There are four benefits to using sanding sealer as the first seal coat prior to topcoat
Enduro-Var II is a reformulation of our original oil-modified, ambering, water-based topcoat. It replaces original Endurovar and is made with more than 70% RENEWABLE RESOURCES formulated from sustainable materials that decrease the carbon footprint and is compatible with ALL GF products.
John Mosconi of Sting King Lutherie in Akron, Ohio takes us on his journey of refinishing this mandola.
Step 1: Prep and Sealing
Our first concern is the use of the epoxy. Although you have may had success with this process previously, we do not recommend the use of Enduro-Var with epoxy or any oil based products. Enduro-Var works well on its own or with GFs water based finishes. There is a great possibility that future finishes can fail.
ANSWER:
It depends! Read on, or watch this GF video demonstration: http://youtu.be/torOAQy91q4
*Here are the main questions to ask yourself:
