General Finishes Water Based Stains have superior qualities over oil-based stains. Their high-quality pigments produce rich, dark, uniform colors on hard-to-stain woods like maple and pine. Water-Based Wood Stain is PFAS-free, and as General Finishes strives for a cleaner and healthier environment, all future product development will be free of “Forever Chemicals." Low odor, low VOC, water cleanup, and noncombustible. Looking for a "green" environment-friendly finish? These stains are formulated with more than 50% RENEWABLE RESOURCES formulated from sustainable materials that decrease the carbon footprint. Brush or spray. See our spray tip size recommendations here. Need inspiration? Visit the General Finishes Design Center OR Pinterest Board. 4 Reasons to Switch to Water-Based Finishes
Stir stain to reincorporate solids that have settled to the bottom of the can before and throughout the application process.
Thinas desired with distilled water; start with 5%, adding up to 10% by volume.
Increase open time, if needed, with up to 5% General Finishes Extender if allowed by local regulations. GF Extender will improve flow and leveling and increase open time, which is helpful in dry climates. California Residents: Adding more than 2% of GF Extender will make the products non-compliant per SCAQMD Regulations. GF assumes no liability for the improper use of these products.
An initial coat of General Finishes Pre-Stain Conditioner Natural can improve color uniformity over difficult-to-stain wood species such as pine. However, it will limit color absorption, so a darker stain may be required to get the depth of color you want. NOTES on softwoods such as Pine, Pawlonia, or Poplar, the use of Pre-Stain Conditioner will reduce blotchiness but not remove it entirely.
Test your complete finishing process beforehand. Stain color can be affected by variances in wood, room lighting, and deepened with the application of topcoat.
Surface preparation is essential. See "Step 1: Preparation for Water Based Wood Stain."
Divide your project into manageable sections: top, side, drawer, door, table seam.
8. Apply product:
Hand-Application over Raw Wood:
Apply a LIBERAL amount of stain to ensure easy workability using a synthetic bristle brush, foam brush, pad applicator or microfiber roller. Work quickly. For large surfaces use a larger applicator such as the pad applicator. If not enough stain is used, the surface may dry too quickly, causing an uneven appearance. On large projects, leave a wet edge between sections to prevent lap lines until you can wipe all the excess off.
Stain one complete section at a time.
Wipe off the excess evenly with the grain using absorbant terry cloth or an absorbent paper towel. Check for missed spots and lap marks before moving to the next section. Do NOT use cotton t-shirts to wipe away stain because they will "push" the stain around and not absorb it.
Pull excess stain out of corners and details with a synthetic bristle brush.
Immediately correct lap marks by rewetting the entire working area with stain and wiping off the excess.
One coat is recommended. If needed, another coat will make the color darker but do not exceed two coats as that will create too much build of a low solids finish. Stains are designed to provide color but are not durable on their own.
Let the stain dry 2+ hours in ideal conditions when using a WATER-BASED topcoat: 50% humidity, 70°F/20°C before adding a second coat (optional) and before adding topcoat. Be sure to allow adequate dry time. If in doubt, wait longer. When using with an OIL-BASED topcoat, allow 24 hours dry time. Increase dry time if:
Humidity is over 80%
More than 2 coats are applied (not recommended)
Thick coats are applied
increase to 24 hours if applying an oil-based topcoat over the water-based stain.
To accelerate dry time in humid conditions, add General Finishes Acceleratorbefore applying and work in a space with good ventilation and air movement. If you decide to re-coat before the recommended time, test dryness.
Spray Application over Raw Wood:
Safety: Wear a full filter respirator (NIOSH/MSHA-approved) and work in a ventilated space.
Spray wet films at 3-5-mil thickness. HVLP: 1.1mm-1.3mm spray tip, medium air cap. Verify tip sizes with your equipment supplier. See our spray tip size recommendations here. Keep your gun at a 90* angle, 6-8" from the surface. On large, flat areas, use wet, even patterns 6-8" wide. For narrow surfaces, reduce the fan pattern to 2-3" wide to reduce overspray. Overlap each pass 25-50% for even coverage. Read here for more information on spraying techniques.
Apply section by section. Spray liberally to a complete section and wipe off the excess evenly with the grain using a quality paper towel or shop towel. Check for missed spots and lap marks before moving to the next section. Do NOT use cotton t-shirts to wipe away stain because they will "push" the stain around and not absorb it.
Spray a LIBERAL amount of stain to ensure easy workability. If not enough stain is used, the surface may dry too quickly, causing an uneven appearance. On large projects, leave a wet edge between sections to prevent lap lines during application.
Pull excess stain out of corners and details with a bristle brush.
Let the stain dry 2+ hours in ideal conditions: 50-70% humidity, 70°F/20°C before adding a second coat (optional) and before adding topcoat. Be sure to allow adequate dry time. If in doubt, wait longer. Increase dry time if:
3+ coats are applied (not recommended)
Prepare surface well. See Existing Finish Prep instructions in "Step 1: Preparation for Water Based Wood Stain."
Apply stain with a foam brush or staining pad. Feather out uneven areas and pull excess stain from corners using a bristle brush. Discharge accumulated stain from the brush onto a dry paper towel as you work. We recommend using a dry brush technique over an existing finish as outlined in this video: How to Update Existing Finishes with Water Based Wood Stain., but even with this technique, do not apply more than 3 coats. Painting on the stain will create too much film build of a low solids finish. Stains are designed to provide color but if applied too heavily, create an unstable surface even when dry and topocated.
Let the stain dry 2+ hours before GF water-based topcoat in ideal conditions: 50-70% humidity, 70*F/20*C before applying a second coat (optional) and before applying topcoat. Be sure to allow adequate dry time. If in doubt, wait longer. Increase dry time if:
More than 3 coats are applied (not recommended)
Applying over products from other brands
Layering General Finishes water- and oil-based products:
Water over oil: Let oil-based products dry 72+hr before applying water-based products
Oil over water: Let water-based products dry 24+hr before applying oil-based products
To accelerate dry time in humid conditions, add General Finishes Accelerator before applying and work in a space with good ventilation and air movement. If you decide to re-coat before the recommended time, test dryness.
Topcoat is required. Finish with 2-3 coats of General Finishes topcoat. Applying more coats will not improve the results. You can remove any grain raise after applying the first coat of topcoat. Watch this video for more information on grain raise. See "Step 3: Topcoat Over Water-Based Stain."
Always seal General Finishes Water Based Wood Stain, General Finishes Dye Stain and General Finishes Enduro Ready-To-Match (RTM) Water Based Wood Stain with 3 coats of topcoat. More coats will not improve durability.
Grain Raise
After the first coat of topcoat has dried, you can knock down grain raise by lightly sanding with a 220 sanding pad. Watch Grain Raise video here.
Recommended Oil-Based Topcoats
When sealing with General Finishes oil-based topcoats, General Finishes Arm-R-Seal and General Finishes Gel Topcoat, let water-based stain dry a minimum of 24 hours first. Oil-based topcoats amber increasingly over time.
Water Based Wood Stain + 10% High Performance Topcoat
**mixture to be used at point of use only. Do not store.
Aged/Varnish Glaze
MATERIALS NEEDED:
General Finishes Water Based Wood Stain: Your choice of color
General Finishes High Performance Topcoat
SAMPLE MIX:
Water Based Wood Stain + High Performance Topcoat 50:50 ratio
Custom Colors
MATERIALS NEEDED:
SAMPLE MIXES:
Create additional colors by mixing Water Based Wood Stains and Dye Stains.
Lighten Water Based Wood Stains by diluting with General Finishes Pre-Stain Conditioner Natural
Toning
Water-Based Wood Stains Can be used for toning. Mix no more than 5%-10% stain to topcoat. Spraying lays down a more even coat, so slightly more stain can be used than when brushing. Toning mixture should be used at point of use only. Do not store for extended period of time.
Product that is 3 years old will not look like product that is 6 months to 1 year old. You will see more stratification or separation as the product ages. Always stir thoroughlybefore using.
Foul Smell
See video tutorial: Tips on Storing Leftover Finishes Water-based finishes crystalize and form a skin due to evaporation when the air-tight seal on a can is broken at first use. The following best practices will increase the life of your product:
Antique Brown, Antique Oak, Black, Black Cherry, Brown Mahogany, Cabernet, Espresso, Hickory, Onyx, Pecan, Provincial, Sedona, Tobacco, Walnut:
WARNING: This product can expose you to Ethylene oxide, which is known to the State of California to cause cancer and birth defects or other reproductive harm. This product can expose you to chemicals including Hydrazine, 1,4-Dioxane, Propylene oxide, which are known to the State of California to cause cancer, and Ethanediol, which is known to the State of California to cause birth defects or other reproductive harm. For more information go to www.P65Warnings.ca.gov.
Graystone, Graphite, Whitewash:
WARNING: This product can expose you to Ethylene oxide, which is known to the State of California to cause cancer and birth defects or other reproductive harm. This product can expose you to chemicals including Hydrazine, 1,4-Dioxane, Propylene oxide, Titanium dioxide, which are known to the State of California to cause cancer, and Ethanediol, which is known to the State of California to cause birth defects or other reproductive harm. For more information go to www.P65Warnings.ca.gov.
Antique Brown, Antique Oak, Black, Black Cherry, Brown Mahogany, Cabernet, Espresso, Hickory, Onyx, Pecan, Provincial, Sedona, Tobacco, Walnut, Water Based Wood Stain Base:
CAUTION: MAY CAUSE EYE IRRITATION.
Graystone, Graphite:
WARNING: HARMFUL IF SWALLOWED. CAUSES EYE IRRITATION.
Whitewash:
WARNING CAUSES EYE & SKIN IRRITATION.
Antique Brown, Cabernet, Hickory, Onyx, Provincial, Sedona, Tobacco:
Keep out of the reach of children. Avoid contact with eyes. Keep container tightly closed and sealed until ready for use. Wash thoroughly after handling.
Antique Oak, Black, Black Cherry, Brown Mahogany, Espresso, Pecan, Walnut, Water Based Wood Stain Base:
WARNING: Keep out of reach of children. Avoid contact with eyes. Keep container tightly closed when not in use. Wash thoroughly after handling.
Keep out of the reach of children. Do not swallow. Avoid contact with eyes. Keep container tightly closed and sealed until ready for use. Wash thoroughly after handling.
Whitewash:
WARNING: Keep out of reach of children. Do not get on skin or clothing. Avoid contact with eyes. Keep container tightly closed when not in use. Wash thoroughly after handling.
Water Based Stains will always exhibit a bit of bleed through. When glazing with any color over water stains, we recommend some type of seal coat is applied first.
Unfortunately, the two colors you have chosen do not work very well together. Expresso will always bleed if Whitewash is applied directly over top. In the future, seal the Espresso stain with a coat of Shellac, and then General Finishes High Performance Topcoat. Allow both to dry, then apply Whitewash as a glaze (1 part stain, 1 part topcoat mix).
Here are two remedies we recommend to fix for bleeding that has occurred:
Strip away finish and start over. Stain with Espresso, top with Shellac, and then with 1-2 coats High Performance. After the HIgh Performance has dried, apply the Whitewash as a glaze (1:1 stain & HPTC). Seal with High Performance.
Paint over the bleeding stain. Seal current finish with Shellac and then paint with Seagull Gray Milk Paint.
Any time you apply a light stain over a dark stain there is a possibility of bleed through. Therefore, it's important to seal off the base color first. If the look of the wood grain is not important, Dark Chocolate Milk Paint is an exact match to Java GelStain when painted, and it could be used as an alternative base color.
PRE SEALING:
Milk Paint: 1.8mm-2.0mm
Brushable White Enamel 1.8mm-2.0mm
Stain Blocker: 1.8mm-2.0mm
Pearl Effects: 1.8mm-2.0mm
Glaze Effects: 1.8mm-2.0mm
Enduro-Var 1.1mm-1.3mm
SPRAYING TOPCOATS:
Thin GF water based stains with distilled water if desired. Start with 5%, adding up to 10% by volume. Increase open time, if needed with up to 5% General Finishes Extender if allowed by local regulations. GF Extender will improve flow and leveling and increase open time, which is helpful in dry climates. California Residents: Adding more than 2% of GF Extender will make the products non compliant per SCAQMD Regulations. GF assumes no liability for the improper use of these products.
GF Enduro RTM stains are a thinner formula designed for professional spray applications.
VOC compliant in all 50 states
Water cleanup
Low odor
Non-flammable
An epoxy acrylic formulation.
Prevents tannin bleed-through & discoloration.
Has high build with excellent adhesion properties.
Apply with a brush, roller, or sprayer.
An Interior polyurethane/acrylic blend.
Clear drying.
highly resistant to water and household chemicals.
Apply with a brush or sprayer.
An interior acrylic formulation.
Clear drying.
provides an extremely flat finish with high durability.
An interior oil-modified water-based urethane.
Dries to a light, amber tone.
Made with over 50% renewable resources.
A premium interior and exterior-rated acrylic formulation.
Self-sealing and does not require topcoat.
Is made with over 50% renewable resources.
Is available in 12 popular colors, plus two tint bases.
An interior oxidating acrylic formula.
Available in 6 colors, including a Clear Base.
Is a decorative specialty finish.
Can be intermixed to create custom colors.
It requires a topcoat
An interior polyurethane.
Clear drying.
Levels to a smooth, hard, durable finish.
Provides excellent slip and black heel mark resistance.
Apply with a brush, roller, or pad applicator.
It’s available in 18 deep brilliant colors.
And provides universal coverage on many wood species.
Used to control blotching on hard-to-stain woods.
And to reduce Water Based Wood Stains.
A penetrating stain with ink-like consistency.
It is available in 14 vibrant colors.
And can be used as a toner.
Apply with a brush or sprayer or wiping on.
The clear base used to reduce Dye Stain colors.
A polyurethane formulation.
Tintable to dark colors.
Contains UV absorbers & Mildewcides to protect the finish.
Clear drying.
A pigmented polyurethane formulation.
Is tintable to light and pastel colors.
Contains UV absorbers & mildewcides to protect the finish.
Available in 10 colors, including a clear base.
Contains U.V. absorbers & mildewcides to protect the finish.
A premium Interior and exterior-rated acrylic formulation.
Available in 12 popular colors, plus two tint bases.
Apply with a brush, roller or sprayer.
A penetrating oil wood preservative.
Contains UV absorbers and mildewcides to protect the finish.
This finish will amber as it ages.
A maintenance product. Reapply when wear becomes evident.
A heavy-bodied, no-drip oil and urethane formula.
Designed to provide a hand-rubbed look.
Will amber as it ages.
Apply with a brush or wipe on.
A heavy-bodied, no-drip formula.
Available in 14 deep, rich, uniform colors.
Apply with a brush, roller, or wipe on.
A penetrating sealer with a high-quality urethane formulation.
It provides long-lasting, durable protection.
and works beautifully on projects with detail.
a traditional, pigmented liquid wiping stain
Available in 14 colors
Can be used as a toner with Arm-R-Seal
Oil-Based Pre-Stain Conditioneris:
Designed to control blotching on hard-to-stain woods.
And penetrates the grain to promote uniform acceptance of oil stains.
Formulated with a blend of oils, urethanes, and wax.
Is GF’s deepest penetrating close-to-the-wood sealer.
And the best choice for highlighting figured wood.
A urethane-solids polymer in a blend of oil & wax.
Enhances the natural look of wood.
One of our easiest finishes to use.
It’s best used with optional GF Hardener to shorten dry time and providesuperior durability.
This is a maintenance product. Reapply when wear becomes evident.
Apply with a white pad or plastic spreader.
A pure urethane formulation.
Highlights figured wood beautifully
A mineral oil formulation.
Meets all requirements for use on wooden surfaces that come in contact with food.
Apply with a cloth.
A routine cleaner for cured wood finishes
Non-combustible with a fresh orange scent
Apply with a cloth
A blend of waxes.
Produces a soft sheen and feel over any wood finish.
Can be used as a polish for rubbing out new finishes OR as a scratch-remover.
Apply with a cloth.
No matter what your project is, General Finishes has the right product for you. General Finishes is dedicated tousing the highest-quality ingredients in all our products, while testing and advancing our water-based finishes with leading-edge technology.
Maple is one of the most difficult woods to achieve a dark, uniform stain color on because it is a dense, closed grain wood and often absorbs stain very unevenly. General Finishes Gel Stains or Water Based Stains usually will perform very well because they are more topical than traditional liquid oil stains, and contain more colorants.
We do not recommend pre-sealing Maple with a conditioner because it closes up the grain of the wood even more, further preventing color adherence. In the future, just use our water-based stains or gel stains on their own. Do not use liquid oil-based stains on Maple because they will blotch.
Also, prep sand Maple with 120 grit, followed by 150 grit or 220 grit.
