Oil Based Gel Stains
This is the home of the popular Java Gel stain that has been featured across the nation's social media for repurposing & upcycling furniture and cabinets. Gel stain that has the most "finishing feel" of all our products. Woodworkers love the lustrous finish that shows up when rubbing out the 2nd and 3rd coats. Gel Stains are formulated with a combination of pigments, oils, and urethanes to produce a durable and beautiful "hand-rubbed" finish.
Gel Stains are heavy-bodied, and so do not penetrate as deeply into the wood as liquid oilbase stains do. Because of this, they are often less affected by the condition of the wood, and can help you get a more even appearance on difficult woods such as aspen or pine.
Check out our Jiving With Java Pinterest Board for DIY examples of Java Gel Stain or Gel Stain Pinterest Board for more ideas.
Colors
COLORS: American Oak, Antique Walnut, Brown Mahogany, Candelite, Colonial Maple, Georgian Cherry, Golden Pine, Java, New Pine, Nutmeg, Prairie Wheat.
Gel Stains are finely ground pigments oil in urethane. They wipe on and produce beautiful hand rubbed finishes. Gels are a thicker consistency than liquid oil base stains, so no drips, runs or spills.
USE: Interior and Exterior
COLORS: American Oak, Antique Walnut, Brown,Mahogany, Candelite, Colonial Maple, Georgian Cherry, Golden Pine, Java, New Pine, Nutmeg, Prairie Wheat.
ALWAYS test color on hidden area to make sure it is what you want.
SHEEN: Satin.
SANDING: 120-150 grit on bare wood. It is otional to sand stains before topcoating.
COATS: Normally 1-2 (additional coats can be applied to deepen color).
RECOAT/DRY TIME: 6-12 hours under ideal conditions (70° and 70% humidity).
CURE TIME: Cure time for all General Finishes products is about 14 days.
APPLICATION METHOD: Wipe on, natural bristle brush, foam brush, or paint pad applicator.
TOPCOAT: Use Gel Satin Topcoat or Arm-R-Seal. You can also use waterbased High Performance, but wait 72 hours before applying when changing from oil to water based finishes.
CLEANUP: Mineral spirits.
COVERAGE: 200 sq.ft/qt VOC:<550 g/l (4.59 lbs/gal).
RECOMMENDED USES: any wood project, fiberglass doors, interior or exterior.
SPONTANEOUS COMBUSTION: This is a combustible product. Dispose of product soaked rags for all oil base products in accordance with local ordinances.
HOW TO APPLY OIL BASE GEL STAIN
See VIDEO on how to apply Gel Stain on raw wood and layer colors
  • Sand wood to 120-150 grit. Sanding between coats is optional.
  • Apply Gel Stain on liberally with a poly foam brush, Handi-Painter applicator, natural bristle brush, or a cotton cloth.
  • Then wipe off with the grain using a clean dry cotton cloth or even better, high quality paper towels.
  • Additional coats can be applied for a deeper, richer color.
HOW TO USE OIL BASE GEL STAIN OVER EXISTING FINISHES
See VIDEO on how to upcycle existing oak cabinets with Java Gel Stain.
PREPARE THE SURFACE
  • Cover any glass with blue painter's tape. Remove (or tape off) any hardware as the gel will stick to it.
  • Clean the surface with mineral spirits and scotch brite pad or a mixture of 50/50 denatured alcohol and water.
  • Sand the surface with 400 grit paper or a soft back sanding sponge. This is not a heavy duty sanding, but a light buffing.
  • Wipe off dust with a tack cloth or a water dampened rag. Let dry.
TWO WAYS TO APPLY GEL STAIN OVER EXISTING FINISHES
1. Apply On/Wipe Off Method:
Work on one section at a time. Apply gel stain liberally with a cotton cloth, pad, brush, or Handi-Painter applicator. Wipe off excess stain with a cloth or high quality paper towels.  Wipe with the grain and blending any adjoining areas. Additional coats will darken the initial coat.
2. Painting Stain On:
This method is normally used if a very dark painted look is desired. Dry brush on sparingly the first coat. Brush on the second coat heavily with a bristle or foam brush and then dry-brush the excess stain off with a clean brush. Using the flat part of a dry bristle brush (slightly angled) brush across and feather out in the direction of the grain pattern. Additional coats will give a darker color.
FREQUENTLY ASKED QUESTIONS
Can I mix Gel Stains together to achieve other colors? Yes, mix like products together to make more stain options. You can also mix with GF liquid oil base stains to obtain a slightly thinner stain than the normal gel formula.
Can I use GF Dyes Stains under Gel Stains? Yes, many use dyes to achieve a depth of grain, an even base, and to achieve deeper colors. Use Amber or Yellow for a golden glow under any gel stain.
How can I tell if the stain is dry? If the stain feels cool to the touch, its not ready. If it is raining, cold, or humid dry times will be longer. If in doubt, waiting longer is always better.
What is the best top coat to use over Gel Stains? Oil Base GF Gel Satin or GF Arm R Seal.
Will Gel Stains darken with another coat? Yes, Gel Stains will darken with additional coats. See step by step photo instructions on how to layer Gel Stain Colors on the GF Blog.
Are GF products compatible with other brands? A good rule of thumb is “Don’t mix brands.” It might work, it might not. We can't troubleshoot results if you use another manufacturer's products with ours.
Can Gel Stain be applied over laminate counter tops?  The answer is no – not much adheres to laminate very well. Folks have successfully put Gel Stain on more surfaces than we ever dreamed of including fiber glass but if you want to proceed, TEST your procedure on a hidden area first and let cure for 14 days. Then further test the finish by duplicating normal wear and tear: washing, scrubbing, scratching, etc to see if the finish bonds to the surface. It might not adhere. The finish was developed for raw wood, and our concern is that some day in the future it would fail on you. We cannot vouch for application to other surfaces.
Can Gel Stain be applied over a high gloss paint finish on kitchen cabinets? Possibly but not recommended - the high gloss is an issue. Folks have successfully put Gel Stain on more surfaces than we ever dreamed of including fiber glass but if you want to proceed, TEST your procedure on the inside of a door first, let the door cure for 14 days. Then further test the finish by duplicating normal wear and tear: washing, scrubbing, scratching, etc to see if the finish bonds to the surface. It might not adhere. If you want to proceed with your testing, the cabinets need to be de-glossed and then sanded with 150-180 grit sandpaper before attempting to apply either the gel stain or Milk Paint. You can buy a De-Glosser solvent at any paint store. We think Milk Paint would be a better choice as paint is more flexible and tends to adhere well to many surfaces, but test that the same way also. GF has several brown colors you can try, or you mix any of them to create your own custom color.
MSDS & Data
Material Safety Data Sheets
Technical Data Sheets
Performance Data Sheets
Reviews
GF Oil Base Gel Wood Stains Review 01/02/2011
3 years 37 weeks ago
I was having trouble finding the right stain to use on my eighties (and very orange) oak kitchen cabinets.  After much trial and error, I came across General Finishes online.  I tracked it down at Marty's Barn Cellar in Elbridge, NY.  The people there gave me some advice and I went home with the java gel stain and the arm r seal.  The cabinets came out exactly as I wanted are are STUNNING.  The stain was so easy to work with, and the top coat goes on beautifully and dries even better.  The sanding tips on your website were very helpful, too.  Even the professional we have helping us with the rest of the kitchen renovations was impressed.  I am telling everyone about your  stains as not many people in this area are familiar with them.  Thank you!
Stephanie Reagan
Your Gel Stains work equally well on all the various woods we sell. Nome of the usual blotchiness or uneven results found with the products we carried previously
Wood You Opelika
Used Java on an oak dining table
3 years 5 weeks ago
This stain is truly amazing. It is user friendly. The best part about it is it can be layered to achieve the depth of color you like without looking like a paint. love, love, love it!
Customer Showcase
