Enduro Professional Water-Based RTM Stains
General Finishes RTM (Ready To Match) Stain System for professional finishers, industrial users, and OEM manufacturing facilities makes color-matching the easiest process on the market. The system consists of 12 ready-to-use LOW VOC water-based stains plus a clear base; a chip box with over 100 color formulas on two-sided color chips plus stock color chips; and a formula book available in print/digital format to calculate any quantity of stain. Intermix the stains and base to design your own colors. Brush or spray application. See our spray tip size recommendations here. Click on the last tab to take a look at the RTM Chip Box. 4 Reasons to Switch to Water-Based Finishes. Made in the U.S.A. by General Finishes.
General Finishes Stain Color Matching System: Enduro RTM Stain
Step 1: Preparation of Raw Wood for Water Based Stain
Before applying stain, all raw wood projects require preparation sanding, and all existing finishes require prep cleaning and sanding. If you skip this critical step, your finish may fail.
Prep Sanding for Raw Wood Projects
  1. Sand open-grain wood (e.g., oak, ash, mahogany, parawood) with 120-grit sandpaper, followed by 150-grit, then 180-grit.
  2. Sand closed-grain wood (e.g., cherry, pine, maple, birch, alder) with 150-grit sandpaper followed by 220-grit.
  3. Remove dust with a vacuum, compressed air, an oil-free tack cloth or a water-dampened rag.
  4. Do not over-sand with fine-grit sandpapers; this will close and seal the wood grain, preventing ideal color absorption.
  5. Do NOT use steel wool with water-based finishes; the particles will get trapped in the finish and rust.
Prep Sanding for Existing Finish
  1. Remove any existing finish by sanding with 120-grit-sandpaper & scuffing with a wire brush if needed.
Reducing Grain Raise on Raw Wood
To reduce grain raise, dampen the wood with water after prep sanding. Let dry completely, then lightly sand with fine-grade (220-320) foam sanding pad.
Step 2: How To Apply General Finishes RTM Water Based Stain
General Finishes Ready to Match (RTM) Stain Application Steps
Download 2024 Professional Water Based Product Catalog here.
Download 2024 RTM Brochure Here
  1. Watch how to color match RTM stain here or product overview video here.
  2. Stir stain to reincorporate solids that have settled to the bottom of the can before and throughout the application process.
  3. Thin as desired with distilled water; start with 5%, adding up to 10% by volume.
  4. Increase open time, if needed, with up to 5% General Finishes Extender  if allowed by local regulations. GF Extender will improve flow and leveling and increase open time, which is helpful in dry climates. California Residents: Adding more than 2% of GF Extender will make the products non-compliant per SCAQMD Regulations. GF assumes no liability for the improper use of these products.
  5. An initial coat of General Finishes Pre-Stain Conditioner Natural can improve color uniformity over difficult-to-stain wood species such as pine. However, it will limit color absorption, so a darker stain may be required to get the depth of color you want.
  6. Test your complete finishing process before starting. The stain color is affected by variances in wood and deepened with the application of topcoat.
  7. Divide your project into manageable sections: top, side, drawer, door, table seam.
  8. Hand-Application over Raw Wood:
    • Apply a LIBERAL amount of stain to ensure easy workability using a synthetic bristle brush, foam brush, pad applicator, staining pad or microfiber roller. If not enough stain is used, the surface may dry too quickly, causing an uneven appearance. On large projects, leave a wet edge between sections to prevent lap lines.
    • Stain a complete section and wipe off the excess evenly with the grain using quality paper towel or shop towel. Check for missed spots and lap marks before moving to the next section. Do NOT use cotton t-shirts to wipe away stain because they will "push" the stain around and not absorb it.
    • Immediately correct lap marks by rewetting the entire working area with stain and wiping off the excess.
    • Pull excess stain out of corners and details with a synthetic bristle brush.
    • Dry time based on ideal conditions: 70˚F/21˚C; 50% humidity. Tack-free: 15-30 minutes. Recoat: 30-45 minutes. Topcoat: 1-2 hours.  Be sure to allow adequate dry time. If in doubt, wait longer. Increase dry time if:
      • Working in cooler temperatures
      • Working over a previously existing finish or sealed surface
        • To accelerate dry time in humid conditions, add General Finishes Accelerator before applying and work in a space with good ventilation and air movement. If you decide to re-coat before the recommended time, test dryness.
    • Optional: apply a second coat to deepen the color. Apply no more than 2 coats.
    • Finish with 3 coats of General Finishes topcoat.
  9. Spray Application over Raw Wood:
    • HVLP: 0.9mm-1.1mm spray tip, medium air cap. Verify tip sizes with your equipment supplier. See our spray tip size recommendations here. Wear a full filter respirator (NIOSH/MSHA-approved) and work in a ventilated space. Keep your gun at a 90* angle, 6-8" from the surface. On large, flat areas, use wet, even patterns 6-8" wide. For narrow surfaces, reduce the fan pattern to 2-3" wide to reduce overspray. Overlap each pass 25-50% for even coverage. Read here for more information on spraying techniques.
    • Apply section by section. Spray liberally to a complete section and wipe off the excess evenly with the grain using quality paper towel or shop towel. Check for missed spots and lap marks before moving to the next section. Do NOT use cotton t-shirts to wipe away the stain because they will "push" the stain around and not absorb it.
    • Pull excess stain out of corners and details with a bristle brush.
  10. Optional: apply a second coat to deepen the color. Apply no more than 2 coats.
  11. Finish with 3 coats of General Finishes topcoat.
Step 3: Topcoat Over Water-Based Stain
Always seal General Finishes Water Based Wood StainGeneral Finishes Dye Stain and General Finishes Enduro Ready-To-Match (RTM) Water Based Wood Stain with 3 coats of topcoat. More coats will not improve durability.
Grain Raise
After the first coat of topcoat has dried, you can knock down grain raise by lightly sanding with a 220 sanding pad. Watch Grain Raise video here.
Recommended Water-Based Topcoats
General Finishes High Performance can be applied by hand or sprayed; General Finishes Enduro Clear Poly is spray-only. Both topcoats dry clear and are great for high-use surfaces, such as kitchen cabinets and tabletops. General Finishes Flat Out Flat is our flattest topcoat, suitable for projects that do not receive major wear.
Recommended Oil-Based Topcoats
When sealing with General Finishes oil-based topcoats, General Finishes Arm-R-Seal and General Finishes Gel Topcoat, let water-based stain dry a minimum of 24 hours first. Oil-based topcoats amber increasingly over time.
Toning with Stains
Toning is the process of adding colorant (tinting), either dye or pigmented stain into a top coat and then applying over an entire piece in order to subtly deepen the color. All of GF water-based stains can be used: Stock base colors of RTM stains, Water-Based Wood Stains or Dye stains. If you are new to toning, we recommend starting with GF Dyes Stains, which can be easier to use as they only contain dyes and no pigments.
All of General Finishes water-based topcoats with the exception of Conversion Vanish can be tinted to create lightly colored finishes for toning.  It is YOUR RESPONSIBILITY TO TEST to your satisfaction before application to your entire project.
There are limits anytime you add pigments or dyes to water-based topcoats. Toning should always be done in small increments to achieve the desired color. If you are starting with a light honey tone door and you want to create an Espresso color this will take multiple coats of color including base coat of stain followed by several toning coats. It is impossible to achieve a radical change in color in coat application.
A good rule to follow when tinting is starting with a minimal amount of stain or dye, 5-10% by volume. Some colors work better than others. Normally 1-2 ounces or stain per quart of clear topcoat is sufficient to create a toner. Always test color first and strain material through a fine mesh filter to remove any undissolved particle of pigment. Once you have achieved the desired color tone apply a clear topcoat to lock in the color.
Some tinting recommendations are:
  • Do not exceed 13 ounces per gallon. Excess amounts of colorant can create surface defects and decrease the viscosity (causing drips, sag, etc.).
  • Tinting a product black only requires about 6 to 8 ounces (based on strength of colorant).
Product Colors 12 Stain Concentrates and a Clear Base, unlimited color matching capabilities - Stain concentrates: Tint White, Raw Sienna, Golden Brown, Red, Trans Red Oxide, Burnt Umber, Raw Umber, Tavern Brown, Bordeaux, Tint Black, Strong Black, Tint Gray
Sheen N/A
Type Enduro Stain Concentrate
Application Method Brush, Roll, Spray, Pad
Usable over existing finishes No
Spray Tip Sizes HVLP 0.9mm-1.1mm
Dry Time - Touch 15-30+ min.
Dry Time - Recoat 1+ hr
Dry Time - Cure N/A
Can Sizes Quarts, Gallons, 5 Gallon pails, 55 Gallon drums
Coverage 110-125 sq. ft/quart, 450-500 sq. ft/gal
Viscosity Thin
Weight Solids 15%
Bordeaux: <60 g/L
Burnt Umber: <200 g/L
Golden Brown: <75 g/L
Raw Sienna: <150 g/L
Raw Umber: <110 g/L
Red: <170 g/L
Strong Black: <115 g/L
Tavern Brown: <165 g/L
Tint Base Black: <265 g/L
Tint Base Clear: <95 g/L
Tint Gray: <115 g/L
Tint White: <95 g/L
Trans Red Oxide: <225 g/L
RTM Water Based Stain FAQs
What is toning finishes?
There are limits anytime you add pigments or dyes to water-based topcoats. Toning should always be done in small increments to achieve the desired color. If you are starting with a light honey tone door and you want to create an Espresso color this will take multiple coats of color including base coat of stain followed by several toning coats. It is impossible to achieve a radical color change with just 1 coat of toner.
*Why Isn't RTM Stain Adhering to the Wood Grain of My Oak Project?
This problem could be caused by the surface tension of the oak. Surface Tension, sometimes created by sanding, can cause stains to not adhere to the grain of the wood.
You have a few options:
  1. Lightly hand-apply the first coat, then spray (without wiping) a second coat.
  2. Hand-apply stain the first coat. Then tone the piece by applying a mix of 10-15% stain with topcoat.
How The RTM System Works
The System Includes 3 Items:
1) A set of 12 water-based stock stain colors plus a clear base.
12 Stock Concentrates
  • General Finishes RTM Wood Stain Stock Color - Tint Base Black (ON OAK)
  • General Finishes RTM Wood Stain Stock Color - Tint Base White (ON OAK)
  • General Finishes RTM Wood Stain Stock Color - Trans Red Oxide (ON OAK)
  • General Finishes RTM Wood Stain Stock Color - Strong Black (ON OAK)
  • General Finishes RTM Wood Stain Stock Color - Tint Gray (ON OAK)
  • General Finishes RTM Wood Stain Stock Color - Bordeaux (ON OAK)
  • General Finishes RTM Wood Stain Stock Color - Burnt Umber (ON OAK)
  • General Finishes RTM Wood Stain Stock Color - Golden Brown (ON OAK)
  • General Finishes RTM Wood Stain Stock Color - Raw Sienna (ON OAK)
  • General Finishes RTM Wood Stain Stock Color - Raw Umber (ON OAK)
  • General Finishes RTM Wood Stain Stock Color - Red (ON OAK)
  • General Finishes RTM Wood Stain Stock Color - Tavern Brown (ON OAK)
2) Color Chip Box
Includes 96 4"x5" two-sided color chips available in maple/oak OR maple/alder. Each chip is labeled with the stain number and corresponding formula for easy reference.
General Finishes Custom Color Matching System Chip Box
3) An RTM Formula Book
This is an RTM Formula book that includes breakdowns of all 96 formulas. Need a different color? You can modify the formulas to fine-tune the color match. Pick out the closest color as a starting point and adjust the parts until you get a match. Once you finalize the formula, save it for future reference to the RTM stain calculator in the Excel spreadsheet included on the USB drive.
Enduro RTM Water-Based Stain Formula Book
It's Fast And Easy
  1. Pick a color from the chip box. Find the formula in the book. Each custom color has a code # on it. For example, the #54 formula is 1 part red 1 part black.
  2. Test the color using 1 tablespoon of red and one tablespoon of black.
  3. A second coat will deepen the color.
  4. Clear coat the sample and you are done.
The Benefits
  • Consistent, accurate color matches every time.
  • Rich colors that can only be achieved in a water-based formula.
  • Our proprietary color blends provide consistency without sacrificing clarity.
  • Colors can be mixed by weight or volume for duplicable consistency.
  • No tinting wheel needed.
  • Compatible with most water and solvent-based clear coats.
  • Low VOC, non-flammable & water clean-up
  • Available in quarts, gallons, 5-gallon pails, 55-gallon drums
