Winner of Fine Woodworking's "Best Overall Choice Award," High Performance Topcoat was voted as the hardest, most durable consumer polyurethane topcoat. It is so versatile, it can be brushed or sprayed.
Flat Out Flat is a matte water based topcoat with a velvety feel and was developed as a durable alternative to our Satin Wax.
Choose this product if you want a finish that looks more like wax and your project will not require high use. Like wax, it dries softer to the touch than High Performance when completely cured, and it will show more marring and fingerprints. Flat Out Flat is made with a stable self cross-linking acrylic instead of urethane.
No, you should not mix Flat Out Flat and High Performance topcoats. They are engineered with different resin systems.
You can mix High Performance topcoats to adjust sheen. For example, you can mix HP Flat and HP gloss to obtain a different sheen.
GF has improved the High Performance formula and Cross Linker would not provide an added benefit.
This is a guesstimate as GF cannot assist with the performance of another manufacturer's product used in conjunction with our own finishes.
It looks like Annie Sloan Chalk Paint is absorbing some of the topcoat because it is so porous. High Performance does not streak over a sealed surface when properly applied. Most likely the chalk paint is so dry it is pulling some of the solvents away from the High Performance, causing an uneven finish or the appearance of streaking. This happens on the original powder Chalk or Milk Paints also.
Add a subtle touch of gold with Burnished Pearl Effects! Learn more about Pearl Effects here: https://youtu.be/7c5WZEwA9wI
Chris Adams and "celebrity guest" Nicole Genz of Rescued Furnishings show how to apply General Finishes
You asked for a SUPER MATTE sheen, and now it's ready to order.
Exciting New Features:
Sand down the final finish with a 220-grit foam sanding pad, and then add another layer of General Finishes High Performance PolyurethaneTopcoat. Apply liberally than you did previously without heavy back-brushing.
Let the topcoat self-level a bit - it will tighten down as it dries.
If it's above 80°F or if the humidity is less than 70% in the space you're working, we recommend adding 10% GF Extender to the topcoat to improve open time.
