Enduro Waterbased Accelerator | General Finishes
Accelerator is an additive that decreases dry time for our water base wood finishes. Available in gallons and 16 ounce sizes.
Need some inspiration? Visit the General Finishes Design Center or Pinterest Board for furniture ideas.
Features
USE: Can be mixed with any interior or exterior water products.
APPLICATION: Mix into any water product following label directions.
CURE TIME: Cure time for all General Finishes products is about 14 days under ideal conditions (70° and 70% humidity). However, this may vary slightly with humidity & temperature. Good ventilation, air movement and higher temperatures will accelerate dry time.
RECOMMENDED USES: Can be used in any water base stain, dye, exterior stain, or topcoat.
HOW MUCH TO ADD: 10-20% by volume. Higher humidity and cooler temperatures will require 20%.
BOTTLE SIZES: 16 oz., Gallon
VOC: <916g/l (458lbs/gal.)
WARNING: TEST FOR COMPATIBILITY WHEN USING THIS PRODUCT WITH PRODUCTS FROM OTHER BRANDS.
General Finishes products should be tested to your complete satisfaction before using. General Finishes will not be responsible for any failure if our products are used in conjunction with other brands of finishes. We do not test General Finishes products with those of another manufacturer and will not accept liability if there is a compatibility issue.
SDS
Safety Data Sheets
