All wood projects require preparation sanding, and all existing finishes require prep cleaning and sanding. If you skip this critical step, your finish may fail.
- Sand with 120-grit sandpaper followed by 150- or 220-grit sandpaper.
- Remove dust with a water-dampened rag or oil-free tack cloth.
- Let dry completely before applying GF product.
- Do not over-sand with fine-grit sandpapers; this will close and seal the wood grain, preventing ideal color absorption.
- Do NOT use steel wool with water-based finishes; the particles will get trapped in the finish and rust.
Preparation for Sealed Surface
See our video: How to Prep Existing Finishes
- Scuff clean with a Scotch-Brite™ pad or maroon synthetic steel wool & 50:50 mix of denatured alcohol & water.
- Dry 1-2 hours.
- Sand lightly with 220-320-grit foam sanding sponge.
- Remove dust.
Step 2: Application of General Finishes Enduro White Undercoat
Enduro White Undercoat is recommended as a spray application but synthetic bristle or foam brush, or short nap or foam roller can be used when necessary. The brushes and rollers can be useful for face frames. Apply over raw wood, MDF, existing finishes. Perfect for using as an undercoat for lighter-colored pigmented topcoats and paints. It acts as a physical barrier rather than a chemical barrier. For priming light or pastel colors, Use Enduro Deep Base Primer. For woods that exhibit tannin bleed-through, use General Finishes Stain Blocker.
Download 2024 Professional Water Based Product Catalog here.
Application Steps
- Product overview video coming soon.
- Work in a well-ventilated area.
- Stir General Finishes Enduro White Undercoat thoroughly to reincorporate solids that have settled to the bottom of the can before and throughout the application process.
- Test for adhesion over existing sealed surfaces.
- Thin as desired with distilled water; start with 5%, adding up to 10% by volume.
- Increase open time, if needed, with 10-15% by volume of General Finishes Extender, if allowed by local regulations. GF Extender will improve flow and leveling and increase open time, which is helpful in dry climates.
- Ready to spray from the container. Apply 1-2 coats, depending on the substrate, the amount applied, and the application method. If you apply 1 light coat you can sand through, add another coat. If you apply 1 solid first coat and sand lightly, then you only need one.
- Spray application: Before spraying, strain through a medium-mesh filter. Spray wet films at 3-5-mil thickness. Medium air cap. Fluid tip sizes: Compressed air: .040, HVLP: .072 or Airless: .011-.013. medium air cap. Verify tip sizes with your equipment supplier. See our spray tip size recommendations here. Keep your gun at a 90° angle, 6-8" from the surface. On large, flat areas, use wet, even patterns 6-8" wide. For narrow surfaces, reduce the fan pattern to 2-3" wide to reduce overspray. Overlap each pass 25% to conceal lines. Wear a full filter (NIOSH/MSHA approved) respiratory & eye protection and work in a ventilated space. Read here for more information on spraying techniques.
- Face frames on cabinets: Enduro professional products are engineered to be spray-only but can be applied successfully to cabinet face frames, edges or drawer fronts with a synthetic bristle or foam brush or small cabinet specific foam roller or 3/8" nap microfiber roller such as Whizz or AllPro brand. Larger areas may not level with hand application.
- If a faster build is desired over raw wood, use General Finishes Sanding Sealer for the first coat.
- Dry time based on ideal conditions: 70°F/20°C; 50% humidity. To touch: 30 minutes. Re-coat: 1+ hour. Dry times are dependent on application method and environmental conditions. Inadequate dry time is one of the top reasons for product failure. You can tell if a water-based finish is dry if it forms a powder when lightly sanded with a fine-grade (220-320) foam sanding pad. If in doubt, wait longer. Increase dry time if:
- Humidity is over 80%
- 3+ coats are applied
- Thick coats are applied
- Applying over an existing sealed finish
- Layering General Finishes water- and oil-based products:
- Water over oil: Let oil-based products dry 72+hr before applying water-based products
- Oil over water: Let water-based products dry 24+hr before applying oil-based products
- To accelerate dry time in humid conditions, add General Finishes Accelerator and work in a space with good ventilation and air movement. If you decide to re-coat before the recommended time, test dryness.
- Finish sand between coats with a fine-grade (220-320) foam sanding pad to improve smoothness and adhesion.
- Remove dust with a vacuum, compressed air, an oil-free tack cloth or a water-dampened rag.
Tinting
Not applicable
Warning: Do not use water-based products with Linseed Oils or Danish Oils.
Product that is 3 years old will not look like product that is 6 months to 1 year old. You will see more stratification or separation as the product ages. Settling is natural. Always stir thoroughly before using.
Foul Smell
If your product has a foul smell, it is contaminated and no longer in useable condition.
Water-based finishes crystalize and form a skin due to evaporation when the air-tight seal on a can is broken at first use. The following best practices will increase the life of your product:
- Pry open sealed lids with a paint can opener by hooking under the lid's rolled edge. The use of a screwdriver can disfigure the rim and lid, impairing a complete seal.
- Keep lid closed while working. Pour what you will use into a bowl, paper cup, or plate, and close can lid as you work.
- Clean the chime of the can thoroughly with a paper towel before closing to create a complete seal. Product falling into the chime can be minimized by using a pouring lid, such as Fitsall. Avoid wiping used brushes on the lid.
- Pound the lid in place using a rubber mallet to avoid distorting the chime or lid. Dents in the lid from direct contact with a hammer can impair a complete seal. Alternatively, place a flat piece of wood over can lid and firmly pound shut.
- Store in moderate temperatures. Avoid temperatures below 50°F/10°C or above 100°F/26°C. Keep from freezing. Frozen and heat-damaged product cannot be revitalized. Temperature-controlled spaces, such as a basement, are ideal for storage. Do not store product in an attic, garage, in direct sunlight, or next to something warm like a water heater or furnace.
- Store can upside down to create a liquid seal, minimize evaporation and reduce the chance of crystallization. Decant remaining product from the can before stirring.
- Decant leftovers to a smaller container when the finish is almost used up. Alternative storage containers for water-based products are plastic FIFO bottles or glass bottles. Do not fill metal-lidded containers completely to prevent them from rusting.
- Product thinned with up to 15% General Finishes Extender or General Finishes Accelerator can be stored, with the exception of thinned General Finishes Water Based Wood Stain.
- Mixtures involving colors & sheens within the same product line, such as:
- High Performance Satin + High Performance Gloss
- Snow White Milk Paint + Coastal Blue Milk Paint
- Amber Dye Stain + Merlot Dye Stain
The following product mixtures should NOT be stored:
- Any water based product with thinned tap water; water often contains bacteria that will adversely affect stored paint.
- Topcoat + Stain or Paint
- Milk Paint + Chalk Style Paint
- Water Based Wood Stain + Dye Stain
- Remove dust with a water-dampened cloth. Dust can build up over time and may scratch or dull finishes if not removed regularly.
- Remove fingerprints, cooking fumes and smoking residue with mild soap and water. These contaminants will not harm the finish, but they accumulate on surfaces and dull the original luster.
- As with all fine furniture finishes, avoid using furniture polish, cleaners or dusting sprays that contain silicone, alcohol, ammonia and anything acidic. Exception: We have successfully cleaned with Clorox wipes for occasional cleanups.
- Clean up water, alcohol and food spills in a timely manner and use placemats & coasters to protect the finish.
- Future finishes or touch-ups may not adhere properly or perform as desired over a contaminated surface. Some contaminants, such as silicone, seep through finish into the wood and often cannot be removed.
- Avoid excessive exposure to direct sunlight, high temperatures or high humidity. These can damage furniture and finishes.
Eye protection: Safety eyewear complying with an approved standard should be used when a risk assessment indicates this is necessary to avoid exposure to liquid splashes, mists, gases, or dust. If contact is possible, the following protection should be worn unless the assessment indicates a higher degree of protection: safety glasses with side shields.
| Basic Features | |
| Product Colors | White |
| Base Type | Water |
| Ambering | No |
| Interior or Exterior | Interior/Exterior |
| Tintable | White & light colors only |
| Type | Acrylic Primer |
| Application | |
| Coats | 1 - 2 coats |
| Application Method | Brush face frames: Synthetic or foam brush, Roll face frames: Short nap or foam, Spray |
| Brushable | No |
| Usable over existing finishes | Yes |
| Sprayable | Yes |
| Spray Tip Sizes | HVLP 1.5mm-1.8mm |
| Topcoat Required | Yes |
| Dry Time | |
| Dry Time - Touch | 30+ min. |
| Dry Time - Recoat | 1+ hr |
| Dry Time - Light Use | 7-10 days |
| Dry Time - Cure | N/A |
| Contents | |
| Can Sizes | Gallons, 5 Gallon pails, 55 Gallon drums |
| Coverage | 450 sq.ft. (41.81 m²) per Gallon |
| Technical Data | |
| Viscosity | Thick |
| Viscosity (cPs) | 1000-2000 |
| Weight Solids | 53% |
| VOC |
US VOC <90 g/L |
Enduro Water-Based Conversion Varnish
Enduro Water Based Stain Blocker Primer
Enduro Water-Based Tintable 2K White Poly
Enduro Water-Based Pro Series White Polyurethane
Hard Wax Oil & Hardener
Gel Stains
Pro Image Flooring Topcoat
Jen Poly Brushes
Stir Stix
Ultraflex Softback Sanding Sponge
TDS: Enduro White Undercoat - 2020-03
