General Finishes RTM (Ready To Match) Stain System for professional finishers, industrial users, and OEM manufacturing facilities makes color-matching the easiest process on the market.
As seen in Green Building and Design Magazine.
Water-based coatings are the future of finishing. You may not be using them today, but you will be in the next five years.
Putty comes in two forms, pre-colored or as a stainable wood filler designed to fill minor imperfection such as nail holes, cracks, and gouges in the wood surface. Putty will display stain a bit differently than wood, so it is not a "perfect" fix, but a good one.
The goal is to get the best possible color match to either the color of the raw wood or the color of your existing finish.
Newly formulated Enduro Stain Blocker is General Finishes' revolutionary water-based stain-blocking primer that now provides improved sandability and advanced performance for interior AND exterior projects. It can protect pigmented finishes from stains, dyes, and wood tannin bleed-through.
