Enduro-Var II is a reformulation of our original oil-modified, ambering, water-based topcoat. It replaces original Endurovar and is made with more than 70% RENEWABLE RESOURCES formulated from sustainable materials that decrease the carbon footprint and is compatible with ALL GF products.
There are four benefits to using sanding sealer as the first seal coat prior to topcoat
Make your wood finishing project's grain really "POP" by layering oil & water-based products together, resulting in enhanced natural wood grain and character.
ANSWER:
It depends! Read on, or watch this GF video demonstration: http://youtu.be/torOAQy91q4
*Here are the main questions to ask yourself:
John Mosconi of Sting King Lutherie in Akron, Ohio takes us on his journey of refinishing this mandola.
Step 1: Prep and Sealing
General Finishes Professional Enduro White Undercoat is similar to General Finishes Sanding Sealer with the addition of white colorant to provide a primer undercoat for white/off-white wood finishes. Want to tint to a darker color? Use Enduro Deep Base Primer instead.
