Oil Based Wood Bowl Finish
Wood Bowl Finish is a durable oil-and-urethane oil-based finish designed for decorative wooden bowls and turnings. For countertops actively used for chopping and cutting, use Butcher Block Oil instead. Wood Bowl Finish is a PFAS-free coating, and as General Finishes strives for a cleaner and healthier environment, all future product development will be free of “Forever Chemicals."
*Wood Bowl Finish was previously called Salad Bowl Finish.
Need some wood finishes inspiration? Visit the General Finishes Design Center or Pinterest Board for project ideas.
General Finishes Oil Based Wood Bowl Finish, 1 Quart
RAW WOOD:
1. Sand open grain wood with 120 grit sandpaper, followed by 150 grit, then 180 grit. Sand closed grain wood with 150 grit sandpaper followed by 220 grit.
Step 2: How To Apply General Finishes Wood Bowl Finish
General Finishes Wood Bowl Finish Application Steps Over Raw or Stained Wood
  2. Stir topcoat thoroughly to reincorporate solids that have settled to the bottom of the can before use. Urethane topcoats are thin and the flatting agents used to create flatter sheens settle quickly to the bottom. Either stir and decant what you need to use immediately or stir frequently throughout the application process.
  3. Wood must be dry & clean before use.
  4. If desired, thin topcoat with 10-15% mineral spirits.
  5. Apply 3 coats. No more than three coats is recommended. More coats will not improve durability.
    • Hand application: Apply a liberal amount of product using a cotton cloth, natural bristle or foam brush, staining pad with smooth, even strokes & light lap lines. The larger the surface the larger the applicator needed. Wipe off the excess evenly with the grain & with light pressure using a cloth or absorbent paper towel.
  6. Finish sand between coats with a 220-320 grit foam sanding pad to improve smoothness and adhesion.
  7. Remove dust with a vacuum, compressed air, a tack cloth or a water-dampened rag.
Dry Time Between Coats
Dry 24+ hours
between coats in ideal conditions, 70°F/20°C, 50% humidity.
Inadequate dry time is one of the top reasons for finish failures.
  • Temperatures are cooler
  • To accelerate dry time in humid conditions work in a space with good ventilation and air movement. If you decide to re-coat before the recommended time, test dryness.
Cure time
Oil-based finishes cure and harden completely after 30 days. Avoid placing heavy objects on top of surfaces that have not cured completely. Treat gently, and do not clean with commercial products during the cure period.
Storage of Oil Based Products
Hard Wax Oil  Warnings and Warranties
DANGER: COMBUSTIBLE LIQUID AND VAPOR. HARMFUL OR FATAL IF SWALLOWED. CAUSES EYE IRRITATION.
DANGER: Can enter lungs and cause damage. DANGER: Keep out of reach of children. Keep away from heat and flame. Use only with adequate ventilation. Do not breathe vapor or mist. Do not swallow. Avoid contact with eyes. Keep container tightly closed when not in use. Wash thoroughly after handling.
Product Colors Dries Amber
Ambering Yes
Sheen Gloss (80+)
Type Oil & Urethane
Spray Tip Sizes HVLP 1.0mm-1.2mm
Dry Time - Touch 12+ hr
Dry Time - Recoat 24+ hr
Dry Time - Cure 30 days
Can Sizes Pints, Quarts
Coverage 50-60 sq.ft./pint, 100-120 sq.ft./quart
Viscosity Thin
Viscosity (cPs) 100-200
Weight Solids 32%
<575.051 g/L
Hardness (Koenig #) 77
Wear (Taber #) 57.10 mg loss
Chemical (105 max) 101
Salad Bowl Finish FAQs
*Why Isn't the Salad Bowl Oil I Applied to Walnut Serving Boards Drying After Two Coats?
Some pieces of wood contain a lot of oil and walnut can be finicky.
The oil in the walnut wood may be causing the problem you've described - a longer dry time might have been needed over an oily wood. If the wood does not dry over the next few days then it may be necessary to sand down and start over.
Unfortunately, if the first coat does not dry, the second will never dry.
