Oil Based Salad Bowl Finish
Salad Bowl Finish is a durable oil-and-urethane oil-based finish and can be used as a beautiful and safe topcoat on wooden bowls, cups, spoons, decorative wood countertops or other wood surfaces that come into contact with food. For butcher block countertops actively used for chopping and cutting, we recommend Butcher Block Oil.
Need some wood finishes inspiration? Visit the General Finishes Design Center or Pinterest Board for project ideas.
Find A Store Compare Similar Products
General Finishes Salad Bowl Finish, Quart
Step 1: Preparation Over Raw Wood
Preparation for Raw Wood
  1. The sanding schedule for wood that will be clear coated with an oil-based topcoat: sand up to 150-grit sandpaper.
  2. Remove dust with a vacuum, tack cloth or water-dampened rag.
  3. Do not over-sand with fine-grit sandpapers; this will close and seal the wood grain, preventing ideal color absorption.
Step 2: How To Apply General Finishes Salad Bowl Finish
General Finishes Salad Bowl Finish Application Steps Over Raw or Stained Wood
  1. Stir topcoat to reincorporate solids that have settled to the bottom of the can before use. Urethane topcoats are thin and the flatting agents used to create flatter sheens settle quickly to the bottom. Either stir and decant what you need to use immediately or stir frequently throughout the application process.
  2. Use only with adequate ventilation. Open windows and doors or use other means to maintain fresh air flow during application and drying.
  3. If desired, thin topcoat with 10-15% mineral spirits.
  4. Apply 3 coats. More coats will not improve durability.
    • Brush application: Apply a liberal amount of product using a clean cloth, bristle brush, foam brush, staining pad or pad applicator. The larger the surface the larger the applicator needed. Wipe along the wood grain using smooth, even strokes. Remove excess with light pressure.
    • Spray application: Salad Bowl Finish can be sprayed successfully, but we prefer hand-application methods because it is easy to spray too much in one area. Spray thin coats and immediately wipe or brush out runs if they occur. HVLP: 1.0mm-1.2mm spray tip, medium air cap. See our general guide for spray tip sizesRead here for more information on spraying techniques.
  5. Lathe application: When applying to projects on the lathe, wipe on a thin even coat, then use 400-grit wet or dry sandpaper to wet-sand first coat into the wood. Use a clean cloth to buff off the excess.
  6. Dry 24+ hours between coats in ideal conditions, 70*F/20*C, 50-70% humidity. Inadequate dry time is one of the top reasons for finish failures. You can tell if an oil-based finish is dry if it is no longer tacky, cool to the touch, and if you can press a cotton ball over the surface and nothing sticks. If in doubt, wait longer. Increase dry time if:
    • To accelerate dry time in humid conditions work in a space with good ventilation and air movement. If you decide to re-coat before the recommended time, test dryness.
  7. Finish sand between coats with a fine-grade (220-320) foam sanding pad or 400-grit sandpaper to improve smoothness and adhesion.
  8. Remove dust with a vacuum, cloth or clean water dampened rag before re-coating.
Cure time
Oil-based finishes cure and harden completely after 30 days. Avoid placing heavy objects on top of surfaces that have not cured completely. Treat gently, and do not clean with commercial products during the cure period.
Storage of Oil Based Products
General Finishes products do not last forever, even when unopened. They are best used within 1 year of the manufacture date listed on the bottom of the can. The life of the product may be extended with proper care and storage.
  6. Avoid temperatures below 50*F/10*C or above 80*F/26*C. Frozen and heat-damaged product cannot be revitalized. Store in original container protected from direct sunlight in a dry, cool and well-ventilated areas.
  • As with all fine furniture finishes, avoid using furniture polish, cleaners or dusting sprays that contain silicone, alcohol, ammonia and anything acidic. Exception: We have successfully cleaned with Clorox wipes.
General Finishes products must be tested to your complete satisfaction before using, including compatibility with other manufacturers products. General Finishes will be responsible only for the cost of our products and will not be responsible for any costs such as labor, damage, or replacement costs.
Danger: Contents are COMBUSTIBLE. Keep away from heat and open flame. Application materials or other waste soaked with this product may spontaneously catch fire if improperly discarded. Immediately after use, place rags, steel wool or waste in a sealed, water-filled, metal container. Dispose of in accordance with local fire regulations.
CAUTION: Contains ALIPHATIC HYDROCARBONS. VAPOR HARMFUL. Use only with adequate ventilation. DELAYED EFFECTS FROM LONG-TERM OVEREXPOSURE. Contains solvents which can cause permanent brain and nervous system damage. Intentional misuse by deliberately concentrating & inhaling the contents can be harmful or fatal.
Do not swallow; first aid: drink water to dilute product. May cause eye and skin irritation; first aid: flush eyes thoroughly with water.
FIRST AID: In case of eye contact, flush thoroughly with large amounts of water for 15 minutes and get medical attention. For skin contact, wash thoroughly with soap and water. In case of respiratory difficulty, provide fresh air and call physician. If swallowed, do not induce vomiting. Get medical attention immediately.
Product Colors Dries Amber
Ambering Yes
Sheen Gloss (90+)
Type Oil & Urethane
Spray Tip Sizes HVLP 1.0mm-1.2mm
Dry Time - Touch 12+ hr
Dry Time - Recoat 24+ hr
Dry Time - Cure 30 days
Can Sizes Pints, Quarts
Coverage 50 sq. ft/pint, 100 sq. ft/quart
Viscosity Thin
Viscosity (cPs) 100-200
Weight Solids 32%
VOC <575 g/L
Hardness (Koenig #) 77
Wear (Taber #) 57.10 mg loss
Water 5
Chemical 101
Salad Bowl Finish FAQs
Why isn't the Salad Bowl Oil I applied to walnut serving boards drying after two coats?
Some pieces of wood contain a lot of oil and walnut can be finicky. The oil in the walnut wood may be causing the problem you've described - a longer dry time might have been needed over an oily wood. If the wood does not dry over the next few days then it may be necessary to sand down and start over. Unfortunately, if the first coat does not dry, the second will never dry.
Relevant Videos
Relevant Videos
