There are four benefits to using sanding sealer as the first seal coat prior to topcoat
Decorative Finishes- Distressing, Antique Finishes, Faux Marble and More
The term for a cloudy, milky appearance in the finish is Blush. There are three causes:
     1. The most common reason is an incompatible stain. For example, using a water-based topcoat over an oil-based based stain. When the top coat is applied, the oil in the stain seeps up through the finish and reacts with the acrylic causing a chemical blush.
Flat Out Flat is a self-crosslinking water-based topcoat that mimics the lustrous look and feel of wax. The increased matting agents used to create "flat look" cause this wood finish to have less clarity, show fingerprints more and provide less durability than High Performance.
General Finishes Professional Enduro White Undercoat is similar to General Finishes Sanding Sealer with the addition of white colorant to provide a primer undercoat for white/off-white wood finishes. Want to tint to a darker color? Use Enduro Deep Base Primer instead.
ANSWER:
It depends! Read on, or watch this GF video demonstration: http://youtu.be/torOAQy91q4
*Here are the main questions to ask yourself:
Yes. All stains need a top coat. Think of stain as the color and top coat as the sealer and protectant. Discover the best topcoat for your gel stain.
Enduro-Var II is a reformulation of our original oil-modified, ambering, water-based topcoat. It replaces original Endurovar and is made with more than 70% RENEWABLE RESOURCES formulated from sustainable materials that decrease the carbon footprint and is compatible with ALL GF products.
