-stain Conditioner dry 20 minutes but no more than 30 minutes before applying GF water-based stain in ideal conditions: 50% humidity, 70°F/20°C.
Dilute Water Based Stains Add 5% GF Pre-Stain Conditioner to GF Water Based Stains by volume, increase up to 15% as desired.
Custom Stain Colors Add 3 tablespoons of any General Finishes Milk Paintcolor to one pint of Water-Based Pre-Stain Conditioner Natural to make a colored wood stain, or 6 tablespoons Milk Paint to 1 quart Pre-Stain Conditioner.
Warning: Do not use water-based products with Linseed Oils or Danish Oils.
Product that is 3 years old will not look like product that is 6 months to 1 year old. You will see more stratification or separation as the product ages. Settling is natural. Always stir thoroughlybefore using.
Foul Smell
See video tutorial: Tips on Storing Leftover Finishes Water-based finishes crystalize and form a skin due to evaporation when the air-tight seal on a can is broken at first use. The following best practices will increase the life of your product:
Water-Based Pre-Stain Conditioner Warnings and Warranties
FIRST AID: Seek immediate medical attention if symptoms occur due to the following. Eye Contact: Remove any contact lenses. Flush eyes with water for 20+ minutes while lifting upper and lower eyelids. Skin Contact: Wash thoroughly after handling. Inhalation:Move to fresh air and loosen clothing. If not breathing, if breathing is irregular or if respiratory arrest occurs, provide artificial respiration or oxygen by trained personnel. Ingestion: Call physician immediately. Wash out mouth with water. Do not induce vomiting unless directed to do so by medical personnel. Never give anything by mouth to an unconscious person.
Prop 65 WARNING: This product can expose you to Ethylene oxide, which is known to the State of California to cause cancer and birth defects or other reproductive harm. This product can expose you to chemicals including Hydrazine, 1,4-Dioxane, Propylene oxide, which are known to the State of California to cause cancer, and Ethanediol, which is known to the State of California to cause birth defects or other reproductive harm. For more information go to www.P65Warnings.ca.gov.
CAUTION: MAY CAUSE EYE IRRITATION.
WARNING: Keep out of reach of children. Avoid contact with eyes. Keep container tightly closed when not in use. Wash thoroughly after handling.
Water Based Stains will always exhibit a bit of bleed through. When glazing with any color over water stains, we recommend some type of seal coat is applied first.
Unfortunately, the two colors you have chosen do not work very well together. Expresso will always bleed if Whitewash is applied directly over top. In the future, seal the Espresso stain with a coat of Shellac, and then General Finishes High Performance Topcoat. Allow both to dry, then apply Whitewash as a glaze (1 part stain, 1 part topcoat mix).
Here are two remedies we recommend to fix for bleeding that has occurred:
Strip away finish and start over. Stain with Espresso, top with Shellac, and then with 1-2 coats High Performance. After the HIgh Performance has dried, apply the Whitewash as a glaze (1:1 stain & HPTC). Seal with High Performance.
Paint over the bleeding stain. Seal current finish with Shellac and then paint with Seagull Gray Milk Paint.
Any time you apply a light stain over a dark stain there is a possibility of bleed through. Therefore, it's important to seal off the base color first. If the look of the wood grain is not important, Dark Chocolate Milk Paint is an exact match to Java GelStain when painted, and it could be used as an alternative base color.
PRE SEALING:
Milk Paint: 1.8mm-2.0mm
Stain Blocker: 1.8mm-2.0mm
Glaze Effects: 1.8mm-2.0mm
Enduro-Var II 1.1mm-1.3mm
Air caps should be medium-sized. Contact your supplier to verify proper tip sizes for your specific equipment.
Break your work into sections, such as dresser top or drawer fronts. Spraying too large of an area can result in a textured grainy surface. A correctly sprayed finish should appear even and glossy. It is essential to apply a sufficient amount of material to ensure proper flow and leveling of the finish.
Spray medium-wet films at 3-5 wet mL thickness. Practice makes perfect. If you have never sprayed finishes before, take a large piece of cardboard and practice your technique first. Spray water on the cardboard to learn how the gun works. Check your fluid settings and adjust the controls to get comfortable with the spray angles and to develop your technique.
SPRAYING TOPCOATS:
SPRAYING WATER-BASED DYE STAINS:
Water-based products do not last forever, even when unopened. General Finishes products are best used within 1 year of the manufacture date listed on the bottom of the can. The life of the product may be extended to 2-3 years with proper care and storage.
SETTLING
Gravity can cause some solids to settle on the bottom of the can and slight separation on the top. This is normal. If working with older paint, use a paint mixing attachment on a drill. If the solids dissolve and clumps smooth out after mixing from the bottom, the product is in good condition for use.
STORAGE TIPS
Pry open sealed lid(s) with a paint can opener by hooking under the lid's rolled edge. The use of a screwdriver can disfigure the rim and lid, impairing a complete seal.
Keep lid(s) closed while working. Pour what you will use into a bowl, paper cup, or plate, and close can lid as you work.
CLEAN the chime of the can(s) thoroughly with a paper towel before closing to create a complete seal. Paint in the chime can be minimized by using a pouring lid, such as Fitsall. Avoid wiping used brushes on the lid.
Pound the lid(s) in place using a rubber mallet to avoid distorting the chime or lid. Dents in the lid from direct contact with a hammer can impair a complete seal. Alternatively, place a flat piece of wood over can lid and firmly pound shut.
Store in moderate temperatures. Avoid temperatures below 50*F/10*C or above 80*F/26*C. Frozen and heat-damaged product cannot be revitalized. Temperature-controlled spaces, such as a basement, are ideal for storage. Do not store product in an attic, garage, in direct sunlight, or next to something warm like a water heater or furnace.
Store the can(s) upside down to create a liquid seal, minimize evaporation and reduce the chance of crystallization. Decant remaining product from the can before stirring.
Thin GF water based stains with distilled water if desired. Start with 5%, adding up to 10% by volume. Increase open time, if needed with up to 5% General Finishes Extender if allowed by local regulations. GF Extender will improve flow and leveling and increase open time, which is helpful in dry climates. California Residents: Adding more than 2% of GF Extender will make the products non compliant per SCAQMD Regulations. GF assumes no liability for the improper use of these products.
GF Enduro RTM stains are a thinner formula designed for professional spray applications.
VOC compliant in all 50 states
Water cleanup
Low odor
Non-flammable
An epoxy acrylic formulation.
Prevents tannin bleed-through & discoloration.
Has high build with excellent adhesion properties.
Apply with a brush, roller, or sprayer.
An Interior polyurethane/acrylic blend.
Clear drying.
highly resistant to water and household chemicals.
Apply with a brush or sprayer.
An interior acrylic formulation.
Clear drying.
provides an extremely flat finish with high durability.
An interior oil-modified water-based urethane.
Dries to a light, amber tone.
Made with over 50% renewable resources.
A premium interior and exterior-rated acrylic formulation.
Self-sealing and does not require topcoat.
Is made with over 50% renewable resources.
Is available in 12 popular colors, plus two tint bases.
An interior oxidating acrylic formula.
Available in 6 colors, including a Clear Base.
Is a decorative specialty finish.
Can be intermixed to create custom colors.
It requires a topcoat
An interior polyurethane.
Clear drying.
Levels to a smooth, hard, durable finish.
Provides excellent slip and black heel mark resistance.
Apply with a brush, roller, or pad applicator.
It’s available in 18 deep brilliant colors.
And provides universal coverage on many wood species.
Used to control blotching on hard-to-stain woods.
And to reduce Water Based Wood Stains.
A penetrating stain with ink-like consistency.
It is available in 14 vibrant colors.
And can be used as a toner.
Apply with a brush or sprayer or wiping on.
The clear base used to reduce Dye Stain colors.
A polyurethane formulation.
Tintable to dark colors.
Contains UV absorbers & Mildewcides to protect the finish.
Clear drying.
A pigmented polyurethane formulation.
Is tintable to light and pastel colors.
Contains UV absorbers & mildewcides to protect the finish.
Available in 10 colors, including a clear base.
Contains U.V. absorbers & mildewcides to protect the finish.
A premium Interior and exterior-rated acrylic formulation.
Available in 12 popular colors, plus two tint bases.
Apply with a brush, roller or sprayer.
A penetrating oil wood preservative.
Contains UV absorbers and mildewcides to protect the finish.
This finish will amber as it ages.
A maintenance product. Reapply when wear becomes evident.
A heavy-bodied, no-drip oil and urethane formula.
Designed to provide a hand-rubbed look.
Will amber as it ages.
Apply with a brush or wipe on.
A heavy-bodied, no-drip formula.
Available in 14 deep, rich, uniform colors.
Apply with a brush, roller, or wipe on.
A penetrating sealer with a high-quality urethane formulation.
It provides long-lasting, durable protection.
and works beautifully on projects with detail.
a traditional, pigmented liquid wiping stain
Available in 14 colors
Can be used as a toner with Arm-R-Seal
Oil-Based Pre-Stain Conditioneris:
Designed to control blotching on hard-to-stain woods.
And penetrates the grain to promote uniform acceptance of oil stains.
Formulated with a blend of oils, urethanes, and wax.
Is GF’s deepest penetrating close-to-the-wood sealer.
And the best choice for highlighting figured wood.
A urethane-solids polymer in a blend of oil & wax.
Enhances the natural look of wood.
One of our easiest finishes to use.
It’s best used with optional GF Hardener to shorten dry time and providesuperior durability.
This is a maintenance product. Reapply when wear becomes evident.
Apply with a white pad or plastic spreader.
A pure urethane formulation.
Highlights figured wood beautifully
A mineral oil formulation.
Meets all requirements for use on wooden surfaces that come in contact with food.
Apply with a cloth.
A routine cleaner for cured wood finishes
Non-combustible with a fresh orange scent
Apply with a cloth
A blend of waxes.
Produces a soft sheen and feel over any wood finish.
Can be used as a polish for rubbing out new finishes OR as a scratch-remover.
Apply with a cloth.
No matter what your project is, General Finishes has the right product for you. General Finishes is dedicated tousing the highest-quality ingredients in all our products, while testing and advancing our water-based finishes with leading-edge technology.
Maple is one of the most difficult woods to achieve a dark, uniform stain color on because it is a dense, closed grain wood and often absorbs stain very unevenly. General Finishes Gel Stains or Water Based Stains usually will perform very well because they are more topical than traditional liquid oil stains, and contain more colorants.
We do not recommend pre-sealing Maple with a conditioner because it closes up the grain of the wood even more, further preventing color adherence. In the future, just use our water-based stains or gel stains on their own. Do not use liquid oil-based stains on Maple because they will blotch.
Also, prep sand Maple with 120 grit, followed by 150 grit or 220 grit.
