Dye Stain Reducer is the clear base we use when manufacturing General Finishes Dye Stain and can be used to make custom Dye Stain colors by mixing with GF water base stains. It can also be used to layer color under other water or oil base stains.
General Finishes Water-Based Pre-Stain Conditioner is essentially a water-based stain formula without added color. Apply it before a water-based stain to minimize blotchiness on woods like maple, pine, and cherry.
Water-Based Wood Stains from General Finishes
GF's Exterior 450 Stains are low VOC premium quality, exterior pigmented water-based wood stains designed for outdoor projects with vertical surfaces such as garage doors, entrance doors and furniture.
General Finishes RTM (Ready To Match) Stain System for professional finishers, industrial users, and OEM manufacturing facilities makes color-matching the easiest process on the market.
General Finishes as Seen in Green Building and Design
As seen in Green Building and Design Magazine.
BY HAILEY HINTON, GREEN BUILDING AND DESIGN MAGAZINE
Water-based coatings are the future of finishing. You may not be using them today, but you will be in the next five years.
Newly formulated Enduro Stain Blocker is General Finishes' revolutionary water-based stain-blocking primer that now provides improved sandability and advanced performance for interior AND exterior projects. It can protect pigmented finishes from stains, dyes, and wood tannin bleed-through.
