General Finishes water-based Enduro Pre-Cat Lacquer clear-drying wood finish uses new technology in the polymer manufacturing process. This unique formula produces a smaller and smoother particle, translating into a big increase in film clarity. The chemical, water, and yellowing resistance are superior to competitors, waterborne or solvent. With high block resistance and stack time at a great price point, this is the perfect coating for professional/industrial finishers and OEM production when fast production time is needed. Learn more about General Finish's entire finishing system of clear and pigmented primers, acrylic and polyurethane clears, pigmented topcoats and water-based stains here: 4 Reasons to Switch to Water-Based Finishes.Spray tip recommendations. Made in the U.S.A. by General Finishes:
General Finishes Enduro Pre-Cat Lacquer Application Steps
CAUTION: Do NOT use GF Enduro Pre-Cat Lacqueror any other clear coat, over white or light paints such as GF Milk Paint, or GF White Poly as it may cause yellowing. Any clear coat can become reactive over wood substrates or existing finishes, causing tannin or dye bleed-though regardless of priming. All of GF's white paints do NOT require a topcoat.
Enduro Pre-Cat Lacquer is a hard topcoat engineered for a good price point. If higher durability is needed, use Enduro Clear Poly. See our comparison tool for more information.
Stir topcoat thoroughly to reincorporate solids that have settled to the bottom of the can before and throughout the application process. Do not shake.
Test for adhesion when applying over an existing sealed surface.
Thinas desired with distilled water; start with 5%, adding up to 10% by volume.
Increase open time, if needed, with 10-15% by volume General Finishes Extender if allowed by local regulations. GF Extender will improve flow and leveling and increase open time, which is helpful in dry climates. California Residents: Adding more than 2% of GF Extender will make the product non-compliant per SCAQMD Regulations. GF assumes no liability for the improper use of these products.
Ready to spray from container. Apply a minimum of 3 coats.
Spray application: Before spraying, strain topcoat through a fine-mesh filter. Spray wet films at 3-5-mil thickness. Medium air cap. Fluid tip sizes: Compressed air: .040, HVLP: .043-.051 or Airless: .009-.013. Verify tip sizes with your equipment supplier. See our spray tip size recommendations. Keep your gun at a 90° angle, 6-8" from the surface. On large, flat areas, use wet, even patterns 6-8" wide. For narrow surfaces, reduce the fan pattern to 2-3" wide to reduce overspray. Overlap each pass 25% to conceal lines. Wear a mask and work in a ventilated space. Read here for more information on spraying techniques.
Face frames on cabinets: Enduro professional products are engineered to be spray-only but can be successfully applied to cabinet face frames or edges with a pad or small, cabinet-specific roller such as Whizz Velour brand. Larger areas may not level with a hand application. ALTERNATIVE: Use the same sheen of General Finishes High Performance Topcoaton areas that must be brushed.
If a faster build is desired using clears over raw wood, use General Finishes Sanding Sealer for the first 1-2 coats, followed by 2 coats of Pre-Cat Lacquer.
Finish sand between coats with a fine-grade (220-320) foam sanding pad or 400-grit sandpaper to improve smoothness and adhesion.
Remove dust with a vacuum, compressed air, an oil-free tack cloth or a water-dampened rag.
Tinting & Toning with Pre-Cat Lacquer When tinting, we recommend using General Finishes Enduro Polyor High Performance Topcoat for tinting instead of Pre-Cat Lacquer because they have higher solids.
Dry Time Based on ideal conditions of 70°F 21°C; 50% humidity.
To touch: 10+ minutes
Ready to Sand: 30-40 minutes
Recoat: 1-2 hours
Be sure to allow adequate dry time. You can tell if a water-based finish is dry if it forms a powder when lightly sanded with a fine-grade (220-320) foam sanding pad or 400-grit sandpaper. If in doubt, wait longer. Rushing the dry time can cause "blush," which is clouding in the finish due to moisture trapped between the layers.
Humidity is over 80%
Temperatures are cooler.
3+ coats are applied
Thick coats are applied
Applying over an existing sealed finish
Applying over products from other brands
Layering General Finishes water- and oil-based products:
Water over oil: Let oil-based products dry 72+hr before applying water-based products
Oil over water: Let water-based products dry 24+hr before applying oil-based products
To accelerate dry time in humid conditions, add General Finishes Accelerator and work in a space with good ventilation and air movement. If you decide to re-coat before the recommended time, test dryness.
As is true of most "water-white" topcoats, General Finishes water-based topcoats dry clear over non-reactive substrates, such as plastic or metal, except General Finishes Enduro-Var, which ambers. When white paint sealed with a water-white topcoat is applied to something as unpredictable as wood, all bets are off and the reason for yellowing is often unknown. It can be caused by topcoat activating tannins in raw wood or aniline dyes, stains, or contaminants in a pre-existing finish. This is most evident when using BRIGHT WHITE paint and most prevalent in sculpted details of furniture where the topcoat can collect, intensifying color change to an unacceptable level.
There is no reliable way to predict whether yellowing will occur and to what degree. Every existing finish is different and we rarely know the finishing provenance on an existing piece. Every tree is different and every piece of wood is unique. Raw wood can bleed tannins immediately after the topcoat dries or months later with seasonal temperature changes. Oak, pine, mahogany, and Douglas fir are particularly prone to bleed-through.
Summary
Whites have a lower “hide” quality and are more transparent than most other colors. Nearly all bright whites require additional coats to achieve the desired color and minimize color variation. This can increase the cost of paint finishing. Always include a clause in your contracts addressing the need for additional coats to achieve coverage.
All bright white paint will yellow slightly with time, with or without topcoat. You have probably tried to touch up white woodwork in your home after several years and noticed the new paint is brighter.
The underlying finish or wood species can affect the final color of light paint.
Details and inside corners are difficult to cover with any paint color, but it tends to be more noticeable with whites. This is a naturally occurring phenomenon in paint application and does not necessarily constitute a defect in the paint finish or your technique.
The more porous the paint, such as a chalk paint, the more likely that yellowing will occur. The topcoat is seeping through the spaces caused by the larger particles of filler that give Chalk Paints their texture.
Tips to Prevent Yellowing
If it is a low-use project, use a premium white paint that is self-sealing and does not require a topcoat. A clear topcoat is not required on General Finishes Milk Paint for increased durability, as it is a self-sealing, exterior-rated coating with high durability and chemical and water resistance. However, topcoats do provide a smooth surface that is easier to clean and boosts durability for high-use projects, such as tabletops and kitchen cabinets.
Use a professional product such as General Finishes Enduro White Poly. It has "increased topcoat properties," is a standalone finish when 3 coats are applied, and does not require sealing with a topcoat.
We recommend using General Finishes Stain Blocker, an engineered chemical barrier, to prevent persistent bleed-through for interior-use projects.
Stain Blocker does not adhere to melamine cabinet veneers.
Stain Blocker cannot be tinted.
Always test your project's ENTIRE finishing schedule (from cleaning to topcoat) on an inside door or a more hidden area of the piece. This will not help if the yellowing occurs later, but at least you will know if there is an immediate problem.
Avoid painting period furniture, such as a 1940s serpentine mahogany desk, with light colors. The pieces were often finished in stain that contained aniline dyes, which cast a pinkish bleed-through under light paint. Not every piece of furniture is suitable for upcycling with a light paint color. Pine, mahogany, and furniture of the 1940s and 50s are a red flag.
Last, not all manufacturers' topcoats are compatible with other finishes and may react with a color change. Always follow best practices by not rushing, and testing to your satisfaction first.
Knots Knots in wood tend to bleed and are dense, making paint and stain adhesion a challenge. Stain Blocker may improve adhesion and prevent bleed-through for painting projects. Pine knots are especially difficult to cover with white or light paints. If you decide to paint over them, apply 3 coats of Stain Blocker first; however, we cannot guarantee adhesion or bleed-through blockage. You are better off using a dark paint on pine.
Product that is 3 years old will not look like product that is 6 months to 1 year old. You will see more stratification or separation as the product ages. Always stir thoroughlybefore using.
Foul Smell
See video tutorial: Tips on Storing Leftover Finishes Water-based finishes crystalize and form a skin due to evaporation when the air-tight seal on a can is broken at first use. The following best practices will increase the life of your product:
Remove dust with a water-dampened cloth. Dust can build up over time and may scratch or dull finishes if not removed regularly.
Remove fingerprints, cooking fumes and smoking residue with mild soap and water. These contaminants will not harm the finish, but they accumulate on surfaces and dull the original luster.
As with all fine furniture finishes, avoid using furniture polish, cleaners or dusting sprays that contain silicone, alcohol, ammonia and anything acidic. Exception: We have successfully cleaned with Clorox wipes for occasional cleanups.
Clean up water, alcohol and food spills in a timely manner and use placemats & coasters to protect the finish.
Future finishes or touch-ups may not adhere properly or perform as desired over a contaminated surface. Some contaminants, such as silicone, seep through finish into the wood and often cannot be removed.
Avoid excessive exposure to direct sunlight, high temperatures or high humidity. These can damage furniture and finishes.
Compatibility Do not use water-based products with Linseed Oils or Danish Oils.
Limited Warranty General Finishes products must be tested to your complete satisfaction before using. General Finishes will not be responsible for color satisfaction, misapplication, nor compatibility with other manufacturers' products. General Finishes will be responsible only for the cost of our products, and not for costs such as labor, damage or project replacement.
Contamination and Compatibility Our finishes are engineered as a system and are compatible with each other. General Finishes cannot guarantee an ideal refinish when applying our products on top of or combined with another company's products or over surfaces that have been in contact with waxes, polishes or sprays containing contaminants such as silicone. Test for adherence and aesthetics before beginning.
Warning If you scrape, sand, or remove old paint, you may release lead dust. LEAD IS TOXIC. EXPOSURE TO LEAD DUST CAN CAUSE SERIOUS ILLNESS, SUCH AS BRAIN DAMAGE, ESPECIALLY IN CHILDREN. PREGNANT WOMEN SHOULD ALSO AVOID EXPOSURE. Wear a NIOSH-approved respirator to control lead exposure. Clean up carefully with a HEPA vacuum and a wet mop. Before you start, find out how to protect yourself and your family by contacting the National Lead Information Hotline at 1-800-424-LEAD or log onto www.epa.gov/lead.
Warning This product contains a chemical known to the State Of California to cause cancer and birth defects. Do not swallow; first aid: drink water to dilute product. May cause eye or skin irritation; first aid: flush eyes thoroughly with water.
Warning Keep out of reach of children. Avoid contact with eyes. Keep container tightly closed when not in use. Wash thoroughly after handling.
Hand protection Chemical-resistant, impervious gloves complying with an approved standard should be worn when handling chemical products if a risk assessment indicates this is necessary. Considering the parameters specified by the glove manufacturer, check during use that the gloves still retain their protective properties. It should be noted that the time to breakthrough for any glove material may differ for different manufacturers. In the case of mixtures, consisting of several substances, the protection time of the gloves cannot be accurately estimated.
Eye protection: Safety eyewear complying with an approved standard should be used when a risk assessment indicates this is necessary to avoid exposure to liquid splashes, mists, gases, or dust. If contact is possible, the following protection should be worn unless the assessment indicates a higher degree of protection: safety glasses with side shields.
Respiratory protection: Based on the hazard and potential for exposure, select a respirator that meets the appropriate standard or certification. Respirators must be used according to a respiratory protection program to ensure proper fitting, training, and other important use aspects.
Environmental exposure controls: Emissions from ventilation or work process equipment should be checked to ensure they comply with the requirements of environmental protection legislation.
Appropriate engineering controls: Good general ventilation should be sufficient to control worker exposure to airborne contaminants.
Hygiene measures: Wash hands, forearms, and face thoroughly after handling chemical products, before eating, smoking, and using the lavatory, and at the end of the working period. Appropriate techniques should be used to remove potentially contaminated clothing. Wash contaminated clothing before reusing. Ensure that eyewash stations and safety showers are close to the workstation location.
Product Colors
Water White in can (dries clear)
Base Type
Water
Ambering
No
Sheen
Flat (10 or less), Satin (25-35), Semi-Gloss (50-60), Gloss (80+)
PRE SEALING:
Milk Paint: 1.8mm-2.0mm
Brushable White Enamel 1.8mm-2.0mm
Stain Blocker: 1.8mm-2.0mm
Pearl Effects: 1.8mm-2.0mm
Glaze Effects: 1.8mm-2.0mm
Enduro-Var 1.1mm-1.3mm
SPRAYING TOPCOATS:
Looking for hardness, clarity and fast stack time? Pre Cat Lacquer is the choice. Use in applications where there is little risk of chemical contamination issues from substances such as ketchup, soap, chemical cleaners, or ammonia. This is the perfect spray finish for interior doors, casing, moldings, door jambs and furniture that receives light use. When you think about it, interior doors don't take a lot of wear. You might wipe them down or dust them once in a while but that is about it. PreCat Lacquer is a hard finish that provides excellent build and superior clarity at a phenomenal price point. If you are not finishing a surface such as a tabletop where you anticipate chemical contamination during use, why pay for a more expensive finish?
Poly is the go-to cabinet finish. It has all the durability you need at a lower price point than Conversion Varnish. It is similar to High Performance in test measurements for chemical, water and wear resistance, but HP can be brushed and Clear Poly can't - it is already thinned for spraying. Clear Poly has a bit of an edge over High Performance in overall chemical resistance, a 98 rating vs 92.
This is our top of the line. Conversion Varnish is a post catalyzed high solids, two component urethane formulated for professionals who need the highest level of durability and chemical resistance. Varnish will cure the fastest. Requires NCO Catalyst. It is recommended for commercial applications or extremely high-wear surfaces such as countertops and bar tops
Flat Out Flat is formulated with a self cross-linking acrylic, and is designed to mimic the look and feel of a wax finish. Because of the increased matting agents used to create the "Flat look", this finish will have less clarity. Like wax, it dries softer to the touch than High Performance when completely cured, and will show more fingerprints. FOF finish will mark up more easily because of increased matting agents used to reduce the sheen, so it is not recommended for high-use tabletops.
Enduro-Var is an oil modified water-based alternative for customers that want the warm look of an oil finish in a water based coating. It looks more like an oil finish than a water coating, and can be sprayed or brushed. The original Enduro-Var adheres well ONLY over WATER STAINS, DYE STAINS, and RAW WOOD. Use over other finishes at your own risk. The new formula of Enduro-Var II is compatible with all GF products and dries to a lighter amber than the previous formula.
Exterior 450 provides a clear drying tough, protective finish that will withstand the rigors of the sun, rain, and wind. It is suitable for vertical surfaces such as fences, patio furniture, garage doors, entrance doors, outdoor kitchens and interior windows. It is not recommended as a deck finish. Fortified with UV absorbers to stabilize the finish, Exterior 450's built-in mildewcide retards mold and mildew growth.
