Orange Oil is General Finishes' most popular natural furniture care product. It is non-combustible with a fresh orange scent.  Use as a cleaner, for antique restoration or as a lubricant when buffing topcoats.
General Finishes Fill Sticks make easy work of wood furniture repair and maintenance. They are a convenient way to fill and hide nicks, gouges and scratches on any shade of interior furniture and woodwork.
After your finish has cured, the best way to clean is with a water-damp rag. If your surface requires deep cleaning due to grease or grime build-up, add a speck of a strong dish detergent, such as Dawn or a bit of vinegar to your damp rag.
If need deeper cleaning, use General Finishes Orange Oil Polish.
General Finishes Outdoor Oil is an exterior-rated penetrating oil that is a wood maintenance preservative. It contains UV prohibitors, heat stabilizers & mildew prohibitors. Use Outdoor Oil for all exterior outdoor wood projects, particularly wood furniture.
You can rub down the finish with 0000 steel wool and General Finishes Orange Oil to lower the sheen.
Pro Tip: GF does not recommend using steel wool with water-based finishes because the particles can become embedded and rust.
This is General Finishes' easiest finish ever and the best oil and wax finish on the market. Hard Wax Oil is a high-quality urethane-solids polymer in a blend of oil & wax that enhances the natural look of wood.
Rub down the finish with 0000 steel wool and General Finishes Orange Oil to lower the sheen.
Liberon 0000 Steel Wool is a good choice for steel wool, as it does not shred as easily as the hardware store brands.
ANSWER: You can rub down the finish with 0000 steel wool and
