General Finishes Extender
Extender is a wetting additive used to increase the drying time of any water based stain, topcoat or glaze. Available in gallons and 16 ounces individually and 4 ounce sizes by the case.
Need some inspiration? Visit the General Finishes Design Center or Pinterest Board for furniture ideas.
Features
Extender is a water base additive that can be mixed with any General Finishes water base product to give more open time to stains and topcoats. This product will slow down the dry time.
USE: Interior and Exterior (can be mixed into any water base product)
APPLICATION: Mix into any water product and apply as normal.
COVERAGE: The addition of Extender will not change any square foot coverage information.
BOTTLE SIZES: 4 oz., 16 oz., Gallon
VOC: <1023g/l (511 lbs/gal.)
HOW MUCH TO ADD: 10-20%  Add in the minimum amount first and slowly add more in 5% increments (especially with topcoats, they are already thin). Less is always better when you are using additives.
WARNING: TEST FOR COMPATIBILITY WHEN USING THIS PRODUCT WITH PRODUCTS FROM OTHER BRANDS.
General Finishes products should be tested to your complete satisfaction before using. General Finishes will not be responsible for any failure if our products are used in conjunction with other brands of finishes. We do not test General Finishes products with those of another manufacturer and will not accept liability if there is a compatibility issue.
SDS
Safety Data Sheets
