Enduro Black and White Poly
Enduro Pigmented Poly is a high solids pigmented finish. It is ideal for cabinets and millwork. Stocked in Black and White, custom colors are available upon request. White and Clear can be used as tint bases to achieve endless colors. For non architectural use. Can be used with General Finishes Glaze Effects. Recommended Accuspray HVLP atomizing sets: .043, .051 or .072 tip and nozzle, No. 10 air cap. Click here for a guide for spray tip sizes.
Sheen: Satin, Semi Gloss
Features
Colors: White, Black
Sheen: Satin, Semi-gloss
Recoat/Dry Time: 1-2 hours
Coats Recommended: 2 - over 2 coats of Undercoat
Cure Time: 21 days
Cleanup: General clean-up with soap and warm water recommended. Rinse thoroughly with clean water. For best results, clean all equipment with General Finishes Brush and Gun Cleaner.
Coverage: 450 sq ft/gal
Can Size: Gallon
Recommended Use: Interior wood applications
Primer Recommendation:
Topcoat Recommendation: All General Finishes waterbased topcoats
Spray Tip Sizes Recommended: .043, .051 or .072 tip and nozzle, No. 10 air cap.
VOC: < 222 g/l (1.86 lb/gal)
Viscosity: 60-70 seconds, Ford #4
